Home » Archived » M2M (model-to-model transformation) » How to call a called rule.[ATL]
How to call a called rule.[ATL] [message #733627] Wed, 05 October 2011 04:49 Go to next message
Hi;
I want to know how I can call a called rule; but I have not succeeded,an error always occurred;please hepl me it is obligatory to use a called rule. in the ALT Manual, there is no such syntax. I hope the author can add it later on. Thanks.
here is the excerpt:
rule Square2Circel {
from E : Square!Square
to c : Circle!Circle
--Color <- thisModule.transfs(E.Color),
Cle<-E.cle,
Rayon<-E.Length
do
c.Color <- thisModule.transfs(E.Color);
rule transfs(n:String){ -- a called rule
to
c : Circle!Circle(
Color<-n
Re: How to call a called rule.[ATL] [message #733650 is a reply to message #733627] Wed, 05 October 2011 05:54 Go to previous messageGo to next message
The way you call the called rule is correct but a called rule must explicitely specify what it returns.
There you'll have :
to
c : Circle!Circle(
Color<-n
do{
c;
Re: How to call a called rule.[ATL] [message #733688 is a reply to message #733650] Wed, 05 October 2011 08:37 Go to previous message
ok;
thnks a lot Sylvain EVEILLARD but after several triad i found thant the problem is on the way that i call the called rule :
old code:
Cle<-E.cle,
Rayon<-E.Length
do
to
c : Circle!Circle(
Color<-n
after correction:
to
c : Circle!Circle(
Color<-n
do{
c;
-- <- thisModule.transfs(E.Color),
Cle<-E.cle,
Rayon<-E.Length
do
--thisModule.transfs('red');
Previous Topic:[ATL] Iterating over collections
Next Topic:index from sequence
Current Time: Sun Sep 21 01:25:53 EDT 2025
Powered by FUDForum. Page generated in 0.04506 seconds
