| java.lang.UnsatisfiedLinkError: wrong elf class elfclass32 [message #731239] |
Fri, 30 September 2011 07:20  |
I am using Eclipse IDE 3.7 for my RCP application. While running the application, following Exception gets logged in the log view:
java.lang.UnsatisfiedLinkError: /opt/hp93000rt/el5/i386/pqr_ure_udk_23-1.1/ure/lib/libjuh.so: /opt/hp93000rt/el5/i386/pqr_ure_udk_23-1.1/ure/lib/libjuh.so: wrong ELF class: ELFCLASS32 (Possible cause: architecture word width mismatch)
at java.lang.ClassLoader$NativeLibrary.load(Native Method)
at java.lang.ClassLoader.loadLibrary0(ClassLoader.java:1778)
at java.lang.ClassLoader.loadLibrary(ClassLoader.java:1703)
at java.lang.Runtime.loadLibrary0(Runtime.java:823)
at java.lang.System.loadLibrary(System.java:1028)
at com.sun.star.comp.helper.Bootstrap.defaultBootstrap_InitialComponentContext(Bootstrap.java:213)
On analysing further I found that this might be due to the use of 64 bit JVM. From other news group posts, it was suggested to use a 32 bit inorder to solve the issue. For this I added -D32 to the VMargs.
On using a 32- bit JVM, following Exception is observed:
java.lang.UnsatisfiedLinkError: no juh in java.library.path
at java.lang.ClassLoader.loadLibrary(ClassLoader.java:1709)
We are still checking on newsgroup post for similar issues. But have not found any for eclipse 3.7 version.
We are not observing this issue with same set up on eclipse IDE 3.5.
We are not able to identify root cause for this issue.
If anyone can suggest any pointers to resolve this issue, it would be of great help.
Thanks in Advance,
Ajinkya
| Re: java.lang.UnsatisfiedLinkError: wrong elf class elfclass32 [message #731943 is a reply to message #731239] |
Mon, 03 October 2011 10:13   |
First question, what are you running on? The path gives the impression
that it may be HPUX (?). Or is it just Linux?
It looks like libjuh.so is a required dependency, and is available on
your machine in a 32-bit flavour. Are you able to try your case with
real 32-bit eclipse and jre installs (not just passing -D32 to the
64-bit jre)?
Grant
On 9/30/2011 7:20 AM, Ajinkya wrote:
> at
> at
> great help.
> Thanks in Advance,
> Ajinkya
| Re: java.lang.UnsatisfiedLinkError: wrong elf class elfclass32 [message #734209 is a reply to message #731943] |
Fri, 07 October 2011 00:21   |
Hi Grant,
Thanks for your reply.
Answering to your first question, I am running the application on Linux.
One more thing I noticed was, the use of VMargs which was previously posted was incorrect, hence 32 JVM was not used. On properly adding -d 32 to the VM Arguments found that running a 32 bit JVM was not supported on the platform.
The actual problem is, though this issue gets resolved by using a 32 bit JVM, it won't be possible to use it for the application.
So I wanted to know, other than using a 32 bit JVM or upgrading the libjuh.so to 64 bit, is there any possible alternative which might be helpful.
Please do reply for any suggestions.
Ajinkya
| Re: java.lang.UnsatisfiedLinkError: wrong elf class elfclass32 [message #734381 is a reply to message #734209] |
Fri, 07 October 2011 11:15   |
There isn't a way to launch a 32-bit Eclipse/SWT app, or to load 32-bit
libraries, with a JRE that's running in 64-bit mode. So I don't have
anything to suggest beyond getting a 32-bit JRE or re-compiling your
library as 64-bit.
Grant
On 10/7/2011 12:21 AM, Ajinkya wrote:
> Hi Grant,
> on the platform.
> helpful.
> Ajinkya
FUDForum. Page generated in 0.03932 seconds
