Re: Installed deltapack, now my ECLIPSE_HOME is incorrect!!!! [message #728089 is a reply to message #728088] |
Thu, 22 September 2011 13:57 |
David Wynter Messages: 4624 Registered: July 2009 |
Found it!
/home/david/workspace/.metadata/.plugins/org.eclipse.core.runtime/.settings/org.eclipse.pde.core.prefs:platform_path=/home/david/opt2/eclipse/deltapack/eclipse
/home/david/workspace/.metadata/.plugins/org.eclipse.core.runtime/.settings/org.eclipse.pde.core.prefs:saved_platform0=/home/david/opt2/eclipse/deltapack/eclipse
Changed these to be correct and it works again. Still no idea how they
ended up like that when deltapack was added. Hope this helps someone else.
David
On 22/09/11 14:51, David Wynter wrote:
> Still don't know how it got changes but using grep found this
> org.eclipse.jdt.core.classpathVariable.ECLIPSE_HOME=/home/david/opt2/eclipse/deltapack/eclipse
> in
> /home/david/workspace/.metadata/.plugins/org.eclipse.core.runtime/.settings/org.eclipse.jdt.core.prefs
> I corrected this and saved. On restart still have the problem, so
> clearly it is getting this setting from somewhere else?
> Removed deltapack from my Target Runtime to see if that also corrected
> the ECLIPSE_HOME, didn't help.
> David
> On 22/09/11 14:08, David Wynter wrote:
>> Hi,
>> I installed the deltapack, somehow it changed my ECLIPSE_HOME variable
>> to point to the eclipse directory under the deltapack directory. Since
>> ECLIPSE_HOME is not edittable I am forced to reinstall Eclips and a
>> million plugins that I use. Another 4 hours lost... I seriously what
>> ever causes the dependency hell (who said DLL hell went away) and weird
>> config changes, is that p2?
>> David
FUDForum. Page generated in 0.03456 seconds
