Home » Eclipse Projects » Virgo » PAR project compiler error in virgo
PAR project compiler error in virgo [message #737662] Sat, 15 October 2011 05:16 Go to next message
Dear professionals,
Still now i am using virgo server and osgi framework using my project, iwas almost finish my project but i need par project, i have create par project then config the osgi bundle java/web project then actually run on application server for virgo but i getting error for below that.
ERROR for virgo console:
Installation of par 'sample-par' version '1.0.0' failed. java.lang.UnsupportedOperationException: Cannot open an input stream for '/home/osgi/server/virgo-web-server-2.1.0.RELEASE/work/org.eclipse.virgo.kernel.deployer_2.1.0.RELEASE/staging/global/bundle/sample-web/0.0.0/sample-web.war/META-INF/MANIFEST.MF' as it does not exist
Install failed for bundle 'sample-par-1-sampledmservice-dm' version '0.0.0'.
Please help me.
[Updated on: Sat, 15 October 2011 05:17] by Moderator
Re: PAR project compiler error in virgo [message #739208 is a reply to message #737662] Mon, 17 October 2011 04:01 Go to previous messageGo to next message
Please could you post the full exception stack trace?
Re: PAR project compiler error in virgo [message #740028 is a reply to message #739208] Tue, 18 October 2011 00:39 Go to previous messageGo to next message
This is my full error report from virgo server:
[2011-10-18 09:52:10.354] startup-tracker <KE0001I> Kernel starting.
[2011-10-18 09:52:14.872] startup-tracker <KE0002I> Kernel started.
[2011-10-18 09:52:15.069] system-artifacts <DE0000I> Installing plan 'org.eclipse.virgo.kernel.userregion.springdm' version '2.1.0'.
[2011-10-18 09:52:15.206] system-artifacts <DE0000I> Installing bundle 'org.springframework.osgi.core' version '1.2.1'.
[2011-10-18 09:52:15.250] system-artifacts <DE0000I> Installing bundle 'org.springframework.osgi.extender' version '1.2.1'.
[2011-10-18 09:52:15.259] system-artifacts <DE0000I> Installing bundle 'org.springframework.osgi.io' version '1.2.1'.
[2011-10-18 09:52:15.279] system-artifacts <DE0000I> Installing bundle 'org.eclipse.virgo.kernel.agent.dm' version '2.1.0.RELEASE'.
[2011-10-18 09:52:15.295] system-artifacts <DE0000I> Installing bundle 'org.eclipse.virgo.kernel.deployer.dm' version '2.1.0.RELEASE'.
[2011-10-18 09:52:16.667] system-artifacts <DE0001I> Installed bundle 'org.springframework.osgi.core' version '1.2.1'.
[2011-10-18 09:52:16.672] system-artifacts <DE0001I> Installed bundle 'org.springframework.osgi.extender' version '1.2.1'.
[2011-10-18 09:52:16.675] system-artifacts <DE0001I> Installed bundle 'org.springframework.osgi.io' version '1.2.1'.
[2011-10-18 09:52:16.679] system-artifacts <DE0001I> Installed bundle 'org.eclipse.virgo.kernel.agent.dm' version '2.1.0.RELEASE'.
[2011-10-18 09:52:16.683] system-artifacts <DE0001I> Installed bundle 'org.eclipse.virgo.kernel.deployer.dm' version '2.1.0.RELEASE'.
[2011-10-18 09:52:16.686] system-artifacts <DE0001I> Installed plan 'org.eclipse.virgo.kernel.userregion.springdm' version '2.1.0'.
[2011-10-18 09:52:16.707] system-artifacts <DE0004I> Starting plan 'org.eclipse.virgo.kernel.userregion.springdm' version '2.1.0'.
[2011-10-18 09:52:16.716] system-artifacts <DE0004I> Starting bundle 'org.springframework.osgi.core' version '1.2.1'.
[2011-10-18 09:52:16.721] start-signalling-1 <DE0005I> Started bundle 'org.springframework.osgi.core' version '1.2.1'.
[2011-10-18 09:52:16.727] system-artifacts <DE0004I> Starting bundle 'org.springframework.osgi.extender' version '1.2.1'.
