PDT 2.0 performance issues (bug #240826) [message #79682] |
Sun, 07 September 2008 12:23 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: michael.zend.com
Hi All,
I'm appealing to the people that experience performance issues in PDT 2.0
(see bug #240826), especially when working in PHP editor.
I'm looking for a real PHP application available for download that can be
used for reproduction of this bug. Some comments in this bug
page say that this problem persists in projects with more than 5000 PHP
files. I've tried to achieve such a project using replication of
Drupal framework 120 times within same project (which produces about 8000
PHP files), but this test does not appear to be objective enough,
since every function, classs and method ends up being declared in multiple
files, and this produces some kind of bottle-neck while looking
for PHP elements matches.
Does anybody experience this bug on some open source PHP framework that
contains many PHP files?
Solving performance problem is crucial for PDT 2.0 users at this point, so
let's do it ASAP!
Thanks!
Re: PDT 2.0 performance issues (bug #240826) [message #79697 is a reply to message #79682] |
Mon, 08 September 2008 09:50 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: kkunjas.gmail.com
Na Sun, 07 Sep 2008 15:23:08 +0300, Michael Spector napisao:
> Hi All,
cut
i have those issues. i mainly work with symfony ( symfony-project.org )
kreso@deressh:~/workspace/uber$ ls -1 -R |wc -l
5091
kreso@deressh:~/workspace/uber$ ls -1 -R /usr/share/php/symfony/ |wc -l
2627
kreso@deressh:~/workspace/uber$ ls -1 -R /usr/share/php/data/symfony/ |wc -
l
186
this is a project i'm currently working and it has around 8000 files
( some of those are resources, but mostly are php files )
symfony framework is listed as include path
when using auto activation of code completition it takes around 10 sec
(cpu usage goes to 100% and disk activity is increased also ) to get any
response from editor (so i turned autoactivation off).
when completing already started phrase it works ok ( some little delay but
it's bearable 0.5-1 sec)
im using latest dltk and pdt build with eclipse 3.4 on 1.6 java OS: ubuntu
8.04
if you need some additional info, just ask
Re: PDT 2.0 performance issues (bug #240826) [message #79712 is a reply to message #79697] |
Mon, 08 September 2008 18:05 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: codeslave.ca.ibm.com
Please post your feedback in Bugzilla (#240826) so that the devs can
track (and be accountable to) these problems.
>> Hi All,
> cut
> 5091
> 2627
> l
> 186
> 8.04
Re: PDT 2.0 performance issues (bug #240826) [message #79742 is a reply to message #79682] |
Tue, 09 September 2008 13:14 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Hi All,
There is new hightly build, which has many improvements regarding this
issue:
http://download.eclipse.org/tools/pdt/downloads/release.php? release=N20080909
I encourage anybody who encounters this bug to use this update.
Please report your feedbacks to: http://bugs.eclipse.org/240826.
Thanks!
"Michael Spector" <michael@zend.com> wrote in message
news:ga0h17$ieq$1@build.eclipse.org...
> Hi All,
> let's do it ASAP!
> Thanks!
Re: PDT 2.0 performance issues (bug #240826) [message #80606 is a reply to message #79742] |
Wed, 24 September 2008 14:43 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Marko Karjalainen![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=markokarjalainen%40kolumbus.fi) Messages: 30 Registered: July 2009 |
Member |
Hi there,
I tested some file editing with I20080917 yesterday on my project and it seems to work.
Project explorer and Php explorer is still unusable, when open folders or right click folder.
On 9.9.2008 16:14, Michael Spector wrote:
> Hi All,
> issue:
> Thanks!
>> Hi All,
>> 2.0 (see bug #240826), especially when working in PHP editor.
>> be used for reproduction of this bug. Some comments in this bug
>> PHP files. I've tried to achieve such a project using replication of
>> 8000 PHP files), but this test does not appear to be objective enough,
>> multiple files, and this produces some kind of bottle-neck while looking
>> that contains many PHP files?
>> point, so let's do it ASAP!
>> Thanks!
FUDForum. Page generated in 0.03457 seconds
