eclipse folder capacity increased too much after update plugins [message #729917] |
Tue, 27 September 2011 09:37 |
Missing name Mising name Messages: 3 Registered: September 2011 |
Hi everyone. My English is not very good.
My problem is: I had installed several plugins and today I have just updated these plugins through "Check for update" menu on Eclipse. After installed, size (capacity) of eclipse has increased about 250MB, too much, I think about tens MB is enough. I think eclipse just download and install all update plugins but don't remove old version of these plugins.
So, what is solution for my trouble ?
[Updated on: Tue, 27 September 2011 09:40] Report message to a moderator
Re: eclipse folder capacity increased too much after update plugins [message #730145 is a reply to message #730091] |
Tue, 27 September 2011 17:34 |
Eric Rizzo Messages: 3070 Registered: July 2009 |
Th Eclipse Foundation forum group is non-technical; it's not the right place to discuss your question. So I'm moving it to the Platform group instead.
The reason that Eclipse keeps old versions of plugins after updating is that it provides a "rollback" feature to allow users to revert their Eclipse installation to a previous state. For example, imagine you install some plugins and later realize that they don't work correctly or conflict with some other features that you use; Eclipse allows you to easily revert to a state before you installed the offending plugins. To do that, it has to keep old versions of plugins around.
If you click About Eclipse, then Installation Details, then Installation History, you can see the UI for this feature. I see that there's a Delete button there, but I'm not sure if it deletes just the "configuration" (state) or if it would also delete the associated plugin versions from your file system also. Hopefully someone else can answer that.
Eric
[Updated on: Tue, 27 September 2011 17:34] Report message to a moderator
FUDForum. Page generated in 0.03895 seconds
