| Access to a different column in the onCreate script [message #730454] |
Wed, 28 September 2011 08:49  |
Hi, I have a table that has columns as follows:
Type, Parameter, Value
for this example lets say the values for these columns are:
T, mirror_bypass_target, false
In the onCreate method of the Value column I have the code:
reportContext.setPersistentGlobalVariable("mirror_bypass_target",this.getValue());
This is to put the value into a global variable for use elsewhere in the report. Now I have many of these tables to deal with (each with a different Parameter name) so I'd like to make this script more generic so that I only have to specify "mirror_bypass_target" on the filter criteria for the table rather than both in the filter criteria and the script itself. I could do this if I could replace the literal value with a reference to the value of the Parameter column. Obviously the "this" context won't do here. Is there a way to achieve this?
| Re: Access to a different column in the onCreate script [message #730550 is a reply to message #730454] |
Wed, 28 September 2011 11:35  |
Mike,
Why not put it on the onCreate for the row and use
var pm = this.getRowData().getColumnValue("Parameter");
var val = this.getRowData().getColumnValue("Value");
reportContext.setPesistentGlobalVariable(pm, val);
BTW if you are not using this value in a chart you can just use
setGlobalVariable.
Jason
FUDForum. Page generated in 0.03137 seconds
