Home » Modeling » EMF » How to add ExtendedMetaData options to a sub ECore model
How to add ExtendedMetaData options to a sub ECore model [message #734083] Thu, 06 October 2011 11:55 Go to next message
I have a main Ecore model that is persisted to file in the following way:
IArchimateModel model = ...;
ResourceSet resourceSet = new ResourceSetImpl();
Resource resource = resourceSet.createResource(uri);
resource.getContents().add(model);
resource.save(null);
The method createResource(URI) in the Resource.Factory is over-ridden as follows:
public Resource createResource(URI uri) {
    ArchimateResource result = new ArchimateResource(uri);
    result.getDefaultLoadOptions().putAll(getOptions());
    result.getDefaultSaveOptions().putAll(getOptions());
    return result;
In getOptions() I can set a number of tweaks to the xml format used in persistence:
options = new HashMap<Object, Object>();
ExtendedMetaData ext = new BasicExtendedMetaData(ExtendedMetaData.ANNOTATION_URI,
                    EPackage.Registry.INSTANCE, new HashMap<EModelElement, EAnnotation>());
ext.setName(IArchimatePackage.Literals.ARCHIMATE_MODEL, "model");
// etc...
options.put(XMLResource.OPTION_EXTENDED_META_DATA, ext);
Now I have created a new Ecore model and package in a separate plug-in that extends the base Ecore model above with just a few additional classes. These classes are namespaced and when created by the user are added to a node of the base model. But this new model has its own Resource.Factory that never seems to be referenced when saving. I would like to do a similar thing and provide default load and save options in ExtendedMetaData to this model's Resource.Factory.
Am I missing something?
Thanks in advance.
Phil
Re: How to add ExtendedMetaData options to a sub ECore model [message #734830 is a reply to message #734083] Mon, 10 October 2011 02:23 Go to previous messageGo to next message
Phil,
Comments below.
> as follows:
> return result;
> persistence:
> // etc...
They're registered by extension so of course you'll have issues if you
have multiple registrations for the same extension (which are logged in
the Error Log). You can always use the debugger to find which factory
it's using.
Missing a registrations or have duplicates...
> Thanks in advance.
> Phil
Re: How to add ExtendedMetaData options to a sub ECore model [message #735023 is a reply to message #734830] Mon, 10 October 2011 12:51 Go to previous messageGo to next message
Thanks for the reply, Ed.
I have registered the factory but I don't think it will make any difference. In my persistence method the Resource is never created. This is because the Eobjects are children of the parent model.
Phil
Ed Merks wrote on Mon, 10 October 2011 02:23
Phil,
Comments below.
> as follows:
> return result;
> persistence:
> // etc...
it's using.
> Thanks in advance.
> Phil
Re: How to add ExtendedMetaData options to a sub ECore model [message #735172 is a reply to message #735023] Tue, 11 October 2011 02:43 Go to previous messageGo to next message
Phil,
Comments below.
Is any resource created?
You'll need to apply your options to whatever resource is being created...
> Phil
>> Phil,
>> Comments below.
>> following way:
>> over-ridden > as follows:
>> > return result;
>> in > persistence:
>> > ExtendedMetaData ext = new >
>> > EPackage.Registry.INSTANCE, new >
>> > // etc...
>> plug-in > that extends the base Ecore model above with just a few
>> additional > classes. These classes are namespaced and when created
>> by the user are > added to a node of the base model. But this new
>> model has its own > Resource.Factory that never seems to be
>> you have multiple registrations for the same extension (which are
>> logged in the Error Log). You can always use the debugger to find
>> which factory it's using.
>> save > options in ExtendedMetaData to this model's Resource.Factory.
>> > Thanks in advance.
>> > Phil
Re: How to add ExtendedMetaData options to a sub ECore model [message #735177 is a reply to message #735172] Tue, 11 October 2011 03:28 Go to previous messageGo to next message
Thanks Ed,
yes the "parent" Resource is created but it doesn't know anything about the embedded "child" Ecore model. I figured out that it's best just to let the child model set its own Extended Metadata directly:
// Ensure Package is initialised
ICanvasPackage.eINSTANCE.eClass();
// The Iconic "imageData" attribute becomes an element
ExtendedMetaData.INSTANCE.setFeatureKind(ICanvasPackage.Literals.ICONIC__IMAGE_DATA, ExtendedMetaData.ELEMENT_FEATURE);
Phil
Re: How to add ExtendedMetaData options to a sub ECore model [message #735188 is a reply to message #735177] Tue, 11 October 2011 03:39 Go to previous messageGo to next message
Phil,
It would seem better to have this meta data in the model at the time you
generate than to add it programmatically...