[2011-10-18 09:52:17.173] start-signalling-1 <DE0005I> Started bundle 'org.springframework.osgi.extender' version '1.2.1'.
[2011-10-18 09:52:17.178] system-artifacts <DE0004I> Starting bundle 'org.springframework.osgi.io' version '1.2.1'.
[2011-10-18 09:52:17.190] start-signalling-1 <DE0005I> Started bundle 'org.springframework.osgi.io' version '1.2.1'.
[2011-10-18 09:52:17.195] system-artifacts <DE0004I> Starting bundle 'org.eclipse.virgo.kernel.agent.dm' version '2.1.0.RELEASE'.
[2011-10-18 09:52:17.205] start-signalling-1 <DE0005I> Started bundle 'org.eclipse.virgo.kernel.agent.dm' version '2.1.0.RELEASE'.
[2011-10-18 09:52:17.209] system-artifacts <DE0004I> Starting bundle 'org.eclipse.virgo.kernel.deployer.dm' version '2.1.0.RELEASE'.
[2011-10-18 09:52:17.306] start-signalling-1 <DE0005I> Started bundle 'org.eclipse.virgo.kernel.deployer.dm' version '2.1.0.RELEASE'.
[2011-10-18 09:52:17.313] start-signalling-1 <DE0005I> Started plan 'org.eclipse.virgo.kernel.userregion.springdm' version '2.1.0'.
[2011-10-18 09:52:17.393] system-artifacts <DE0000I> Installing plan 'org.eclipse.virgo.web' version '2.1.0'.
[2011-10-18 09:52:17.414] system-artifacts <DE0000I> Installing bundle 'org.eclipse.gemini.web.core' version '1.1.0.RELEASE'.
[2011-10-18 09:52:17.430] system-artifacts <DE0000I> Installing bundle 'org.eclipse.gemini.web.tomcat' version '1.1.0.RELEASE'.
[2011-10-18 09:52:17.448] system-artifacts <DE0000I> Installing bundle 'org.eclipse.virgo.web.core' version '2.1.0.RELEASE'.
[2011-10-18 09:52:17.463] system-artifacts <DE0000I> Installing bundle 'org.eclipse.virgo.web.dm' version '2.1.0.RELEASE'.
[2011-10-18 09:52:17.482] system-artifacts <DE0000I> Installing bundle 'org.eclipse.virgo.web.tomcat' version '2.1.0.RELEASE'.
[2011-10-18 09:52:17.766] system-artifacts <DE0001I> Installed bundle 'org.eclipse.gemini.web.core' version '1.1.0.RELEASE'.
[2011-10-18 09:52:17.770] system-artifacts <DE0001I> Installed bundle 'org.eclipse.gemini.web.tomcat' version '1.1.0.RELEASE'.
[2011-10-18 09:52:17.775] system-artifacts <DE0001I> Installed bundle 'org.eclipse.virgo.web.core' version '2.1.0.RELEASE'.
[2011-10-18 09:52:17.779] system-artifacts <DE0001I> Installed bundle 'org.eclipse.virgo.web.dm' version '2.1.0.RELEASE'.
[2011-10-18 09:52:17.783] system-artifacts <DE0001I> Installed bundle 'org.eclipse.virgo.web.tomcat' version '2.1.0.RELEASE'.
[2011-10-18 09:52:17.787] system-artifacts <DE0001I> Installed plan 'org.eclipse.virgo.web' version '2.1.0'.
[2011-10-18 09:52:17.804] system-artifacts <DE0004I> Starting plan 'org.eclipse.virgo.web' version '2.1.0'.
[2011-10-18 09:52:17.809] system-artifacts <DE0004I> Starting bundle 'org.eclipse.gemini.web.core' version '1.1.0.RELEASE'.
[2011-10-18 09:52:17.835] start-signalling-1 <DE0005I> Started bundle 'org.eclipse.gemini.web.core' version '1.1.0.RELEASE'.
[2011-10-18 09:52:17.839] system-artifacts <DE0004I> Starting bundle 'org.eclipse.gemini.web.tomcat' version '1.1.0.RELEASE'.
[2011-10-18 09:52:18.575] system-artifacts <TC0000I> Starting Tomcat.
[2011-10-18 09:52:18.615] system-artifacts <TC0010I> Creating HTTP/1.1 connector with scheme http on port 9090.
