Home » Language IDEs » C / C++ IDE (CDT) » Build Settings disabled
Build Settings disabled [message #726572] Sun, 18 September 2011 14:00 Go to next message
I have a C++ project, compiled with MinGW. Its Build Settings are entirely disabled. I've been told that's because I'm (not)using Managed Project but sadly I don't know where could I possibly set that. I need those options enabled because I want to change an output directory ( by default it's in Workspace\[Project name]\[Release/Debug] ).
Any ideas? Cheers, Tom
Re: Build Settings disabled [message #726649 is a reply to message #726572] Mon, 19 September 2011 03:15 Go to previous messageGo to next message
Open Project Properties->C/C++ Build
Check "Generate Makefiles automatically".
Re: Build Settings disabled [message #726788 is a reply to message #726649] Mon, 19 September 2011 10:59 Go to previous messageGo to next message
As I said before, all of the options on "Builder Settings" tab are disabled ( grayed-out ) and I cannot access them. I'm particularly interested in changing the "Build directory" option at the very bottom, which is unfortunately grayed-out as well (why?). However, "Generate Makefiles automatically" check box is already checked by default.
I'm using the Eclipse Indigo Release, if that could help in any way.
Re: Build Settings disabled [message #726946 is a reply to message #726788] Mon, 19 September 2011 22:50 Go to previous messageGo to next message
hmmm, not sure sorry, I thought managed build was the old way.
Did this project already exist? or did you create it from a directory? or import it from the filesystem? Personally for existing code I usually say new C++ makefile project, and then give it an existing directory. If _all_ of the settings in the Builder Settings tab are greyed out, I would suspect your project file is broken or incompatible with the version of eclipse cdt you are using. Just some guesses.
Re: Build Settings disabled [message #726991 is a reply to message #726788] Tue, 20 September 2011 02:29 Go to previous messageGo to next message
Thomas wrote on Mon, 19 September 2011 16:59
Then you are using the internal builder (see "Builder Settings->Builder type). You cannot change the build directory. If you want to change the "Output directory" you can either
- add a post build step that will copy your application (C/C++ Build->Settings->Build steps)
or
- modify the linker command in C/C++ Build->Settings->Tool Settings: C++ Linker
Re: Build Settings disabled [message #727655 is a reply to message #726991] Wed, 21 September 2011 15:01 Go to previous messageGo to next message
HI,
I want to do the same thing (reallocate the build directory). Can you tell us what need to be changed in the linker setting ?
regards
Jonathan
[Updated on: Wed, 21 September 2011 15:06] by Moderator
Re: Build Settings disabled [message #727870 is a reply to message #727655] Thu, 22 September 2011 02:20 Go to previous message
Jonathan wrote on Wed, 21 September 2011 21:01
HI,
regards
Jonathan
http://www.eclipse.org/forums/index.php/mv/msg/207500/665566/#msg_665566
Previous Topic:Contributing to CView context menu
Next Topic:Eclipse Indigo with MS VC 9.0? How to?
Current Time: Thu Nov 06 20:51:29 EST 2025
Powered by FUDForum. Page generated in 0.24978 seconds
