Home » Eclipse Projects » EclipseLink » DescriptorQueryManager+EntityManager
Re: DescriptorQueryManager+EntityManager [message #734367 is a reply to message #734295] |
Fri, 07 October 2011 14:43 |
Chris Delahunt Messages: 1389 Registered: July 2009 |
The documentation you seem to be looking at is for the underlying native EclipseLink api, which is a hold over from TopLink. The JPA interface is built on top of it, so you can still use those api to get at the nuts and bolts, but most features are entirely accessible through JPA and JPA like annotations or XML.
Some questions:
1) Is your descriptor customizer being called?
2) What query are you trying to execute and what api are you using to build and execute it?
3) What gets issued to the database for your query? You can turn logging on to see what SQL is issued to the database bu setting the value to FINE or FINER as described at
http://wiki.eclipse.org/EclipseLink/Examples/JPA/Logging
4) What are your requirements query wise - are you able to just use named stored procedure queries for reading, or will you need to use stored proc for writing as well?
As for the setReadAllQuery(), this is used for the default read all query, such as if you peform a basic query with no selection criteria. If you try a find, this might not use your stored procedure - you might want to create a named stored proc to use instead of find, or take a look at the setReadObjectQuery() api.
As for linking the session concepts to JPA - a ServerSession matches up closely to a EntityManagerFactory, while a UnitOfWork is used internally by an EntityManager. Hope that helps
Best Regards,
Chris
Re: DescriptorQueryManager+EntityManager [message #734383 is a reply to message #734295] |
Some questions:
Best Regards,
Chris
Re: DescriptorQueryManager+EntityManager [message #734403 is a reply to message #734367] |
Fri, 07 October 2011 16:17 |
Neikius Mising name Messages: 43 Registered: April 2011 |
Member |
Hi, thanks for the quick answer and helpful suggestions. Lets move this thing, I will update as I go.
Up to this point:
1) Yep
2) I am trying to execute a named procedure, like this:
Query query = entityManager.createNamedQuery("Table.getAll", Table.class);
This does NOT work in the customizer. As I suspected entityManager is null and never gets injected that early... quite obvious once I think about it. I used it 'cause I cannot find any other way to specify named query.
I have to do this:
descriptorQueryManager.setReadAll[Call/Query/SQLString](...);
I guess I have to provide one of these? Guess if I were to provide SQLString that would be ok, but how do I map return parameters then (out cursor)? So I am trying to insert either query or call here. And named query at that. Is that even possible? I do not know. atm I do not have the patience to dig around in the sources. And there is no documents regarding this, just some vague statements that it should be possible which lead me to EclipseLink Sessions in the end. And I don't have a clue about the old-style sessions since I am mostly familiar with classic JPA... dead ends everywhere.
3) I am quite sure nothing goes through, since I've just modified the procedure to write something while it fetches (the fastest way though a bit inflexible).
4) In the end I will want full CRUD through procedures. I'd like to standardise at least the basics though, so I don't have to write queries all the time. Well I can do that without the jpa/eclipselink I guess. But this way it seems nicer when you work.
I was guessing the readAllQuery gets executed on
Query query = em.createQuery("select OBJECT(u) from Table u");
tableList = query.getResultList();
Hope it does. Otherwise my task is already impossible.
Oh and thanks for the reply again. I didn't expect to get one, ever, as I usually don't with my problems
edit: Let me include my named procedure, guess this could be very wrong... no errors though.
@Entity
@Table(name="TABLE")
@NamedStoredProcedureQueries(value={
@NamedStoredProcedureQuery(name="Table.getAll",
procedureName="GETALL_TABLE",
resultClass=Table.class,
parameters={
@StoredProcedureParameter(queryParameter="result", name="c_cur", direction=Direction.OUT_CURSOR)
@Customizer(data.table.TableDescriptorCustomizer.class)
public class Table implements Serializable {
edit2: Trying to set call procedure directly in descriptor and ignoring these annotations and the notion of named queries. Was looking nice though, I like the clarity of annotations for stuff like this.
Have some problems on what and how to bind, but I might be able to work this out.