[2011-10-18 09:52:18.629] system-artifacts <TC0010I> Creating HTTP/1.1 connector with scheme https on port 8445.
[2011-10-18 09:52:18.647] system-artifacts <TC0010I> Creating AJP/1.3 connector with scheme http on port 8008.
[2011-10-18 09:52:18.783] system-artifacts <TC0001I> Started Tomcat.
[2011-10-18 09:52:18.801] system-artifacts <DE0004I> Starting bundle 'org.eclipse.virgo.web.core' version '2.1.0.RELEASE'.
[2011-10-18 09:52:18.825] system-artifacts <DE0004I> Starting bundle 'org.eclipse.virgo.web.dm' version '2.1.0.RELEASE'.
[2011-10-18 09:52:18.839] start-signalling-1 <DE0005I> Started bundle 'org.eclipse.virgo.web.dm' version '2.1.0.RELEASE'.
[2011-10-18 09:52:18.860] system-artifacts <DE0005I> Started bundle 'org.eclipse.virgo.web.tomcat' version '2.1.0.RELEASE'.
[2011-10-18 09:52:19.043] start-signalling-1 <DE0005I> Started bundle 'org.eclipse.virgo.web.core' version '2.1.0.RELEASE'.
[2011-10-18 09:52:19.048] start-signalling-1 <DE0005I> Started bundle 'org.eclipse.gemini.web.tomcat' version '1.1.0.RELEASE'.
[2011-10-18 09:52:19.051] start-signalling-1 <DE0005I> Started plan 'org.eclipse.virgo.web' version '2.1.0'.
[2011-10-18 09:52:19.056] Thread-2 <UR0001I> User region ready.
[2011-10-18 09:52:19.151] deployer-recovery <DE0000I> Installing par 'org.eclipse.virgo.apps.repository' version '2.1.0.RELEASE'.
[2011-10-18 09:52:19.157] deployer-recovery <DE0000I> Installing bundle 'org.eclipse.virgo.apps.repository-2.1.0.RELEASE-org.eclipse.virgo.apps.repository.web' version '2.1.0.RELEASE'.
[2011-10-18 09:52:19.162] deployer-recovery <DE0000I> Installing bundle 'org.eclipse.virgo.apps.repository-2.1.0.RELEASE-org.eclipse.virgo.apps.repository.core' version '2.1.0.RELEASE'.
[2011-10-18 09:52:19.382] deployer-recovery <DE0001I> Installed bundle 'org.eclipse.virgo.apps.repository-2.1.0.RELEASE-org.eclipse.virgo.apps.repository.web' version '2.1.0.RELEASE'.
[2011-10-18 09:52:19.386] deployer-recovery <DE0001I> Installed bundle 'org.eclipse.virgo.apps.repository-2.1.0.RELEASE-org.eclipse.virgo.apps.repository.core' version '2.1.0.RELEASE'.
[2011-10-18 09:52:19.390] deployer-recovery <DE0001I> Installed bundle 'org.eclipse.virgo.apps.repository-2.1.0.RELEASE-synthetic.context' version '2.1.0.RELEASE'.
[2011-10-18 09:52:19.394] deployer-recovery <DE0001I> Installed par 'org.eclipse.virgo.apps.repository' version '2.1.0.RELEASE'.
[2011-10-18 09:52:19.414] deployer-recovery <DE0004I> Starting par 'org.eclipse.virgo.apps.repository' version '2.1.0.RELEASE'.
[2011-10-18 09:52:19.454] deployer-recovery <DE0004I> Starting bundle 'org.eclipse.virgo.apps.repository-2.1.0.RELEASE-org.eclipse.virgo.apps.repository.web' version '2.1.0.RELEASE'.
[2011-10-18 09:52:19.495] Thread-3 <WE0000I> Starting web bundle 'org.eclipse.virgo.apps.repository-2.1.0.RELEASE-org.eclipse.virgo.apps.repository.web' version '2.1.0.RELEASE' with context path '/org.eclipse.virgo.apps.repository'.
[2011-10-18 09:52:19.550] deployer-recovery <DE0004I> Starting bundle 'org.eclipse.virgo.apps.repository-2.1.0.RELEASE-org.eclipse.virgo.apps.repository.core' version '2.1.0.RELEASE'.
