StackOverflowError [message #737680] |
Sat, 15 October 2011 09:46 |
My Hudson build started to fail with StackOverflowErrors, see
https://hudson.eclipse.org/hudson/job/emf-cdo-integration/1902/console :
[echo] Installing buckminster
[java] Installing org.eclipse.buckminster.cmdline.product 1.4.0.v20110910-0906.
[java] Installing org.eclipse.buckminster.core.headless.feature.feature.group 1.4.0.v20110915-1108.
[java] Installing org.eclipse.buckminster.pde.headless.feature.feature.group 1.4.0.v20110910-0906.
[java] Installing org.eclipse.buckminster.git.headless.feature.feature.group 1.4.0.v20110910-0810.
[java] Operation completed in 23969 ms.
*provision*:
[echo] Importing projects into /opt/users/hudsonbuild/.hudson/jobs/emf-cdo-integration/workspace/result/ws
[echo] Importing binaries into /opt/users/hudsonbuild/.hudson/jobs/emf-cdo-integration/workspace/result/tp
[mkdir] Created dir: /opt/users/hudsonbuild/.hudson/jobs/emf-cdo-integration/workspace/result/tp
[java] import '-P' '/opt/users/hudsonbuild/.hudson/jobs/emf-cdo-integration/workspace/result/buckminster.properties' '-B' '/opt/users/hudsonbuild/.hudson/jobs/emf-cdo-integration/workspace/bom.xml' '-P' '/opt/public/jobs/emf-cdo-integration/workspace/git/plugins/org.eclipse.emf.cdo.releng/build.properties' '/opt/public/jobs/emf-cdo-integration/workspace/git/plugins/org.eclipse.emf.cdo.releng/build.mspec'
[java] Platform install location: /opt/public/jobs/emf-cdo-integration/workspace/tools/buckminster
[java] Target platform provided by class org.eclipse.buckminster.pde.internal.PDETargetPlatform
[java] org.eclipse.emf.cdo.releng:osgi.bundle: Using resolver rmap
[java] org.eclipse.emf.cdo.releng:osgi.bundle: Using resolver Local resolver
[java] org.eclipse.emf.cdo.releng:osgi.bundle: Trying provider local(materialized)
[java] No materialization found for org.eclipse.emf.cdo.releng:osgi.bundle
[java] org.eclipse.emf.cdo.releng:osgi.bundle: Trying provider local(workspace)
[java] No open workspace project found that corresponds to org.eclipse.emf.cdo.releng:osgi.bundle
[java] org.eclipse.emf.cdo.releng:osgi.bundle: Rejecting provider local(target): Target platform disabled in query
[java] org.eclipse.emf.cdo.releng:osgi.bundle: Using resource map file:/opt/public/jobs/emf-cdo-integration/workspace/git/plugins/org.eclipse.emf.cdo.releng/build.rmap
[java] ERROR [0001] : java.lang.StackOverflowError
[java] INFO: TAG-ID 0001 = Query for org.eclipse.emf.cdo.releng:osgi.bundle
[java]
[java] Doing full workspace refresh
[java] Waiting for jobs to end
BUILD FAILED
/opt/public/jobs/emf-cdo-integration/workspace/git/plugins/org.eclipse.emf.cdo.releng/build.xml:429: The following error occurred while executing this line:
/opt/public/jobs/emf-cdo-integration/workspace/git/plugins/org.eclipse.emf.cdo.releng/build.xml:55: The following error occurred while executing this line:
/opt/public/jobs/emf-cdo-integration/workspace/git/plugins/org.eclipse.emf.cdo.releng/build.xml:40: Java returned: 1
The workspace log does not contain a stack trace:
https://hudson.eclipse.org/hudson/job/emf-cdo-integration/ws/result/ws/.metadata/.log
Cheers
/Eike
http://www.esc-net.de
Cheers
/Eike
Re: StackOverflowError [message #737748 is a reply to message #737680] |
Sat, 15 October 2011 11:45 |
You get an overflow just after opening the rmap. Could it be that you
somehow pass a property that is self referencing?
- thomas
On 2011-10-15 11:46, Eike Stepper wrote:
> [java] Installing
> [java] Installing
> [java] Installing
> *provision*:
> [java] import '-P'
> '-B'
> '-P'
> resolver
> local(materialized)
> local(workspace)
> [java]
> BUILD FAILED
> Java returned: 1
> Cheers
> /Eike
> http://thegordian.blogspot.com
> http://twitter.com/eikestepper
Re: StackOverflowError [message #737848 is a reply to message #737748] |
Sat, 15 October 2011 14:31 |
Am 15.10.2011 13:45, schrieb Thomas Hallgren:
> You get an overflow just after opening the rmap. Could it be that you somehow pass a property that is self referencing?
With your hint I could find it:
<jvmarg value="-Dgit.repository=${git.repository}" />
Now it works again. Thanks!!
Cheers
/Eike
> - thomas
>> [java] Installing
>> [java] Installing
>> [java] Installing
>> *provision*:
>> [java] import '-P'
>> '-B'
>> '-P'
>> resolver
>> local(materialized)
>> local(workspace)
>> [java]
>> BUILD FAILED
>> Java returned: 1
>> Cheers
>> /Eike
Cheers
/Eike
FUDForum. Page generated in 0.03712 seconds
