Home » Archived » BIRT » Create reportdesign with the Birt API in java
Create reportdesign with the Birt API in java [message #730785] Thu, 29 September 2011 03:28 Go to next message
Hi there
I got a question is it possible to create a reportdesign in java with the help of the API.
I want to add a Headline field to each reportdesign and I don´t want to do this by my own. This should do a java programm for me.
Could anybody help me
Dude
Re: Create reportdesign with the Birt API in java [message #730943 is a reply to message #730785] Thu, 29 September 2011 11:09 Go to previous messageGo to next message
Absolutely. Have a look at the design engine api:
http://eclipse.org/birt/phoenix/deploy/designEngineAPI.php
Jason
On 9/29/2011 3:28 AM, Dude wrote:
> Hi there
> Dude
Re: Create reportdesign with the Birt API in java [message #733669 is a reply to message #730943] Wed, 05 October 2011 07:31 Go to previous messageGo to next message
Thanks a lot
I still got one problem. This solution add everything at the bottom of the report.
Do you have any idea how I can add my stuff on a certain point.
I want to add it at the top of my report as a headline
Dude
Re: Create reportdesign with the Birt API in java [message #733747 is a reply to message #733669] Wed, 05 October 2011 10:50 Go to previous messageGo to next message
You should be able to insert into a position:
designHandle.getBody().add(content, newPos)
where content is the design handle for your headline label or data item.
newPos is just an integer. Try 0.
Jason
On 10/5/2011 7:31 AM, Dude wrote:
> Thanks a lot
> the report.
> Thanks
> Dude
Re: Create reportdesign with the Birt API in java [message #733970 is a reply to message #733747] Thu, 06 October 2011 03:26 Go to previous messageGo to next message
Thansk I already got it.
But I still got one question how can I add a dynamic Textfield?
Dude
Re: Create reportdesign with the Birt API in java [message #734092 is a reply to message #733970] Thu, 06 October 2011 12:07 Go to previous messageGo to next message
Attached is a DE API example that shows adding various things to a
report including a text item.
Jason
> Dude
Re: Create reportdesign with the Birt API in java [message #749373 is a reply to message #734092] Tue, 25 October 2011 03:19 Go to previous messageGo to next message
One more question Wink
Is it possible to edit the rptlibrary via the API??
Thanks for any answers
Dude
Re: Create reportdesign with the Birt API in java [message #750033 is a reply to message #749373] Tue, 25 October 2011 11:38 Go to previous message
Yes the same way you edit a report.
Just open a library instead of a report:
LibraryHandle libhan =session.openLibrary("reports/test.rptlibrary");
DesignElementHandle mytable =
libhan.getElementFactory().newTableItem("mytable");
libhan.getComponents().add(mytable);
Jason
On 10/25/2011 3:19 AM, Dude wrote:
> Thanks
> One more question ;)
> Dude
Previous Topic:View hyperlinks in weblogic server
Next Topic:Hive dataset : column sum
Current Time: Tue Sep 23 07:10:54 EDT 2025
Powered by FUDForum. Page generated in 0.06348 seconds