[2011-10-18 09:52:19.569] deployer-recovery <DE0004I> Starting bundle 'org.eclipse.virgo.apps.repository-2.1.0.RELEASE-synthetic.context' version '2.1.0.RELEASE'.
[2011-10-18 09:52:19.668] start-signalling-2 <DE0005I> Started bundle 'org.eclipse.virgo.apps.repository-2.1.0.RELEASE-synthetic.context' version '2.1.0.RELEASE'.
[2011-10-18 09:52:19.852] deployer-recovery <DE0000I> Installing plan 'org.eclipse.virgo.apps.admin.plan' version '2.1.0'.
[2011-10-18 09:52:19.931] deployer-recovery <DE0000I> Installing bundle 'org.eclipse.virgo.apps.admin.core' version '2.1.0.RELEASE'.
[2011-10-18 09:52:20.271] start-signalling-2 <DE0005I> Started bundle 'org.eclipse.virgo.apps.repository-2.1.0.RELEASE-org.eclipse.virgo.apps.repository.core' version '2.1.0.RELEASE'.
[2011-10-18 09:52:20.653] deployer-recovery <DE0000I> Installing bundle 'org.eclipse.virgo.apps.admin.web' version '2.1.0.RELEASE'.
[2011-10-18 09:52:21.068] deployer-recovery <DE0001I> Installed bundle 'org.eclipse.virgo.apps.admin.core' version '2.1.0.RELEASE'.
[2011-10-18 09:52:21.074] deployer-recovery <DE0001I> Installed bundle 'org.eclipse.virgo.apps.admin.web' version '2.1.0.RELEASE'.
[2011-10-18 09:52:21.079] deployer-recovery <DE0001I> Installed plan 'org.eclipse.virgo.apps.admin.plan' version '2.1.0'.
[2011-10-18 09:52:21.089] deployer-recovery <DE0004I> Starting plan 'org.eclipse.virgo.apps.admin.plan' version '2.1.0'.
[2011-10-18 09:52:21.124] deployer-recovery <DE0004I> Starting bundle 'org.eclipse.virgo.apps.admin.core' version '2.1.0.RELEASE'.
[2011-10-18 09:52:21.140] deployer-recovery <DE0004I> Starting bundle 'org.eclipse.virgo.apps.admin.web' version '2.1.0.RELEASE'.
[2011-10-18 09:52:21.148] Thread-3 <WE0000I> Starting web bundle 'org.eclipse.virgo.apps.admin.web' version '2.1.0.RELEASE' with context path '/admin'.
[2011-10-18 09:52:21.342] deployer-recovery <DE0000I> Installing bundle 'org.eclipse.virgo.apps.splash' version '2.1.0.RELEASE'.
[2011-10-18 09:52:21.404] Thread-3 <WE0001I> Started web bundle 'org.eclipse.virgo.apps.repository-2.1.0.RELEASE-org.eclipse.virgo.apps.repository.web' version '2.1.0.RELEASE' with context path '/org.eclipse.virgo.apps.repository'.
[2011-10-18 09:52:21.412] start-signalling-1 <DE0005I> Started bundle 'org.eclipse.virgo.apps.repository-2.1.0.RELEASE-org.eclipse.virgo.apps.repository.web' version '2.1.0.RELEASE'.
[2011-10-18 09:52:21.416] start-signalling-1 <DE0005I> Started par 'org.eclipse.virgo.apps.repository' version '2.1.0.RELEASE'.
[2011-10-18 09:52:21.509] deployer-recovery <DE0001I> Installed bundle 'org.eclipse.virgo.apps.splash' version '2.1.0.RELEASE'.
[2011-10-18 09:52:21.543] start-signalling-1 <DE0005I> Started bundle 'org.eclipse.virgo.apps.admin.core' version '2.1.0.RELEASE'.
[2011-10-18 09:52:21.580] deployer-recovery <DE0004I> Starting bundle 'org.eclipse.virgo.apps.splash' version '2.1.0.RELEASE'.
[2011-10-18 09:52:21.604] Thread-3 <WE0000I> Starting web bundle 'org.eclipse.virgo.apps.splash' version '2.1.0.RELEASE' with context path '/'.
