HTTPProxy failure using ssh protocol? [message #733813] |
Wed, 05 October 2011 17:26 |
John J. Franey Messages: 31 Registered: July 2009 |
Member |
In egit 1.1, I cannot clone or fetch from a remote repository. Command line works fine.
Indeed, I have an http proxy in my company, and I have Windows->Preferences->General->Network Connections Active Provider is 'native' proxy. This configuration works for the jira mylyn connector I am using.
So:
1) Why does egit want to use http proxy at all when the ssh protocol is specified.
2) If it must use the http proxy, why can't it use my 'native' active provider to get it (like jira mylyn connector does)? And what does it send via http anyway?
John
org.eclipse.jgit.errors.TransportException: ssh://jfraney@10.133.141.225/srv/git/public/collector.git: ProxyHTTP: java.io.IOException: proxy error: Proxy Authentication Required
at org.eclipse.jgit.transport.JschConfigSessionFactory.getSession(JschConfigSessionFactory.java:138)
at org.eclipse.jgit.transport.SshTransport.getSession(SshTransport.java:121)
at org.eclipse.jgit.transport.TransportGitSsh$SshFetchConnection.<init>(TransportGitSsh.java:248)
at org.eclipse.jgit.transport.TransportGitSsh.openFetch(TransportGitSsh.java:147)
at org.eclipse.jgit.transport.FetchProcess.executeImp(FetchProcess.java:127)
at org.eclipse.jgit.transport.FetchProcess.execute(FetchProcess.java:113)
at org.eclipse.jgit.transport.Transport.fetch(Transport.java:1062)
at org.eclipse.jgit.api.FetchCommand.call(FetchCommand.java:136)
at org.eclipse.egit.core.op.FetchOperation.run(FetchOperation.java:128)
at org.eclipse.egit.ui.internal.fetch.FetchOperationUI.execute(FetchOperationUI.java:99)
at org.eclipse.egit.ui.internal.fetch.FetchOperationUI$1.run(FetchOperationUI.java:117)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54)
Caused by: com.jcraft.jsch.JSchException: ProxyHTTP: java.io.IOException: proxy error: Proxy Authentication Required
at com.jcraft.jsch.ProxyHTTP.connect(ProxyHTTP.java:158)
at com.jcraft.jsch.Session.connect(Session.java:198)
at org.eclipse.jgit.transport.JschConfigSessionFactory.getSession(JschConfigSessionFactory.java:128)
... 11 more
Caused by: java.io.IOException: proxy error: Proxy Authentication Required
at com.jcraft.jsch.ProxyHTTP.connect(ProxyHTTP.java:122)
... 13 more
FUDForum. Page generated in 0.02978 seconds