[Updated on: Fri, 07 October 2011 16:36] Report message to a moderator
Re: DescriptorQueryManager+EntityManager [message #734414 is a reply to message #734367] |
Member |
public void customize(ClassDescriptor descriptor) throws Exception {
descriptor.setReadOnly();
DescriptorQueryManager dqm = descriptor.getDescriptorQueryManager();
StoredProcedureCall spc = new StoredProcedureCall();
spc.setProcedureName("GETALL_TABLE");
spc.addNamedCursorOutputArgument("c_cur");
ReadAllQuery raq = new ReadAllQuery(Table.class, spc);
dqm.setReadAllCall(spc);
dqm.setReadAllQuery(raq);
dqm.setReadAllSQLString(null);
descriptor.setQueryManager(dqm);
Set all 3 instances of "readall"-something to my custom ones. Still, select columns from table gets called... I guess EntityManager doesn't care for my customizer. Maybe I should file a bug or is there something major I am still missing? I am currently trying to make sense of eclipselink sources regarding this. If I find an entry point...
[Updated on: Fri, 07 October 2011 18:05] Report message to a moderator
Re: DescriptorQueryManager+EntityManager [message #735561 is a reply to message #735392] |
Wed, 12 October 2011 08:36 |
Member |
James wrote on Tue, 11 October 2011 11:14Yes, custom queries are used from JPA.
The descriptor defines basic CRUD operations that you can override using stored procedures or custom SQL. You need to set the query to a custom query, not a named query.
The basic CRUD operations only override very specific operations, not any dynamic or JPQL queries. For a specific query, you need to define a NamedStoredProcedureQuery for it and call that specific named query through JPA the same as calling any other named query.
See,
http://wiki.eclipse.org/EclipseLink/Examples/JPA/CRUDStoredProcedures
James : http://wiki.eclipse.org/EclipseLink : http://en.wikibooks.org/wiki/Java_Persistence : http://java-persistence-performance.blogspot.com/
Indeed I have since come to the conclusion that I won't be able to use named procedures/functions for this task (albeit that would have been logical imo).
But not even specifying it otherwise works for me. Hence my statement. The call I provide is never called.
The examples provided at the link are sadly, outdated and not verbose enough. It doesn't say anywhere whether it is enough to override one instance (setCall), or do I have to override all three (setCall, setReadAllQuery, setSQLQuery). Also the example provided is so outdated that the entire api has changed... there is no setName function on StoredProcedureCall. Also why is there no example for readAll? Also it doesn't say anywhere whether this works with EntityManager or just EclipseLink Sessions proprietary api.
Also as I posted - check one post up - I was trying to do just that (from the link) And the call specified is plainly ignored. At least for readAll operation that is the most important imo. Also there is no specification what triggers readAll operation.
EntityManager em;
This should trigger my readAllCall yes?
As it is now user does not have permissions on tables. Eclipselink still tries to read directly from the table.
Also I guess I will never be able to read data if I have complex oracle PLSQL types in there? I was looking at this: http://wiki.eclipse.org/EclipseLink/Examples/JPA/PLSQLStoredFunction
This is even worse... I have to repeat the field 3x and also define a special db object to do the mapping. I cannot reuse the existing entity class, I have to manually specify fields (which are the same in each instance). Well I will try whether this works at all.
Re: DescriptorQueryManager+EntityManager [message #735563 is a reply to message #735392] |
Member |
> See,
EntityManager em;
Re: DescriptorQueryManager+EntityManager [message #739718 is a reply to message #735563] |
Mon, 17 October 2011 19:37 |
The setName on StoredProcedureCall was just a typo, I fixed the wiki example.
It may be that JPQL will not invoke the custom read-all query. Please log a bug for this.
In general if your database does not allow SQL, then using dynamic JPQL to query it is very odd. You would be much better off using a named query in JPA, not JPQL.
James : Wiki : Book : Blog : Twitter
Re: DescriptorQueryManager+EntityManager [message #755446 is a reply to message #748498] |
Tue, 08 November 2011 14:49 |
Member |
You are right. It was obviously wrong code on my end.
BUT
There is no way to figure out the "correct code" since this thing is pretty much undocumented. Right now I am just writing my own sql generators that will run the stuff for me. That ought to work when I can figure out how to call sql stored procedure/function directly. I will post another topic regarding this.
Thanks for your time regarding this issue, though it still doesn't work you saved me some time and calmed me down. At least this venue of thought can be closed now, though I am sad I couldn't get it to work.
[Updated on: Tue, 08 November 2011 14:50] Report message to a moderator
Current Time: Fri Apr 26 22:29:01 GMT 2024
Powered by FUDForum. Page generated in 0.04239 seconds