[2011-10-18 09:52:21.887] Thread-3 <WE0001I> Started web bundle 'org.eclipse.virgo.apps.admin.web' version '2.1.0.RELEASE' with context path '/admin'.
[2011-10-18 09:52:21.889] start-signalling-2 <DE0005I> Started bundle 'org.eclipse.virgo.apps.admin.web' version '2.1.0.RELEASE'.
[2011-10-18 09:52:21.893] start-signalling-2 <DE0005I> Started plan 'org.eclipse.virgo.apps.admin.plan' version '2.1.0'.
[2011-10-18 09:52:21.988] Thread-3 <WE0001I> Started web bundle 'org.eclipse.virgo.apps.splash' version '2.1.0.RELEASE' with context path '/'.
[2011-10-18 09:52:21.995] start-signalling-1 <DE0005I> Started bundle 'org.eclipse.virgo.apps.splash' version '2.1.0.RELEASE'.
[2011-10-18 09:52:22.635] fs-watcher <HD0001I> Hot deployer processing 'INITIAL' event for file 'org.eclipse.virgo.apps.repository-2.1.0.RELEASE.par'.
[2011-10-18 09:52:23.292] TCP Connection(2)-127.0.0.1 <DE0000I> Installing par 'cashmiddletier-par' version '1.0.0'.
[2011-10-18 09:52:23.296] TCP Connection(2)-127.0.0.1 <DE0000I> Installing bundle 'cashmiddletier-par-1-cashmiddletierservice-dm' version '0.0.0'.
[2011-10-18 09:52:23.314] TCP Connection(2)-127.0.0.1 <DE0000I> Installing bundle 'cashmiddletier-web' version '0.0.0'.
[2011-10-18 09:52:27.205] TCP Connection(2)-127.0.0.1 <ME0003I> Dump 'serviceability/dump/2011-10-18-09-52-321' generated
[2011-10-18 09:52:27.211] TCP Connection(2)-127.0.0.1 <DE0002E> Installation of par 'cashmiddletier-par' version '1.0.0' failed. java.lang.UnsupportedOperationException: Cannot open an input stream for '/home/novabit/server/virgo-web-server-2.1.0.RELEASE/work/org.eclipse.virgo.kernel.deployer_2.1.0.RELEASE/staging/samplemiddletier-par-1/bundle/cashmiddletier-par-1-cashmiddletierservice-dm/0.0.0/samplemiddletierservice-dm.jar/META-INF/MANIFEST.MF' as it does not exist
at org.eclipse.virgo.kernel.artifact.fs.internal.FileArtifactFSEntry.getInputStream(FileArtifactFSEntry.java:59)
at org.eclipse.virgo.kernel.install.artifact.internal.ServiceScoper.loadManifest(ServiceScoper.java:186)
at org.eclipse.virgo.kernel.install.artifact.internal.ServiceScoper.loadBundleManifests(ServiceScoper.java:175)
at org.eclipse.virgo.kernel.install.artifact.internal.ServiceScoper.doScope(ServiceScoper.java:156)
at org.eclipse.virgo.kernel.install.artifact.internal.ServiceScoper.scope(ServiceScoper.java:88)
at org.eclipse.virgo.kernel.install.artifact.internal.PlanScoper.scope(PlanScoper.java:137)
at org.eclipse.virgo.kernel.install.artifact.internal.StandardPlanInstallArtifact.scope(StandardPlanInstallArtifact.java:175)
at org.eclipse.virgo.kernel.install.pipeline.stage.transform.internal.ScopingTransformer.processScopedPlanInstallArtifact(ScopingTransformer.java:50)
at org.eclipse.virgo.kernel.install.pipeline.stage.transform.internal.ScopedPlanIdentifyingTreeVisitor.visit(ScopedPlanIdentifyingTreeVisitor.java:32)
at org.eclipse.virgo.util.common.ThreadSafeArrayListTree.visit(ThreadSafeArrayListTree.java:165)
at org.eclipse.virgo.kernel.install.pipeline.stage.transform.internal.ScopingTransformer.transform(ScopingTransformer.java:41)
at org.eclipse.virgo.kernel.install.pipeline.stage.transform.internal.TransformationStage.doProcessTree(TransformationStage.java:55)
