Re: xtext validation internal error while migrating to XTEXT2 [message #726412 is a reply to message #726338] |
Sun, 18 September 2011 00:13 |
iokerica Messages: 14 Registered: September 2011 |
Junior Member |
At first, it's just log4j shows the warning.
!ENTRY org.apache.log4j 4 0 2011-09-18 08:07:58.109
!MESSAGE org.eclipse.xtext.resource.impl.DefaultResourceDescriptionStrategy - java.lang.String cannot be cast to org.eclipse.xtext.naming.QualifiedName
!ENTRY org.apache.log4j 4 0 2011-09-18 08:08:01.390
!ENTRY org.apache.log4j 4 0 2011-09-18 08:08:01.417
!MESSAGE org.eclipse.xtext.linking.lazy.LazyLinkingResource - resolution of uriFragment 'xtextLink_::0.0.1.2::1::/7' failed.
Then after I types three elements then error popup shows
!ENTRY org.eclipse.core.jobs 4 2 2011-09-18 08:08:09.903
!MESSAGE An internal error occurred during: "Xtext validation".
!STACK 0
org.eclipse.emf.common.util.WrappedException: java.lang.ClassCastException: java.lang.String cannot be cast to org.eclipse.xtext.naming.QualifiedName
at org.eclipse.xtext.linking.lazy.LazyLinkingResource.getEObject(LazyLinkingResource.java:201)
at org.eclipse.xtext.linking.lazy.LazyLinkingResource.resolveLazyCrossReference(LazyLinkingResource.java:139)
at org.eclipse.xtext.linking.lazy.LazyLinkingResource.resolveLazyCrossReferences(LazyLinkingResource.java:103)
at org.eclipse.xtext.EcoreUtil2.resolveLazyCrossReferences(EcoreUtil2.java:417)
at org.eclipse.xtext.validation.ResourceValidatorImpl.resolveProxies(ResourceValidatorImpl.java:127)
at org.eclipse.xtext.validation.ResourceValidatorImpl.validate(ResourceValidatorImpl.java:62)
at org.eclipse.xtext.ui.editor.validation.ValidationJob$1.exec(ValidationJob.java:79)
at org.eclipse.xtext.ui.editor.validation.ValidationJob$1.exec(ValidationJob.java:1)
at org.eclipse.xtext.util.concurrent.AbstractReadWriteAcces.readOnly(AbstractReadWriteAcces.java:32)
at org.eclipse.xtext.ui.editor.model.XtextDocument.readOnly(XtextDocument.java:86)
at org.eclipse.xtext.ui.editor.validation.ValidationJob.createIssues(ValidationJob.java:75)
at org.eclipse.xtext.ui.editor.validation.ValidationJob.run(ValidationJob.java:64)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54)
Caused by: java.lang.ClassCastException: java.lang.String cannot be cast to org.eclipse.xtext.naming.QualifiedName
at org.eclipse.xtext.naming.DefaultDeclarativeQualifiedNameProvider$2.get(DefaultDeclarativeQualifiedNameProvider.java:62)
at org.eclipse.xtext.naming.DefaultDeclarativeQualifiedNameProvider$2.get(DefaultDeclarativeQualifiedNameProvider.java:1)
at org.eclipse.xtext.util.OnChangeEvictingCache.get(OnChangeEvictingCache.java:46)
at org.eclipse.xtext.naming.DefaultDeclarativeQualifiedNameProvider.getFullyQualifiedName(DefaultDeclarativeQualifiedNameProvider.java:58)
at org.eclipse.xtext.naming.IQualifiedNameProvider$AbstractImpl.apply(IQualifiedNameProvider.java:31)
at org.eclipse.xtext.naming.IQualifiedNameProvider$AbstractImpl.apply(IQualifiedNameProvider.java:1)
at org.eclipse.xtext.scoping.Scopes$2.apply(Scopes.java:90)
at org.eclipse.xtext.scoping.Scopes$2.apply(Scopes.java:1)
at com.google.common.collect.Iterators$8.next(Iterators.java:697)
at com.google.common.collect.Iterators$7.computeNext(Iterators.java:602)
at com.google.common.collect.AbstractIterator.tryToComputeNext(AbstractIterator.java:135)
at com.google.common.collect.AbstractIterator.hasNext(AbstractIterator.java:130)
at org.eclipse.xtext.scoping.impl.MultimapBasedSelectable.setExportedObjects(MultimapBasedSelectable.java:97)
at org.eclipse.xtext.scoping.impl.MultimapBasedSelectable.<init>(MultimapBasedSelectable.java:36)
at org.eclipse.xtext.scoping.impl.ImportedNamespaceAwareLocalScopeProvider.internalGetAllDescriptions(ImportedNamespaceAwareLocalScopeProvider.java:216)
at org.eclipse.xtext.scoping.impl.ImportedNamespaceAwareLocalScopeProvider$2.get(ImportedNamespaceAwareLocalScopeProvider.java:204)
at org.eclipse.xtext.scoping.impl.ImportedNamespaceAwareLocalScopeProvider$2.get(ImportedNamespaceAwareLocalScopeProvider.java:1)
at org.eclipse.xtext.scoping.impl.ImportedNamespaceAwareLocalScopeProvider.getAllDescriptions(ImportedNamespaceAwareLocalScopeProvider.java:202)
at org.eclipse.xtext.scoping.impl.ImportedNamespaceAwareLocalScopeProvider.getResourceScope(ImportedNamespaceAwareLocalScopeProvider.java:112)
at org.eclipse.xtext.scoping.impl.ImportedNamespaceAwareLocalScopeProvider.getResourceScope(ImportedNamespaceAwareLocalScopeProvider.java:101)
at org.eclipse.xtext.scoping.impl.ImportedNamespaceAwareLocalScopeProvider.getScope(ImportedNamespaceAwareLocalScopeProvider.java:89)
at org.eclipse.xtext.scoping.impl.ImportedNamespaceAwareLocalScopeProvider.getScope(ImportedNamespaceAwareLocalScopeProvider.java:87)
at org.eclipse.xtext.scoping.impl.AbstractDeclarativeScopeProvider.delegateGetScope(AbstractDeclarativeScopeProvider.java:72)
at org.eclipse.xtext.scoping.impl.AbstractDeclarativeScopeProvider.getScope(AbstractDeclarativeScopeProvider.java:102)
at org.eclipse.xtext.linking.impl.DefaultLinkingService.getScope(DefaultLinkingService.java:59)
at org.eclipse.xtext.linking.impl.DefaultLinkingService.getLinkedObjects(DefaultLinkingService.java:119)
at org.eclipse.xtext.linking.lazy.LazyLinkingResource.getEObject(LazyLinkingResource.java:170)
... 12 more
[Updated on: Sun, 18 September 2011 00:20] Report message to a moderator
Re: xtext validation internal error while migrating to XTEXT2 [message #726414 is a reply to message #726412] |
Sun, 18 September 2011 00:23 |
Junior Member |
I guess I know what's wrong.
I have defined a subclass extends DefaultDeclarativeQualifiedNameProvider
But I just return String in the qualifiedName method.
Since it compiles, I didn't notice it.
But it seems you didn't update the comment.
in comment, it is still written as String.
* computes the fully qualified name of an EObject by first invoking a method <br/>
* <code>String qualifiedName(MyType ele)</code><br/>
* reflectively.
Thanks for hints.
Clark
[Updated on: Sun, 18 September 2011 00:42] Report message to a moderator
FUDForum. Page generated in 0.03686 seconds
