Home » Archived » M2M (model-to-model transformation) » [QVTo] Generate XMI with multiple namespaces
[QVTo] Generate XMI with multiple namespaces [message #739527] Mon, 17 October 2011 11:19 Go to next message
I would like to write a QVT transformation in Eclipse Indigo that accomplishes the following:
I have an Input Meta-Model, lets call it In.ecore (which is generated from an xsd file).
I have two Output Meta-Models, Out_includes_A.ecore and Out_included_B.ecore, which are also generated from two different xsd description files. These xsd files import one another, or to be more precise Out_includes_A includes Out_included_B.
In the Ecore models, I could deal with these references either by implementing Attributes of type AnySimpleType or something, or by using references to the types in the other Meta-Model. I decided to go with the second option, which might be wrong already.
Now, I wrote a QVT transformation that should create an output model (out.xmi) something like
<node xmlns:BBB="http:SLASHSLASHwww.BBB.orgSLASHBBB"
  xmlns="http:SLASHSLASHwww .AAA.orgSLASHAAA">
   <something_from_AAA name="xxx" />
   <BBB:something_from_BBB </>
</node>
However, that's not what I get. Instead, the second namespace is completely disregarded (in a sense). I get something like
<node xmlns="http:SLASHSLASHwww .AAA.orgSLASHAAA">
   <BBBsomething_from_BBB </>
</node>
where BBBsomething_from_BBB was the name given to the reference Element in the node-part of the AAA-Input Meta-Model. The Extended Meta Data references are correct (they point to the correct namespace).
The QVT transformation looks like
transformation Input2AAA(in a : Input, out : AAA);
i.e. the Output model is of type AAA, maybe this is my mistake.
So, my question is: what do I need to do, to accomplish the behavour I want? My problem is, I don't really know where to start. Is it an Ecore Problem? Should I somehow try to combine both output metamodels into one? Should I use AnyType-based solutions? Or are my Extended Meta Data references broken? Or should I go about my QVT transformation in a different way? Or is it a problem with the xsd importer?
I have worked with all of these tools quite a lot, but my understanding of them is not very deep, as one can surely see easily. And I left out quite a lot of information. What kind of information would you need in order to answer these questions above?
Is there a standard way to go about this? I googled but I could not come up with a lot, concerning multiple namespaces in xsd and there handling Ecore and in the M2M tooling.
Thank you very much in advance for your help. It is deeply appreciated!
Daniel
Re: [QVTo] Generate XMI with multiple namespaces [message #739584 is a reply to message #739527] Mon, 17 October 2011 12:17 Go to previous messageGo to next message
Hi Daniel
I recommend separating your concerns.
Most of the Eclipse Modeling tools support Ecore, and QVTo supports
Ecore to Ecore transformations.
EMF provides XSD import and export capabilities for Ecore files that are
then used by other tools, so find out which of
a) XSD2Ecore
b) Ecore2Ecore
c) Ecore2XSD
does not do as you want and then fix it. Each stage has plenty of
configuration capabilities and opportunities for errors.
Ed Willink
On 17/10/2011 16:19, daniel.engelhardt wrote:
> Hello,
> from an xsd file).
> <BBB:something_from_BBB </> </node>
> <BBBsomething_from_BBB </> </node>
> importer?
> Best regards,
> Daniel
Re: [QVTo] Generate XMI with multiple namespaces [message #742446 is a reply to message #739584] Thu, 20 October 2011 09:55 Go to previous messageGo to next message
Hi Edward,
thank you very much for your post.
As I tried to dig deeper, I could reduce the problem so far, by going through your list backwards:
If I use the Ecore files produced from the XSD2Ecore importer, and create a dynamic instance, I already get the problem. The resulting XMI file does not contain the namespace information I need.
So, it's not a M2M problem and I am in the wrong forum to begin with. It's an Ecore problem.
But I begin to wonder if it is even possible to create an XMI file (via dynamic instances out of one Ecore file) that contains references using namespaces to another Ecore.
I.e. my question is on how to create something like:
 <AAA:something_from_AAA name="xxx" />
I went through the options for exporting (like OPTION_USE_ENCODED_ATTRIBUTE_STYLE) and I could not make it work.
What would be the correct way? Can someone help me?
(Should I repost this in the Ecore forum? Such a behaviour is frowned upon in some forums ...)
Best regards, Daniel
Edward Willink wrote on Mon, 17 October 2011 12:17
Hi Daniel
a) XSD2Ecore
b) Ecore2Ecore
c) Ecore2XSD
Ed Willink
> Hello,
> from an xsd file).
> importer?
> Best regards,
> Daniel
Re: [QVTo] Generate XMI with multiple namespaces [message #742564 is a reply to message #742446] Thu, 20 October 2011 11:59 Go to previous message
Hi Daniel
Don't repost.
Post a new message focussed on your XSD2Ecore problem.
There are many powerful capabilities very few of which I use since I
regard starting with XSD as like upgrading from COBOL.
Ed Willink
On 20/10/2011 14:55, daniel.engelhardt wrote:
> Hi Edward,
>> Hi Daniel
>> are then used by other tools, so find out which of
>> a) XSD2Ecore
>> b) Ecore2Ecore
>> c) Ecore2XSD
>> Regards
>> Ed Willink
>> > Hello,
>> > I would like to write a QVT transformation in Eclipse Indigo that >
>> generated > from an xsd file).
>> > I have two Output Meta-Models, Out_includes_A.ecore and >
>> more > precise Out_includes_A includes Out_included_B.
>> > In the Ecore models, I could deal with these references either by >
>> implementing Attributes of type AnySimpleType or something, or by >
>> go > with the second option, which might be wrong already.
>> model > (out.xmi) something like
>> > However, that's not what I get. Instead, the second namespace is >
>> > where BBBsomething_from_BBB was the name given to the reference >
>> Element in the node-part of the AAA-Input Meta-Model. The Extended >
>> behavour I > want? My problem is, I don't really know where to start.
>> Is it an > Ecore Problem? Should I somehow try to combine both output
>> metamodels > into one? Should I use AnyType-based solutions? Or are
>> my Extended > Meta Data references broken? Or should I go about my
>> QVT > transformation in a different way? Or is it a problem with the
>> xsd > importer?
>> > I have worked with all of these tools quite a lot, but my >
>> appreciated!
>> > Best regards,
>> > Daniel
Previous Topic:[ATL]: a target model inconsistant with it's metamodel
Next Topic:Match with abstract Classes
Current Time: Mon Mar 24 12:03:45 EDT 2025
Powered by FUDForum. Page generated in 0.03660 seconds
