Home » Newcomers » Newcomers » Can't update Eclipse for EE Developers (Indigo)
Can't update Eclipse for EE Developers (Indigo) [message #730731] Wed, 28 September 2011 21:57 Go to next message
Originally posted by: Jarrick Chagma
When I go to update my IDE I get a long sequence of downloads and then
several errors popup similar to this:
An internal error occurred during: "Install download1".
Comparison method violates its general contract!
And then the overall update fails.
How can I get around this problem? I am using Eclipse 3.7 on Windows 7 x64
with Java 7.
Jarrick
Re: Can't update Eclipse for EE Developers (Indigo) [message #730732 is a reply to message #730731] Wed, 28 September 2011 22:26 Go to previous messageGo to next message
"Jarrick Chagma" wrote in message news:j60ika$kf8$1@news.eclipse.org...
> x64 with Java 7.
Now, when I tried it again, I get the same pop-ups and then this message
when the overall update fails:
An error occurred while collecting items to be installed
session context was:(profile=epp.package.jee,
phase=org.eclipse.equinox.internal.p2.engine.phases.Collect, operand=,
action=).
No repository found containing:
osgi.bundle,org.eclipse.help.base,3.6.1.v201109091335
Problems downloading artifact:
osgi.bundle,org.eclipse.jdt.debug,3.7.1.v20110802_r371.
File has invalid
content:C:\Users\Qu0ll\AppData\Local\Temp\signatureFile2484399316112185277.jar
Invalid content:jdi.jar
The file "jdi.jar" in the jar
"C:\Users\Qu0ll\AppData\Local\Temp\signatureFile2484399316112185277.jar" has
been tampered!
Invalid content:jdimodel.jar
The file "jdimodel.jar" in the jar
been tampered!
Retry another mirror
osgi.bundle,org.eclipse.jst.ws.consumption,1.0.601.v201108230319.
File has invalid
content:C:\Users\Qu0ll\AppData\Local\Temp\signatureFile3130881922127206531.jar
Invalid content:webserviceutils.jar
The file "webserviceutils.jar" in the jar
"C:\Users\Qu0ll\AppData\Local\Temp\signatureFile3130881922127206531.jar" has
been tampered!
osgi.bundle,org.eclipse.platform,3.7.1.v201109091335
So what's all that about? Why the missing repositories? And who's
tampering with files???
Jarrick
Re: Can't update Eclipse for EE Developers (Indigo) [message #731104 is a reply to message #730732] Thu, 29 September 2011 20:30 Go to previous messageGo to next message
"Jarrick Chagma" wrote in message news:j60kcg$lu3$1@news.eclipse.org...
I cleared out the temporary files and I don't get any errors about
"tampering" anymore but I still get multiple pop-up errors and this at the
end of it (when it has failed):
action=).
Error closing the output stream for
osgi.bundle,org.eclipse.platform,3.7.1.v201109091335 on repository
file:/D:/Java/apps/eclipse-indigo-x64/.
Error unzipping
C:\Users\Qu0ll\AppData\Local\Temp\org.eclipse.platform_3.7.1.v2011090913355802467490411037654.jar:
Invalid zip file format
Please, can someone tell me how to get around all these errors???
Jarrick
Re: Can't update Eclipse for EE Developers (Indigo) [message #731157 is a reply to message #730732] Fri, 30 September 2011 02:52 Go to previous messageGo to next message
>> then several errors popup similar to this:
You're probably running into https://bugs.eclipse.org/317785. You have
three choices:
1) Run with JRE 6 to do the update
2) Start with -Djava.util.Arrays.useLegacyMergeSort=true
3) Don't update but download a fresh 3.7.2 package
Dani
>> 7 x64 with Java 7.
> message when the overall update fails:
> action=).
> File has invalid
> has been tampered!
> has been tampered!
> File has invalid
> has been tampered!
> Jarrick
Re: Can't update Eclipse for EE Developers (Indigo) [message #731445 is a reply to message #731157] Fri, 30 September 2011 23:26 Go to previous messageGo to next message
"Daniel Megert" wrote in message news:j63o9t$pp6$1@news.eclipse.org...
I took this option and it all now updates perfectly. Thanks very much!
Jarrick
Re: Can't update Eclipse for EE Developers (Indigo) [message #735283 is a reply to message #731445] Tue, 11 October 2011 08:24 Go to previous messageGo to next message
Thanks for the solution. Could you elaborate on
"2) Start with -Djava.util.Arrays.useLegacyMergeSort=true"
Can you let know step-by-step instruction for above line.
Thanks.
Re: Can't update Eclipse for EE Developers (Indigo) [message #735559 is a reply to message #735283] Wed, 12 October 2011 03:36 Go to previous messageGo to next message
On 11.10.2011 14:24, Zen San wrote:
> Thanks for the solution. Could you elaborate on "2) Start with
eclipse[.exe] -vmargs -Djava.util.Arrays.useLegacyMergeSort=true
Dani
> Thanks.
