Could not initialize class org.eclipse.xsd.XS [message #735405] |
Tue, 11 October 2011 17:08 |
David Messages: 1 Registered: October 2011 |
When I try to open an xsd file in Eclipse, I am getting the error
"An error has occurred. See error log for more details. Could not initialize class org.eclipse.xsd.XSDPackage$Literals "
I have been working with this file for a few months and have not had any issues previously. Further, I have not made any changes to my system recently. The call stack in the error log is :
!ENTRY org.eclipse.jface 4 2 2011-10-11 10:00:07.590
!MESSAGE Problems occurred when invoking code from plug-in: "org.eclipse.jface".
!STACK 0
java.lang.NoClassDefFoundError: Could not initialize class org.eclipse.xsd.XSDPackage$Literals
at org.eclipse.xsd.impl.XSDSchemaImpl.eStaticClass(XSDSchemaImpl.java:847)
at org.eclipse.emf.ecore.impl.EObjectImpl.eClass(EObjectImpl.java:224)
at org.eclipse.xsd.util.XSDSwitch.doSwitch(XSDSwitch.java:74)
at org.eclipse.wst.xsd.ui.internal.adapters.XSDAdapterFactory.createAdapter(XSDAdapterFactory.java:136)
at org.eclipse.emf.common.notify.impl.AdapterFactoryImpl.createAdapter(AdapterFactoryImpl.java:133)
at org.eclipse.emf.common.notify.impl.AdapterFactoryImpl.adaptNew(AdapterFactoryImpl.java:107)
at org.eclipse.emf.common.notify.impl.AdapterFactoryImpl.adapt(AdapterFactoryImpl.java:93)
at org.eclipse.wst.xsd.ui.internal.adapters.XSDAdapterFactory.adapt(XSDAdapterFactory.java:151)
at org.eclipse.wst.xsd.ui.internal.editor.InternalXSDMultiPageEditor.buildModel(InternalXSDMultiPageEditor.java:247)
at org.eclipse.wst.xsd.ui.internal.adt.editor.ADTMultiPageEditor.createPages(ADTMultiPageEditor.java:168)
at org.eclipse.wst.xsd.ui.internal.editor.InternalXSDMultiPageEditor.createPages(InternalXSDMultiPageEditor.java:567)
at com.genuitec.myeclipse.ui.editors.XSDEditor.createPages(XSDEditor.java:14)
at org.eclipse.ui.part.MultiPageEditorPart.createPartControl(MultiPageEditorPart.java:357)
at org.eclipse.ui.internal.EditorReference.createPartHelper(EditorReference.java:662)
at org.eclipse.ui.internal.EditorReference.createPart(EditorReference.java:462)
at org.eclipse.ui.internal.WorkbenchPartReference.getPart(WorkbenchPartReference.java:595)
at org.eclipse.ui.internal.EditorReference.getEditor(EditorReference.java:286)
at org.eclipse.ui.internal.EditorManager.findEditor(EditorManager.java:403)
at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched(WorkbenchPage.java:2799)
at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(WorkbenchPage.java:2762)
at org.eclipse.ui.internal.WorkbenchPage.access$11(WorkbenchPage.java:2754)
at org.eclipse.ui.internal.WorkbenchPage$10.run(WorkbenchPage.java:2705)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2701)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2685)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2676)
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:651)
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:610)
at org.eclipse.ui.actions.OpenFileAction.openFile(OpenFileAction.java:99)
at org.eclipse.ui.actions.OpenSystemEditorAction.run(OpenSystemEditorAction.java:99)
at org.eclipse.ui.views.navigator.OpenActionGroup.runDefaultAction(OpenActionGroup.java:133)
at org.eclipse.ui.views.navigator.MainActionGroup.runDefaultAction(MainActionGroup.java:330)
at org.eclipse.ui.views.navigator.ResourceNavigator.handleOpen(ResourceNavigator.java:787)
at org.eclipse.ui.views.navigator.ResourceNavigator$6.open(ResourceNavigator.java:499)
at org.eclipse.ui.OpenAndLinkWithEditorHelper$InternalListener.open(OpenAndLinkWithEditorHelper.java:48)
at org.eclipse.jface.viewers.StructuredViewer$2.run(StructuredViewer.java:842)
at org.eclipse.core.runtime.Platform.run(Platform.java:888)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:48)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:175)
at org.eclipse.jface.viewers.StructuredViewer.fireOpen(StructuredViewer.java:840)
at org.eclipse.jface.viewers.StructuredViewer.handleOpen(StructuredViewer.java:1101)
at org.eclipse.jface.viewers.StructuredViewer$6.handleOpen(StructuredViewer.java:1205)
at org.eclipse.jface.util.OpenStrategy.fireOpenEvent(OpenStrategy.java:264)
at org.eclipse.jface.util.OpenStrategy.access$2(OpenStrategy.java:258)
at org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrategy.java:298)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1003)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:3910)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3503)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2405)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2369)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2221)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:500)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:493)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:113)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:194)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:368)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:559)
[Updated on: Tue, 11 October 2011 17:08] Report message to a moderator
FUDForum. Page generated in 0.02416 seconds
