Home » Archived » M2M (model-to-model transformation) » [ATL] Iterating over collections
[ATL] Iterating over collections [message #730603] Wed, 28 September 2011 13:06 Go to next message
i got two sequences: a = Sequence {0,2,3,6}, b = Sequence {2,1,2,1}.
Now i want to create the following string: '(0,2)(2,1)(3,2)(6,1)', similar to the zip function in functional programming. I tried lots of approaches, which didn't work. So, how is this possible without the possibility to iterate over multiple sequences with an iteration counter?
Thank you,
nicgue
[Updated on: Wed, 28 September 2011 13:06] by Moderator
Re: [ATL] Iterating over collections [message #730619 is a reply to message #730603] Wed, 28 September 2011 13:54 Go to previous messageGo to next message
You do have an iteration counter : the size of the result.
let a : OclAny = Sequence{0,2,3,6} in
let b : OclAny = Sequence{2,1,2,1} in
a->iterate(e; res : OclAny = Sequence{}|
res.append(Sequence{e,b->at(res.size() + 1)})
icon14.gif  Re: [ATL] Iterating over collections [solved] [message #730636 is a reply to message #730619] Wed, 28 September 2011 14:45 Go to previous messageGo to next message
great, thank you!
Re: [ATL] Iterating over collections [message #730651 is a reply to message #730619] Wed, 28 September 2011 15:05 Go to previous message
Or you can create one
let a : Sequence(Integer) = Sequence{0,2,3,6} in
let b : Sequence(Integer) = Sequence{2,1,2,1} in
Sequence{1..a->size()}->collectNested(e : Integer |
Sequence{a->at(e),b->at(e)})
Ed Willink
Previous Topic:[ATL] MWE2 component
Next Topic: How to call a called rule.[ATL]
Current Time: Thu Apr 17 16:47:29 EDT 2025
Powered by FUDForum. Page generated in 0.03369 seconds