Re: Can't update Eclipse for EE Developers (Indigo) [message #755656 is a reply to message #730731] Wed, 09 November 2011 03:50 Go to previous messageGo to next message
Solution 2 works.
Thank you, Dani.
Linerd
Re: Can't update Eclipse for EE Developers (Indigo) [message #997680 is a reply to message #731445] Tue, 08 January 2013 09:38 Go to previous messageGo to next message
Sorry. Start what where?
Re: Can't update Eclipse for EE Developers (Indigo) [message #1011997 is a reply to message #997680] Wed, 20 February 2013 11:53 Go to previous messageGo to next message
You can go to eclipse.ini file. Add this line after -vmargs
Re: Can't update Eclipse for EE Developers (Indigo) [message #1057510 is a reply to message #1011997] Wed, 08 May 2013 08:35 Go to previous messageGo to next message
I get the same error when attempting to update. Here is my .ini file with the -Djava line added: (I have also tried jre6) Eclipse 3.7 is not an option; I need to use 3.6 for a particular plugin. Any suggestions? -Thanks!
-startup
plugins/org.eclipse.equinox.launcher_1.1.0.v20100507.jar
--launcher.library
plugins/org.eclipse.equinox.launcher.win32.win32.x86_1.1.0.v20100503
-showsplash
--launcher.XXMaxPermSize
256m
--launcher.defaultAction
openFile
-vmargs
-Xms40m
-Xmx384m
Re: Can't update Eclipse for EE Developers (Indigo) [message #1058045 is a reply to message #1057510] Fri, 10 May 2013 11:26 Go to previous messageGo to next message
This shouldn't be a problem with "jre6"--it's specifically a change made in Java 7.
Re: Can't update Eclipse for EE Developers (Indigo) [message #1107373 is a reply to message #1058045] Thu, 12 September 2013 05:56 Go to previous messageGo to next message
I know this is a quite old post guys, but I just run into this and I was so curious about how the thing of passing parameters to the JVM when starting eclipse works....
Could anybody explain to me how basically did you figure out which argument to pass, and what that argument means?
best
R.
Re: Can't update Eclipse for EE Developers (Indigo) [message #1385985 is a reply to message #1107373] Thu, 12 June 2014 12:25 Go to previous messageGo to next message
I'm also still having this: on update software, getting the error:
session context was:(profile=epp.package.jee, phase=org.eclipse.equinox.internal.p2.engine.phases.Collect, operand=, action=).
No repository found containing: osgi.bundle,org.eclipse.jdt.core,3.9.2.v_OTDT_r222_201402180730
No repository found containing: org.eclipse.update.feature,org.eclipse.objectteams.otdt.core.patch,2.2.2.201402180730
I updated my eclipse.ini file to:
-startup
plugins/org.eclipse.equinox.launcher_1.3.0.v20130327-1440.jar
--launcher.library
plugins/org.eclipse.equinox.launcher.win32.win32.x86_64_1.1.200.v20140116-2212
-product
org.eclipse.epp.package.jee.product
openFile
256M
-showsplash
256m
openFile
--launcher.appendVmargs
-vmargs
-Djava.net.preferIPv4Stack=true
-Dosgi.requiredJavaVersion=1.6
-Xms40m
-Xmx512m
Re: Can't update Eclipse for EE Developers (Indigo) [message #1386236 is a reply to message #1385985] Sun, 15 June 2014 13:24 Go to previous messageGo to next message
I am aware that is a really old post fellas, but I just operate into this and that i was so inquisitive about how the detail of passing variables for the JVM when starting up eclipse works....
Could any person explain to me how mainly did you determine which argument to move, and what that argument indicates?
Re: Can't update Eclipse for EE Developers (Indigo) [message #1387097 is a reply to message #1386236] Tue, 24 June 2014 02:14 Go to previous messageGo to next message
Error unzipping
Re: Can't update Eclipse for EE Developers (Indigo) [message #1387171 is a reply to message #1386236] Tue, 24 June 2014 11:24 Go to previous messageGo to next message
See https://bugs.eclipse.org/bugs/show_bug.cgi?id=317785 for why that argument is required with an Eclipse this old. No one should be using a version this old if they can avoid it.
In the eclipse.ini file, anything before the -vmargs line is a command line option for Eclipse, anything after is meant for the JVM executable.
Re: Can't update Eclipse for EE Developers (Indigo) [message #1716070 is a reply to message #730731] Mon, 30 November 2015 20:39 Go to previous message
I am getting the same error. I have a "Arrays cannot be resolved" error yet my Java Build Path does have "JRE System Library [jre1.8.0_65]" in which includes rt.jar which includes the Arrays class. And of course the java code includes "import java.util.*;" and all the other java.util classes are working. I have Indigo and added "-Djava.util.Arrays.useLegacyMergeSort=true" after -vmargs, restarted Eclipse but no luck - Arrays still will not resolve. Any suggestions would be highly appreciated.
Previous Topic:Old Eclipse Version
Next Topic:Eclipse language behaving wierdly
Current Time: Thu Nov 06 09:40:48 EST 2025
Powered by FUDForum. Page generated in 0.15181 seconds
