Birt 3.7 and IE 9 [message #731199] |
Fri, 30 September 2011 08:51 |
Emmanuel Messages: 12 Registered: September 2011 |
Do you know if the following version of Birt will support IE9.
This tool is so magic...
I put an iframe in the page.
When we generate in a pdf format it works quite fine.
We have an issue in the prototype.js in the stopobserving function on element.removeEventListener(name, observer, useCapture) :
message (sorry in french) : Erreur d'exécution Microsoft JScript: Objet appelant non valide.
The html format doesn't work.
There is no SOAP return and the processing window stay.
The first problem is in the AbstractBaseReportDocument.js class.
We need to change : if (BrowserUtility.isIE) by ( BrowserUtility.isIE6 || BrowserUtility.isIE7).
The problem seems to be on the birtSoapRequest. We have an Error not specified on the __xmldocument property.
Manu
[Updated on: Mon, 03 October 2011 06:45] Report message to a moderator
Re: Birt 3.7 and IE 9 [message #731385 is a reply to message #731199] |
Fri, 30 September 2011 19:32 |
It is not on the project plan yet, but it most likely work.
Jason
On 9/30/2011 4:51 AM, Emmanuel wrote:
> Hello,
> Regards
> Manu
Re: Birt 3.7 and IE 9 [message #731932 is a reply to message #731459] |
Mon, 03 October 2011 13:54 |
What url are you using for the iframe?
Jason
On 10/1/2011 1:05 AM, Emmanuel wrote:
> Thanks Jason.
> But as you can see I update my post.
> It doesn't work when we use an iframe in asp.net.
> Regards
> Manu
Re: Birt 3.7 and IE 9 [message #731951 is a reply to message #731937] |
Mon, 03 October 2011 14:37 |
I assume you have format=html in the url?
Can you remove the runat attribute and can you try using /preview
instead of /frameset?
Jason
On 10/3/2011 10:08 AM, Emmanuel wrote:
> I use this url :
> <iframe id="iframe2" runat="server" src="h t t p : /
> /localhost:8080/Birt/frameset?__report=report\SalesInvoice.rptdesign&__format"
> scrolling="auto" width="100%" height="600px" frameborder="0"> </iframe>
> Regards
> Manu
Re: Birt 3.7 and IE 9 [message #732354 is a reply to message #732173] |
Tue, 04 October 2011 14:56 |
Does removing the runat option and leaving the frameset work?
If you open the browser and put the iframe url in does it work?
Jason
On 10/4/2011 2:39 AM, Emmanuel wrote:
> Hello,
> Yes the url has =html at the end.
> Thanks a lot for your feedback.
> It works with preview as you recommend, but we loose all the benefits of
> the frameset (run, export etc ...).
> Manu
Re: Birt 3.7 and IE 9 [message #733744 is a reply to message #733581] |
Wed, 05 October 2011 14:35 |
Emmanuel,
Can you open a bug for this? The frameset mapping uses AJAX and
webservices to update the data. I am not certain why this is failing in
the case.
Jason
On 10/5/2011 2:41 AM, Emmanuel wrote:
> In fact, I have no error, the please processing window is running with
> no end.
> Here is the beginning of the source : <TITLE>Classic Models Sales
> Invoice Report</TITLE>
> <BASE href="http://localhost:8080/Birt/webcontent/birt" >
> <!-- Mimics Internet Explorer 7, it just works on IE8. -->
> <META HTTP-EQUIV="X-UA-Compatible" CONTENT="IE=EmulateIE7">
> Manu
Re: Birt 3.7 and IE 9 [message #740485 is a reply to message #740215] |
Tue, 18 October 2011 15:05 |
I will look into the bug.
Jason
On 10/18/2011 5:16 AM, Emmanuel wrote:
> Hello Jason,
> I create the Bug 360068 as you recommand.
> But since the 06th october, no return.
> Do you think it's normal?
> Ciao
> Manu
Re: Birt 3.7 and IE 9 [message #754030 is a reply to message #754022] |
Mon, 31 October 2011 14:41 |
Manu,
I will check with the dev team again.
Jason
On 10/31/2011 10:18 AM, Emmanuel wrote:
> Hi Jason,
> Sorry for disturbing oyou again, but since the 18th of October, I still
> have no nes on the bug.
> Regards
> Manu
Re: Birt 3.7 and IE 9 [message #768163 is a reply to message #767928] |
Mon, 19 December 2011 17:25 |
Thanks Manu, were you able to try the compatibility test from my last
message?
Jason
On 12/19/2011 3:17 AM, Emmanuel wrote:
> Hello Jason,
> Sorry for disturbing you again but I Still have no news on that bug.
> Regards
> Manu
Re: Birt 3.7 and IE 9 [message #768329 is a reply to message #768175] |
Mon, 19 December 2011 23:09 |
Would you be able to do a skype session and show me how you have
everything setup?
Jason
On 12/19/2011 12:38 PM, Emmanuel wrote:
> Yes I do the test but the result is the same.
> Regards
> Manu
FUDForum. Page generated in 0.05405 seconds
