Home » Eclipse Projects » EclipseLink » How can I get the child entitites on a XML marshalling using @XmlID and @XmlIDREF annotations. I onl
How can I get the child entitites on a XML marshalling using @XmlID and @XmlIDREF annotations. I onl [message #730597] Wed, 28 September 2011 12:20
Hello all,
I want to generate an XML file of an object tree with 1:N relashionship. I am using the @XmlID and @XmlIDREF annotations.
The entity "construtora" has N "empreendimentos" entitites related.
The root class is :
class ConstrutoraImpl {
@XmlID
private long id;
String nome;
String contato;
String telefone;
@XmlIDREF
@XmlList
private List<EmpreendimentoImpl> empreendimentos;
class EmpreeendimentoImpl {
@XmlID
private long id:
String nome;
String endereco;
private ConstrutoraImpl construtora;
The java code to generate the XML file is:
JAXBContext context = (JAXBContext) JAXBContext.newInstance(new Class[]{ConstrutoraImpl.class, EmpreendimentoImpl.class});
Marshaller marshaller = context.createMarshaller();
marshaller.setProperty(Marshaller.JAXB_FORMATTED_OUTPUT, Boolean.TRUE);
marshaller.marshal(construtora, System.out);
The resulting XML file is:
<construtora>
<id>75</id>
<empreendimentos>74 75</empreendimentos>
<contato>contato1</contato>
<nome>nome1</nome>
<telefone>telefone1</telefone>
</construtora>
The "empreendimentos" child entities are missing. How can I generate a XML with all the child entitites and the root entity?
All the Best,
André Moutinho
Previous Topic:How can I get the child entitites on a XML marshalling using @XmlID and @XmlIDREF annotations. I onl
Next Topic:How to use @XmlID and @XmlIDREF annotations on a entity defined by an interface
Current Time: Sun Nov 09 01:48:05 EST 2025
Powered by FUDForum. Page generated in 0.03672 seconds