at org.eclipse.virgo.kernel.install.pipeline.stage.AbstractPipelineStage.process(AbstractPipelineStage.java:41)
at org.eclipse.virgo.kernel.install.pipeline.internal.StandardPipeline.doProcessTree(StandardPipeline.java:62)
at org.eclipse.virgo.kernel.install.pipeline.internal.CompensatingPipeline.doProcessTree(CompensatingPipeline.java:72)
at org.eclipse.virgo.kernel.deployer.core.internal.PipelinedApplicationDeployer.driveInstallPipeline(PipelinedApplicationDeployer.java:271)
at org.eclipse.virgo.kernel.deployer.core.internal.PipelinedApplicationDeployer.doInstall(PipelinedApplicationDeployer.java:151)
at org.eclipse.virgo.kernel.deployer.core.internal.PipelinedApplicationDeployer.install(PipelinedApplicationDeployer.java:123)
at org.eclipse.virgo.kernel.deployer.core.internal.PipelinedApplicationDeployer.deploy(PipelinedApplicationDeployer.java:190)
at org.eclipse.virgo.kernel.deployer.management.StandardDeployer.deploy(StandardDeployer.java:52)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at com.sun.jmx.mbeanserver.ConvertingMethod.invokeWithOpenReturn(ConvertingMethod.java:167)
at com.sun.jmx.mbeanserver.MXBeanIntrospector.invokeM2(MXBeanIntrospector.java:96)
at com.sun.jmx.mbeanserver.MXBeanIntrospector.invokeM2(MXBeanIntrospector.java:33)
at com.sun.jmx.mbeanserver.MBeanIntrospector.invokeM(MBeanIntrospector.java:208)
at com.sun.jmx.mbeanserver.PerInterface.invoke(PerInterface.java:120)
at com.sun.jmx.mbeanserver.MBeanSupport.invoke(MBeanSupport.java:262)
at com.sun.jmx.interceptor.DefaultMBeanServerInterceptor.invoke(DefaultMBeanServerInterceptor.java:836)
at com.sun.jmx.mbeanserver.JmxMBeanServer.invoke(JmxMBeanServer.java:761)
at javax.management.remote.rmi.RMIConnectionImpl.doOperation(RMIConnectionImpl.java:1427)
at javax.management.remote.rmi.RMIConnectionImpl.access$200(RMIConnectionImpl.java:72)
at javax.management.remote.rmi.RMIConnectionImpl$PrivilegedOperation.run(RMIConnectionImpl.java:1265)
at javax.management.remote.rmi.RMIConnectionImpl.doPrivilegedOperation(RMIConnectionImpl.java:1360)
at javax.management.remote.rmi.RMIConnectionImpl.invoke(RMIConnectionImpl.java:788)
at sun.rmi.server.UnicastServerRef.dispatch(UnicastServerRef.java:305)
at sun.rmi.transport.Transport$1.run(Transport.java:159)
at sun.rmi.transport.Transport.serviceCall(Transport.java:155)
at sun.rmi.transport.tcp.TCPTransport.handleMessages(TCPTransport.java:535)
at sun.rmi.transport.tcp.TCPTransport$ConnectionHandler.run0(TCPTransport.java:790)
at sun.rmi.transport.tcp.TCPTransport$ConnectionHandler.run(TCPTransport.java:649)
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908)
at java.lang.Thread.run(Thread.java:619)
[2011-10-18 09:52:27.218] TCP Connection(2)-127.0.0.1 <DE0003E> Install failed for bundle 'samplemiddletier-par-1-samplemiddletierservice-dm' version '0.0.0'.
[2011-10-18 09:52:27.222] TCP Connection(2)-127.0.0.1 <DE0003E> Install failed for bundle 'samplemiddletier-web' version '0.0.0'.
[2011-10-18 09:52:27.226] TCP Connection(2)-127.0.0.1 <DE0003E> Install failed for par 'cashmiddletier-par' version '1.0.0'.
[2011-10-18 09:52:27.230] fs-watcher <HD0005I> Hot deploy not performed because file 'org.eclipse.virgo.apps.repository-2.1.0.RELEASE.par' is already deployed.
