Home » Language IDEs » PHP Development Tools (PDT) » problems with debugging a web page with Xdebug
problems with debugging a web page with Xdebug [message #78999] Mon, 25 August 2008 09:57 Go to next message
I successfully installed xdebug which works correctly (I'm using PDT 2
and ganymede under Linux);
however, when I create a debug configuration, although I correctly set
all the parameters, the internal web browser does not start automatically.
I can debug a web page only if I manually insert in the web browser the
same url plus the string ?XDEBUG_SESSION_START=ECLIPSE_DBGP
why this is not done automatically?
thanks in advance
Lorenzo
ICQ# lbetto, 16080134 (GNU/Linux User # 158233)
HOME: http://www.lorenzobettini.it MUSIC: http://www.purplesucker.com
http://www.myspace.com/supertrouperabba
BLOGS: http://tronprog.blogspot.com http://longlivemusic.blogspot.com
http://www.gnu.org/software/src-highlite
http://www.gnu.org/software/gengetopt
http://www.gnu.org/software/gengen http://doublecpp.sourceforge.net
Re: problems with debugging a web page with Xdebug [message #79005 is a reply to message #78999] Mon, 25 August 2008 12:25 Go to previous message
It should do this, what parameters are put into the url field for the browser ?
are you sure your launch configuration specifies xdebug ?
Have you tried configuring PDT to use an external browser to see if that helps ?
(window-->preferences, select general, web browser to configure). Eclipse does seem to have problems
at times with internal browser selection.
Dave Kelsey
Lorenzo Bettini wrote:
> Hi
> thanks in advance
> Lorenzo
Previous Topic:installation all in one
Next Topic:PDT 2.0 schedule
Current Time: Sun Mar 16 03:41:56 EDT 2025
Powered by FUDForum. Page generated in 0.02888 seconds
