Re: Save a rptdocument during a report is ran [message #726134 is a reply to message #725753] |
Fri, 16 September 2011 16:07 |
Why not use the __document url parameter? You can specify a folder
location that is not temp. You could also add a script in the
beforeRender that makes a copy of the document, just remember that the
beforeRender is called every time a page is rendered in the viewer.
Just use standard file io and get the report document name and location
using:
reportContext.getHttpServletRequest().getAttribute("attributeBean").getReportDocumentName();
Jason
On 9/15/2011 12:54 PM, RWIL wrote:
> We would like to save the .rptdocument for each report ran through the
> birtviewer. The main idea is : whatever the output format requested by
> the user is, we would like to keep the corresponding .rptdocument stored
> somewhere on our server.
> Is there any API that can be put inside the .rptdesign to save the
> corresponding .rptdocument each time the .rptdesign is run ?
> The fact of running a report is creating a .rptdocument on a "temp-like"
> folder on the birtviewer site, but this .rptdocument is temporary and is
> being removed after a while. We would like to store it permanently
> somewhere.
> Any idea ?
> Kind regards
> RWIL
FUDForum. Page generated in 0.03350 seconds
