Home » Eclipse Projects » P2 » Imposible to install plug-ins with P2 director application
Imposible to install plug-ins with P2 director application [message #731825] Mon, 03 October 2011 04:49 Go to next message
I have a product and I want to install different external features using the p2 director application but it doesn't work.
With this code:
/home/hudson/moskitt-galileo-dev/build/org.eclipse.releng.basebuilder/eclipse \
-application org.eclipse.equinox.p2.director \
-repository http://download.moskitt.org/moskitt/mdt.storage/updates-1.3.4 \
-installIU es.cv.gvcase.features.mdt.common.storage.feature.group \
-destination moskitt-1.3.7.v201109160830 \
-bundlepool moskitt-1.3.7.v201109160830
I obtain this error:
Installing es.cv.gvcase.features.mdt.common.storage.feature.group 0.9.3.201104261240.
An error occurred while installing the items
session context was:(profile=profile, phase=org.eclipse.equinox.internal.provisional.p2.engine.phases.Install, operand=null --> [R]es.cv.gvcase.features.mdt.common.storage.feature.jar 0.9.3.201104261240, action=org.eclipse.equinox.internal.p2.touchpoint.eclipse.actions.InstallFeatureAction).
Error while loading manipulator.
Caused by: Application failed, log file location: /home/hudson/moskitt-galileo-dev/build/org.eclipse.releng.basebuilder/configuration/1317630776639.log
I have tried to specify the profile option:
-profile SDKProfile
and the error is different:
Cannot complete the install because one or more required items could not be found.
Software being installed: Artifacts storage for MOSKitt 0.9.3.201104261240 (es.cv.gvcase.features.mdt.common.storage.feature.group 0.9.3.201104261240)
Missing requirement: gvCASE mdt common elements Storage 0.9.3.201104261240 (es.cv.gvcase.mdt.common.storage 0.9.3.201104261240) requires 'bundle org.eclipse.ui 0.0.0' but it could not be found
Cannot satisfy dependency:
From: Artifacts storage for MOSKitt 0.9.3.201104261240 (es.cv.gvcase.features.mdt.common.storage.feature.group 0.9.3.201104261240)
To: es.cv.gvcase.mdt.common.storage [0.9.3.201104261240]
Application failed, log file location: /home/hudson/moskitt-galileo-dev/build/org.eclipse.releng.basebuilder/configuration/1317631489134.log
Missing requirement is not correct because "org.eclipse.ui" plug-in is into product.
Any idea ?¿?
Thanks in advance
Re: Imposible to install plug-ins with P2 director application [message #731827 is a reply to message #731825] Mon, 03 October 2011 04:53 Go to previous messageGo to next message
Running the product and installing the same feature with the "Install New Software" option it works fine.
I'm using Eclipse Galileo 3.5.0 as builder.
Re: Imposible to install plug-ins with P2 director application [message #735982 is a reply to message #731827] Thu, 13 October 2011 05:40 Go to previous messageGo to next message
At the beginning, i had the same troubles. The installation via the GUI fetches all prerequistes if configured. You will get the same error, if you uncheck "Contact all update sites during install to find required software".
So on the command line, you need to add the required features too, if not installed.
Re: Imposible to install plug-ins with P2 director application [message #735992 is a reply to message #735982] Thu, 13 October 2011 06:04 Go to previous messageGo to next message
I think this can't be the problem because as you can see in the error
refers that (org.eclipse.ui) can't be found but it is into RCP !!!
Moreover, to verify that don't exist dependencies to other plug-ins, I have installed it via GUI with the "contact all update sites during install to find required software" unchecked and the feature has been installed without problems.
Thanks a lot.
Best regards
Re: Imposible to install plug-ins with P2 director application [message #752435 is a reply to message #735992] Wed, 26 October 2011 07:45 Go to previous message
What if you don't specify -bundlepool, and specify the full path to -destination? Keep -profile
PW
Previous Topic:p2.inf tooling ?
Next Topic:Installing plug-ins and data (DLLs)
Current Time: Wed Oct 29 00:40:16 EDT 2025
Powered by FUDForum. Page generated in 0.03726 seconds
