Home » Archived » Jubula » Jubula + Jenkins Integration
Jubula + Jenkins Integration [message #731268] Fri, 30 September 2011 09:08 Go to next message
Hi Guys,
We have been using Jubula in our company for quit some time. Recently, my boss has asked me to find a way to integrate Jubula with Jenkins. As I am relatively new to this area perhaps you can help me answering the following Qs.
1. Is it possible to configure Jenkins/Jubula so that the Jenkins will display the test results for each step of the testsuite in Red/Green(Text result should be fine too)?
2. Is it possible to run Jubula using relative paths especially in org.eclipse.jubula.client.ui.prefs file?
GENERATEREPORT_KEY=true
START_BROWSE_PATH_KEY=C\:\\Users\\USERNAME\\workspace\\....
RESULTPATH_PREF_KEY=C\:\\Users\\USERNAME\\Documents\\Jubula_Test_Results
SCHEMA_KEY=Jubula
TEST_EXECUTION_RELEVANT=0
REPORTGENERATORSTYLE_KEY=Full
USER_KEY=jubula
REMEMBER_KEY=true
MINORVERSION_PREF_KEY=1
PERSP_CHANGE_KEY=0
eclipse.preferences.version=1
SERVER_SETTINGS_KEY=...........=,;;
MAJORVERSION_PREF_KEY=1
LAST_USED_SERVER_KEY=localhost\:60000
TIA
Re: Jubula + Jenkins Integration [message #733586 is a reply to message #731268] Wed, 05 October 2011 02:56 Go to previous messageGo to next message
maybe this helps:
http://devnotesblog.wordpress.com/2011/06/14/automating-eclipse-jubula-tests-with-jenkins/
Re: Jubula + Jenkins Integration [message #733998 is a reply to message #733586] Thu, 06 October 2011 05:21 Go to previous messageGo to next message
I am running a Jenkins CI on http: //ngiger.dyndns.org/jenkins/view/2.1.6/job/jubula-elexis-2.1.6/ for testing our application.
The whole setup can be found at https: //bitbucket.org/ngiger/jubula-elexis/overview
I would also appreciate to see the details of each step.
I used Ruby scripts to setup the whole environment. Have a look at run_jenkins.rb and the files it uses and you should get the idea.
Re: Jubula + Jenkins Integration [message #734221 is a reply to message #733998] Fri, 07 October 2011 03:03 Go to previous message
If you upgrade to Jubula 1.1 (release end of septembre) then the HTML reports will show the details of each steps.
Previous Topic:Integrating Jubula with a CI server
Next Topic:Can't get "Check Existence of Value in Column" to work correctly
Current Time: Wed Nov 05 23:26:02 EST 2025
Powered by FUDForum. Page generated in 0.03864 seconds