[2011-10-18 09:52:27.234] fs-watcher <HD0001I> Hot deployer processing 'INITIAL' event for file 'org.eclipse.virgo.apps.admin-2.1.0.RELEASE.plan'.
[2011-10-18 09:52:27.239] fs-watcher <HD0005I> Hot deploy not performed because file 'org.eclipse.virgo.apps.admin-2.1.0.RELEASE.plan' is already deployed.
[2011-10-18 09:52:27.244] fs-watcher <HD0001I> Hot deployer processing 'INITIAL' event for file 'org.eclipse.virgo.apps.splash-2.1.0.RELEASE.war'.
[2011-10-18 09:52:27.248] fs-watcher <HD0005I> Hot deploy not performed because file 'org.eclipse.virgo.apps.splash-2.1.0.RELEASE.war' is already deployed.
Re: PAR project compiler error in virgo [message #740272 is a reply to message #740028] Tue, 18 October 2011 06:30 Go to previous messageGo to next message
It looks like one of the bundles inside the PAR has no manifest. You could crack the PAR and its bundles open manually to check this.
Re: PAR project compiler error in virgo [message #741029 is a reply to message #740272] Wed, 19 October 2011 01:37 Go to previous messageGo to next message
Thanks you for valuable time spend me,
another one doubt me, manifest file means PAR project manifest file? or dependence project MF file? which one i check that? please help me.
My PAR Manifest file below that is it right?
Manifest-Version: 1.0
Application-Name: samplemiddletier-par
Application-Description: samplemiddletier-par
Application-Version: 1.0.0
Application-SymbolicName: samplemiddletier-par
and add bundle dependencies 1.sampledmservice
2.sample-web
another doubt : I have export the PAR file, which one location i put par file for virgo server still now i am putting the par file in stage folder is it right?
for example Export PAR file--> copy to paste virgo server STAGE folder
Re: PAR project compiler error in virgo [message #742362 is a reply to message #741029] Thu, 20 October 2011 08:30 Go to previous messageGo to next message
* please any body professional help me i am using virgo server i was create par project then export par file, still did not run the project.
* another one doubt for export the par file which one place i put the par jar file in virgo server, now i was putting for stage folder it's right way?
Please help me.
Re: PAR project compiler error in virgo [message #747846 is a reply to message #742362] Mon, 24 October 2011 06:13 Go to previous messageGo to next message
You can export the PAR file and then copy it to Virgo's pickup directory or drag the PAR project to the Virgo server under Eclipse.
(Sorry for the delayed response, I forgot to subscribe to this thread.)
Re: PAR project compiler error in virgo [message #753616 is a reply to message #747846] Fri, 28 October 2011 01:02 Go to previous messageGo to next message
Hello friends,
Did you give the tips i have follow my project,I try to export par file and put in pickup directory. But i got same error. whereas i getting another one error some time i deployed in par file did not error thrown in console then i go to see log file in virgo server i got the error for SCOPE NULL what can i do. please kindly help me.
my project environment : Linux Kubuntu OS
Re: PAR project compiler error in virgo [message #754771 is a reply to message #740272] Fri, 04 November 2011 05:40 Go to previous messageGo to next message
I check the export par file then extract the par file, having META-INF and com.osgiservice.jar file this is correct?. I think web project war file does not have in par file because I look the stage folder in virgo runtime create par folder and open the that folder i see the war and jar file here so my mistake is export and generate par file. how can i solve the problem.
please any suggestion let me know. ASAP
[Updated on: Fri, 04 November 2011 05:42] by Moderator
Re: PAR project compiler error in virgo [message #755490 is a reply to message #754771] Tue, 08 November 2011 11:18 Go to previous messageGo to next message
This sounds like a bug in the tooling. You might have to export the jar and war files separately and then use the 'jar' command to package up a par file on the command line. Alternatively, just have an external build, something like Ant that will do it for you. This is what we use.
Chris.
Re: PAR project compiler error in virgo [message #869289 is a reply to message #755490] Thu, 03 May 2012 03:24 Go to previous message
now i am using maven project how can i build par project.
Previous Topic:Virgo 3.5.0.M04 released
Next Topic:Bundle refresh in virgo 3.0.2
Current Time: Thu Nov 06 22:45:16 EST 2025
Powered by FUDForum. Page generated in 0.05388 seconds
