Home » Newcomers » Newcomers » How to stop the debugging JBoss?
How to stop the debugging JBoss? [message #79363] Tue, 21 June 2005 13:17 Go to next message
Originally posted by: diviner_chan.hotmail.com_
Hi all,
After I do starting the JBoss server for debugging, I don't
know how to shut it down. How do I do this?
Thank you very much.
Diviner.
Re: How to stop the debugging JBoss? [message #79408 is a reply to message #79363] Tue, 21 June 2005 14:39 Go to previous messageGo to next message
Originally posted by: daniel.rohe.stud.tu-ilmenau.de
I don't know how you start the JBoss server but I think under Windows you
can terminate the process by pressing CTRL+C in the terminal window.
Daniel
"Diviner" <diviner_chan@hotmail.com_> schrieb im Newsbeitrag
news:d99i35$pv4$1@news.eclipse.org...
> Hi all,
> Best regards,
> Diviner.
Re: How to stop the debugging JBoss? [message #79423 is a reply to message #79408] Tue, 21 June 2005 14:56 Go to previous messageGo to next message
Daniel Rohe,
Starting JBoss in debugging mode by Right Click on Package Explorer ->
Debug -> Debug... -> Select a JBoss configuration item ->
Click Debug button.
No, it can't be shutdown from terminal window because that is nothing
terminal window.
Diviner.
> Daniel
>>Hi all,
>>Best regards,
>>Diviner.
Re: How to stop the debugging JBoss? [message #79537 is a reply to message #79423] Wed, 22 June 2005 01:48 Go to previous messageGo to next message
Originally posted by: eclipse.rizzoweb.com
Diviner wrote:
> Daniel Rohe,
> Click Debug button.
> terminal window.
In the Eclipse Debug view, select the process stack for JBoss and hit
the Stop button in the toolbar (red square icon). That will result in an
ungraceful shutdown of the JBoss process, which might not be what you
want. The clean way to shutdown is to use the JBoss administrative
application that is deployed when JBoss starts up.
HTH,
Eric
Re: How to stop the debugging JBoss? [message #79568 is a reply to message #79537] Wed, 22 June 2005 02:56 Go to previous messageGo to next message
>> Click Debug button.
JBoss IDE plugin lets you add a "Default Server" menu for starting up /
shutting down the server.
In Window -> Customize Perspective...: select Command and enable Default
Server.
You must also select your default server in Window -> Preferences ->
JBoss-IDE -> Launcher.
After that, you will be able to start and stop JBoss server using the
Default Server menu or the toolbar.
(I am using Eclipse 3.0.0, JBoss 3.2.5, JBoss-IDE 1.3.30; I suppose some
details may change in different configurations)
DYD
Re: How to stop the debugging JBoss? [message #79910 is a reply to message #79537] Thu, 23 June 2005 02:11 Go to previous messageGo to next message
Originally posted by: divinerchan.gmail.com
Eric Rizzo,
Would you introduce more about "JBoss administrative application"?
Diviner.
> Diviner wrote:
>> Daniel Rohe,
>> Click Debug button.
>> terminal window.
> HTH,
> Eric
Re: How to stop the debugging JBoss? [message #79924 is a reply to message #79568] Thu, 23 June 2005 02:13 Go to previous messageGo to next message
DYD,
I have already set Default JBoss Server, so where is the Switch of JBoss?
Diviner.
>>> Click Debug button.
> Server.
> DYD
Re: How to stop the debugging JBoss? [message #79939 is a reply to message #79537] Thu, 23 June 2005 02:16 Go to previous messageGo to next message
Eric Rizzo,
When I was worked on other project, the Red Square was gone. So I can't
alwasy depends on this icon.
Diviner.
> Diviner wrote:
>> Daniel Rohe,
>> Click Debug button.
>> terminal window.
> HTH,
> Eric
Re: How to stop the debugging JBoss? [message #79954 is a reply to message #79924] Thu, 23 June 2005 03:12 Go to previous messageGo to next message
>> Default Server.
Have you also added the menu to your perspective ?
(Window -> Customize Perspective... -> Command -> check Default Server)
In this case you should have the menu "Default server" with commands
"Start" and "Shutdown"
Re: How to stop the debugging JBoss? [message #80091 is a reply to message #79910] Thu, 23 June 2005 11:42 Go to previous messageGo to next message
Diviner wrote:
> Eric Rizzo,
http://www.jboss.org/docs/index
Re: How to stop the debugging JBoss? [message #80369 is a reply to message #79954] Fri, 24 June 2005 04:42 Go to previous messageGo to next message
DYD,
Sorry. I find it now.
Diviner.
>>> Default Server.
Re: How to stop the debugging JBoss? [message #80398 is a reply to message #80091] Fri, 24 June 2005 05:21 Go to previous message
Eric Rizzo,
Diviner.
> Diviner wrote:
>> Eric Rizzo,
Previous Topic:Installtion of EMF plugin
Next Topic:How to install Eclipse?
Current Time: Fri Oct 24 18:19:46 EDT 2025
Powered by FUDForum. Page generated in 0.12232 seconds
