Re: Cloning job gets stuck [message #738017 is a reply to message #737975] |
Sat, 15 October 2011 18:34 |
Am 15.10.2011 18:41, schrieb Eike Stepper:
> Do I have to repeat 7.6923 times?
Jokes aside, repeating the same exercise always freezes at 27%.
One thing I've noticed when using a command line tool for cloning is that the Git objects that are received at 27% seem
to be quite large. The command line tool shows the total received bytes and I can see constant progress. but this
progress does not have a big impact on the number of received objects. Not enough to impact the percent value of the
reported progress.
To really be able to notice a freeze (a bug or network issue) as opposed to receiving large objects it would be helpful
to display the display the size of the received objects in the job's task message.
Please note that in my case it really freezes at 27% and I don't seem to have other network issues.
Cheers
/Eike
http://www.esc-net.de
Cheers
/Eike
Re: Cloning job gets stuck [message #749483 is a reply to message #748715] |
Tue, 25 October 2011 08:42 |
Hi Matthias,
Comments below...
Am 24.10.2011 23:24, schrieb Matthias Sohn:
> Are you trying to spam this forum ?
No.
> Why do you post 27 copies of the same question ?
I didn't. I only see now that the ultra cool Eclipse forum software (which personally I never use) has gone mad again. I
just submitted https://bugs.eclipse.org/bugs/show_bug.cgi?id=361893
> Also your post contains quite a number of HTML tags I don't like to parse.
Again, only in the web forum (which I did not use). In fact I embedded some screenshots to make it easier for you to
understand my EGit problem.
> Which version of EGit are you using ?
1.1.0.201109151100-r
> Which repository are you trying to clone here ?
The image I embedded into my original posts would have clarified that. The problem occurs randomly (maybe in 1 of 4
cases, sometimes more often, sometimes less) with any of these repos: http://git.eclipse.org/c/cdo . All my
committershave struggled with this until they reverted to using a command line git tool.
> Do you have enough free heap when the clone stalls ?
I'm starting Eclipse with 2.5 gigabytes heap size and usually I have arund 2.0 gigabytes of them available (according to
the heap size trim).
> Check with VisualVM or some similar tool.
Sorry, that's beyond my capabilities and resources. The error log at least did not reveal a heap problem (or any other
problem).
Cheers
/Eike
Cheers
/Eike
Re: Cloning job gets stuck [message #755157 is a reply to message #755155] |
Mon, 07 November 2011 14:59 |
Matthias Sohn Messages: 1268 Registered: July 2009 |
sligthyl tweaked version of the mentioned script:
#!/bin/bash
# Shows you the largest objects in your repo's pack file.
# usage:
# $ git gc # first run gc to move all data to packs
# $ git-find-big-blobs 100 # find and list biggest 100 objects
# derived from
# http://stubbisms.wordpress.com/2009/07/10/git-script-to-show-largest-pack-objects-and-trim-your-waist-line/
# set the internal field spereator to line break, so that we can iterate easily over the verify-pack output
IFS=$'\n';
# list all objects including their size, sort by size, take top $1 biggest blobs
objects=`git verify-pack -v .git/objects/pack/pack-*.idx | grep -v chain | sort -k3nr | head -n $1`
echo "All sizes are in kB's. The pack column is the size of the object, compressed, inside the pack file."
output="size,pack,SHA,location"
for y in $objects
do
# extract the size in bytes
size=$((`echo $y | cut -f 5 -d ' '`/1024))
# extract the compressed size in bytes
compressedSize=$((`echo $y | cut -f 6 -d ' '`/1024))
# extract the SHA
sha=`echo $y | cut -f 1 -d ' '`
# find the objects location in the repository tree
other=`git rev-list --all --objects | grep $sha`
#lineBreak=`echo -e "\n"`
output="${output}\n${size},${compressedSize},${other}"
done
echo -e $output | column -t -s ', '
Re: Cloning job gets stuck [message #755223 is a reply to message #755157] |
Mon, 07 November 2011 18:05 |
Hi Matthias,
Thanks a lot!! The script outputs an error:
estepper/bin/git-find-big-blobs: line 21: /1024: syntax error: operand expected (error token is "/1024")
nevertheless it outputs the 100 biggest objects. I'll discuss with my team if and how we can remove some of them. Thanks
again ;-)
Cheers
/Eike
Am 07.11.2011 15:59, schrieb Matthias Sohn:
> #!/bin/bash
> # usage:
> # derived from
> IFS=$'\n';
> for y in $objects
> do
> # extract the SHA
> done
Cheers
/Eike
FUDForum. Page generated in 0.05813 seconds
