Home » Language IDEs » C / C++ IDE (CDT) » referenced element 'enablement' is not defined
referenced element 'enablement' is not defined [message #728106] Thu, 22 September 2011 10:32
I'm trying to build CDT from git repository because I want to try the patch fea0a6163a194903940d0a90424449c60ed1b006. Unfortunately building of the project ends with following errors
Description Resource Path Location Type
Referenced element 'enablement' is not defined quickAssistProcessors.exsd /org.eclipse.cdt.ui/schema line 56 Plug-in Problem
Referenced element 'enablement' is not defined quickFixProcessors.exsd /org.eclipse.cdt.ui/schema line 61 Plug-in Problem
Is anybody here able to give me a solution of described problem, please? I have tried to search the web - there are some notes about this issue but with no solution.
I'm also not sure how to install the project to eclipse (when it will be built successfully). Copying the files to the eclipse directory will be enough?
regards
Jan
Previous Topic:static linking
Next Topic:problems with cross-compiler path on C/C++ Linux implementation
Current Time: Thu Nov 06 20:51:31 EST 2025
Powered by FUDForum. Page generated in 0.03651 seconds
