Re: can MAT use PHD? (or only HPROF?) [message #7136 is a reply to message #7112] |
Wed, 19 November 2008 00:28 |
Originally posted by: cgrinds.us.ibm.com
"Paul Th. Keyser" <rolarenfan@earthlink.net> wrote in
news:gfv4dg$h4v$1@build.eclipse.org:
> Instructions do not list IBM JRE which we alas must use. (Not my code or
> decision ...) Instructions seem to assume (without quite saying so) that
> the heap-dump format must be HPROF: what formats are recognized other
> than HPROF? In particular, it seems (from "Open heap Dump" -> navigate
> to directory full of PHD's) that PHD is not recognized?
> On the other hand, I have tried to get the IBM JVM to produce HPROF, so
> far to no avail -- does anyone know how to do that?
Hi Paul,
PHDs are missing a lot of information.
MAT can consume system core files produced by IBM's VM.
You can either programmatically ask for a system dump or setup signal
handler to generate a system dump when a SIG is received.
You can add an adaptor that allows MAT to read IBM core.*.dmp files.
"IBM DTFJ adapter for Eclipse Memory Analyzer Tool"
http://www.ibm.com/developerworks/java/jdk/tools/mat.html
HTH,
Chris
Chris Grindstaff
cgrinds@us.ibm.com
Re: can MAT use PHD? (or only HPROF?) [message #7261 is a reply to message #7136] |
Thu, 20 November 2008 01:40 |
Paul E. Keyser Messages: 878 Registered: July 2009 |
--------------030802080004040404060801
OK, that failed. I got the adaptor and created the ".dmp" files, and
when I navigate in MAT (File -> Open Heap Dump) to the directory where
they are, they are visible -- but MAT+DTFJ just immediately barfs; see
attached .log file.
Any other way to get this to work?
-Paul
name="MAT+DTFJ_Crash.log"
Content-Disposition: inline;
filename="MAT+DTFJ_Crash.log"
!SESSION 2008-11-19 20:33:31.796 -----------------------------------------------
eclipse.buildId=I20070625-1500
java.fullversion=J2RE 1.5.0 IBM J9 2.3 Windows XP x86-32 j9vmwi3223-20070426 (JIT enabled)
J9VM - 20070420_12448_lHdSMR
JIT - 20070419_1806_r8
GC - 200704_19
Command-line arguments: -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.mat.parser 4 0 2008-11-19 20:33:52.359
!MESSAGE Error opening heap dump
!SUBENTRY 1 org.eclipse.mat.parser 4 0 2008-11-19 20:33:52.359
!MESSAGE Unable to read dump in either IBM Java 6, IBM Java 5.0 or IBM Java 1.4.2 formats
!STACK 0
java.io.IOException: Unable to read dump in either IBM Java 6, IBM Java 5.0 or IBM Java 1.4.2 formats
at org.eclipse.mat.dtfj.DTFJIndexBuilder.getUncachedDump(DTFJIn dexBuilder.java:3871)
at org.eclipse.mat.dtfj.DTFJIndexBuilder.getDump(DTFJIndexBuild er.java:3752)
at org.eclipse.mat.dtfj.DTFJIndexBuilder.fill(DTFJIndexBuilder. java:284)
at org.eclipse.mat.parser.internal.SnapshotFactoryImpl.parse(Sn apshotFactoryImpl.java:183)
at org.eclipse.mat.parser.internal.SnapshotFactoryImpl.openSnap shot(SnapshotFactoryImpl.java:101)
at org.eclipse.mat.snapshot.SnapshotFactory.openSnapshot(Snapsh otFactory.java:87)
at org.eclipse.mat.ui.snapshot.ParseHeapDumpJob.run(ParseHeapDu mpJob.java:54)
Caused by: java.io.IOException: Currently can only handle SDFF files, which _MUST have a suffix of ".sdff"_
or svcdumps
at com.ibm.dtfj.image.sov.ImageFactory.getImage(ImageFactory.ja va:99)
at com.ibm.dtfj.image.sov.ImageFactory.getImage(ImageFactory.ja va:169)
at org.eclipse.mat.dtfj.DTFJIndexBuilder.getUncachedDump(DTFJIn dexBuilder.java:3860)
... 7 more
!ENTRY org.eclipse.mat.ui 4 0 2008-11-19 20:33:52.375
!MESSAGE Error opening heap dump 'core.20081120.012103.1220.dmp'. Check log for details.
!STACK 0
org.eclipse.mat.SnapshotException: Error opening heap dump 'core.20081120.012103.1220.dmp'. Check log for details.
at org.eclipse.mat.parser.internal.SnapshotFactoryImpl.parse(Sn apshotFactoryImpl.java:217)
--------------030802080004040404060801--
FUDForum. Page generated in 0.03254 seconds
