Home » Eclipse Projects » Memory Analyzer » Using MemoryAnalyzer api's in Java(Using MemoryAnalyzer api's in Java)
Using MemoryAnalyzer api's in Java [message #731221] Fri, 30 September 2011 06:11 Go to next message
we wanted to use Memory Analyzer API's in our Java code (ie not writing extensions to MAT)...
Approach followed was to copy all jars(found in "plugin" folder of MemoryAnalyzer) to classpath of project .(in Jdeveloper)
and have sample progam to get "ISnapshot" of hprof file
Sample Program
File hproffile=new File("scratch/ana1","jrockit_568.hprof");
ISnapshot iSnap=null;
VoidProgressListener progressListner=new VoidProgressListener();
try {
System.out.println("Opening .....");
iSnap= SnapshotFactory.openSnapshot(hproffile,progressListner);
System.out.println("done....");
} catch (SnapshotException e) {
e.printStackTrace();
finally{
System.out.println("Finally Block");
SnapshotFactory.dispose(iSnap);
Error while getting Platform's Extension registry
was getting following runtime error
Caused by: java.lang.NullPointerException
at org.eclipse.mat.snapshot.SnapshotFactory.<clinit>(SnapshotFactory.java:82)
On checking "SnapshotFactory.java" ..found that it was failing while getting "extensionPoint"
IExtensionPoint extensionPoint = Platform.getExtensionRegistry().getExtensionPoint(
MATPlugin.PLUGIN_ID + ".factory");
with this
1>whats the right approach to use api's of MAT (ie using SnapshotFactory,ISnapshot etc) in Java ..
2>is there any "extension" setup , to override above error message
2>any relevant documentation regarding this
Re: Using MemoryAnalyzer api's in Java [message #733189 is a reply to message #731221] Tue, 04 October 2011 11:29 Go to previous messageGo to next message
Eclipse and Memory Analyzer tool use an OSGi environment, so just using the jars on a class path won't work, as things like Eclipse extension point definitions won't be found.
Re: Using MemoryAnalyzer api's in Java [message #733596 is a reply to message #733189] Wed, 05 October 2011 03:52 Go to previous messageGo to next message
As Andrew wrote it is not possible to just put the MAT jars on the classpath and use it within your tool. But you could have your own Eclipse plugins which use the API. And in case you don't need GUI, you can define your own org.eclipse.core.runtime.applications extension, have a class that implements IApplication and run it with some script.
MAT offers for example the possibility to parse a heap dump without running the GUI. Have a look at the ParseHeapDump script. The extension point is defined in the org.eclipse.mat.api plugin and implemented in the org.eclipse.mat.internal.apps.ParseSnapshotApp class.
I guess this could be a way for you to build some tools on top of MAT APIs.
What do you think?
Krum
Re: Using MemoryAnalyzer api's in Java [message #734423 is a reply to message #733596] Fri, 07 October 2011 13:56 Go to previous messageGo to next message
Andrew,Krum - Thanks for the Information provided .
As per the information provided created extension
1>using "org.eclipse.mat.api" plugin and a
2>Extension class to implement Interface "org.eclipse.equinox.app.IApplication"
( "extesnion" java file attached )
On Running the plugin
Run-->Run As--> Eclipse applciation
following errors are encountered..
1>org.eclipse.core.runtime.CoreException: Plug-in org.eclipse.mat.ui.rcp was unable to load class org.eclipse.mat.ui.rcp.Application.
2>org.osgi.framework.BundleException: The activator org.eclipse.mat.ui.rcp.RCPPlugin for bundle org.eclipse.mat.ui.rcp is invalid
3>org.osgi.framework.BundleException: The activator org.eclipse.ui.internal.WorkbenchPlugin for bundle org.eclipse.ui.workbench is invalid
Re: Using MemoryAnalyzer api's in Java [message #735159 is a reply to message #734423] Tue, 11 October 2011 02:36 Go to previous messageGo to next message
How to run or debug the plugin (non GUI) using eclipse ide..
and
how to specify the parameters in ide during debug like
org.eclipse.mat.api:suspects
or
org.eclipse.mat.api:top_components
which we provide while running the applciation as script...
like ./MemoryAnalyzer -consolelog -application <<applciationName>> "$@"
Re: Using MemoryAnalyzer api's in Java [message #735538 is a reply to message #735159] Wed, 12 October 2011 02:46 Go to previous messageGo to next message
Krum ,Andrew- Thanks for the advice, we are able to progess on that.
We were able to progress on getting java instance of
Collection of histogram records and
execute applciation relevant OQL queries .
--- to traverse the result and derive logic
with this i have couple of questions to progress further
1>what is the java api to get "leak suspect" information of a hprof
which object has leak suspect information?
2>Once we get OQL result in "IResultTable" object.
how to sort the resulttable on a specific column.
ie
IOQLQuery query1 = SnapshotFactory.createQuery(" SELECT m.@retainedHeapSize FROM java.lang.String m ");
IResultTable res =((IResultTable)query1.execute(snapshot, listener));
how to sort on DESC order of "m.@retainedHeapSize"
Re: Using MemoryAnalyzer api's in Java [message #740243 is a reply to message #735538] Tue, 18 October 2011 05:55 Go to previous messageGo to next message
Andrew, Krum -
1) Can you point us to a Java API, which gives us handle to "Leak Suspect" results as java-object instances.
2) Is there any In-Built sorting mechanism provided to sort rows in "IResultTable" ?
Vinod
Re: Using MemoryAnalyzer api's in Java [message #741156 is a reply to message #740243] Wed, 19 October 2011 04:31 Go to previous messageGo to next message
1. Try the find_leaks query, called using SnapshotQuery.lookup("find_leaks", snapshot)
2. Try RefinedResultBuilder
and setSortOrder()
Re: Using MemoryAnalyzer api's in Java [message #741641 is a reply to message #741156] Wed, 19 October 2011 14:51 Go to previous messageGo to next message
Facing ClassCastException ,when casting OQLQuery result to "RefinedResultBuilder"
ie
IOQLQuery query1 =SnapshotFactory.createQuery("<<OQL Query>> ");
RefinedResultBuilder res =((RefinedResultBuilder)query1.execute(snapshot, listener));
is there any way to get OQLQuery Result in "RefinedResultBuilder" Object?
Re: Using MemoryAnalyzer api's in Java [message #742113 is a reply to message #741641] Thu, 20 October 2011 03:26 Go to previous messageGo to next message
Use the constructor for RefinedResultBuilder, set the sort order, then build the RefinedStructuredResult.
Re: Using MemoryAnalyzer api's in Java [message #1385832 is a reply to message #733596] Wed, 11 June 2014 09:44 Go to previous message
I'm trying to use the Memory Analyzer API programmatically. I have followed the steps pointed in this post:
1. Create a new plug-in project
2. Add the required "org.eclipse.mat.api" plugin
3. Add a extension class implementing "org.eclipse.equinox.app.IApplication"
In the start method I tried to read a dump file and I get the following exception:
SEVERE: Error during creation of snapshot factory.
java.lang.NullPointerException at org.eclipse.mat.snapshot.SnapshotFactory.openSnapshot(SnapshotFactory.java:145)
Could you please help me? Should I add anything else for being able to use the MAT API?
Thanks!
Previous Topic:How to create heap dump for spring based web application running in weblogic
Next Topic:Memory Analyzer 1.4.0 is now released!
Current Time: Wed Nov 05 19:01:25 EST 2025
Powered by FUDForum. Page generated in 0.24283 seconds