On 11/10/2011 9:28 AM, Phil Beauvoir wrote:
> Thanks Ed,
> ICanvasPackage.eINSTANCE.eClass(); // The Iconic
> Phil
Re: How to add ExtendedMetaData options to a sub ECore model [message #735435 is a reply to message #735188] Tue, 11 October 2011 15:13 Go to previous messageGo to next message
Thanks again, Ed. I added EAnnotations to the elements in the ECore editor. Job done.
Once again this proves that EMF is the most well thought out framework. Ever. Smile
Phil
Ed Merks wrote on Tue, 11 October 2011 03:39
Phil,
> Thanks Ed,
> Phil
Re: How to add ExtendedMetaData options to a sub ECore model [message #738080 is a reply to message #735435] Sat, 15 October 2011 16:36 Go to previous messageGo to next message
Unfortunately this has led to a curious side effect. When I was using the programmatic ExtendedMetadata, references to other objects' IDs in the persistence of a model instance looked like the following:
<sourceConnection xsi:type="archimate:Connection" id="8de80c5a" source="b2e81369" target="428b4832" relationship="2e12df54"/>
But after the change, using the ExtendedMetadata annotations in the eCore model and generating the model, the persistence of a model instance now adds a hash (#) in front of each referenced ID:
<sourceConnection xsi:type="archimate:Connection" id="8de80c5a" source="#b2e81369" target="#428b4832" relationship="#2e12df54"/>
Why is the hash there now?
Phil
Phil Beauvoir wrote on Tue, 11 October 2011 15:13
Phil
Re: How to add ExtendedMetaData options to a sub ECore model [message #738397 is a reply to message #738080] Sun, 16 October 2011 02:54 Go to previous messageGo to next message
Phil,
Comments below.
Is EAttribute.isID true for this?
> source="#b2e81369"
Is EReference.isResolveProxies true for this?
For something that could be a cross document reference in general but
the object is in the same resource so the resource URI needs to be
specified.
> Phil
>> editor. Job done.
>> framework. Ever. :)
>> Cheers,
>> Phil
Re: How to add ExtendedMetaData options to a sub ECore model [message #738449 is a reply to message #738397] Sun, 16 October 2011 04:35 Go to previous message
Thanks once again Ed for taking the time to answer. In the end after some experimentation I found the cause.
When I was previously persisting the model using my own BasicExtendedMetaData in the Resource Factory, EMF generated a very basic createResource(URI) method in the ResourceFactory:
    return result;
I then specified all my own XMLResource.* options and ExtendedMetadata and added them to the default save and load options.
However, now that I have added annotations to the Ecore model, EMF generated a new method:
        XMLResource result = new ArchimateResource(uri);
        result.getDefaultSaveOptions().put(XMLResource.OPTION_EXTENDED_META_DATA, Boolean.TRUE);
        result.getDefaultLoadOptions().put(XMLResource.OPTION_EXTENDED_META_DATA, Boolean.TRUE);
        result.getDefaultSaveOptions().put(XMLResource.OPTION_SCHEMA_LOCATION, Boolean.TRUE);
        result.getDefaultLoadOptions().put(XMLResource.OPTION_USE_ENCODED_ATTRIBUTE_STYLE, Boolean.TRUE);
        result.getDefaultSaveOptions().put(XMLResource.OPTION_USE_ENCODED_ATTRIBUTE_STYLE, Boolean.TRUE);
        result.getDefaultLoadOptions().put(XMLResource.OPTION_USE_LEXICAL_HANDLER, Boolean.TRUE);
        return result;
Once I removed the XMLResource.OPTION_USE_ENCODED_ATTRIBUTE_STYLE options it no longer prefixed hashes to id references.
Is this expected behaviour for EMF to generate these options in createResource(URI) only when the Ecore model has ExtendedMetadata annotations? It took me by surprise.
Phil
Ed Merks wrote on Sun, 16 October 2011 02:54
Phil,
Comments below.
> source="#b2e81369"
specified.
> Phil
>> editor. Job done.
>> Cheers,
>> Phil
[Updated on: Sun, 16 October 2011 14:34] by Moderator
Previous Topic:Null Pointer Exception during drag and drop in emf editor: appeared in 2.7
Next Topic:Override the persistency of non-containmnent references
Current Time: Tue Oct 28 06:45:04 EDT 2025
Powered by FUDForum. Page generated in 0.08626 seconds
