Intent to automate diagnosis with MAT Java APIs [message #730834] |
Thu, 29 September 2011 06:18  |
MAT Dev Team:
Once "Memory Analyzer" tool provides Leak-suspect report, we need to further
spend a good amount of time to complete the exact root-cause OR 'source of issue', when the actual java Enterprise-Application is quite large-scale.
In this context, I would like to see how much of the "Root-cause" analysis
of Heapdump file can be automated, with the assumption that Application-framework
knowledge can be programmed into the debugging-code.
So, would like to check with the MAT-Dev team, if they expose MAT as "jar-files",
(and corresponding Java-doc), so that consumers (like us) can see how effectively
they can automate this triaging / debugging process.
In other words, instead of manually triaging, we are looking forward to use the
java methods directly, to retrieve the Leak-suspects, and then traverse
thro Histogram programatically, and further traverse programatically through
other data-set.
Thanks a lot for this help.
Vinod
FUDForum. Page generated in 0.03530 seconds
