Re: Jax-WS creation and editing workflow [message #724695 is a reply to message #723926] |
Mon, 12 September 2011 20:28 |
On 09-Sep-11 15:32, michael.mott wrote:
> Either I am confused about the workflow of editing web services created
> with WTP or their is a problem.
> I created a POJO and used the Web Service wizard to create a bottom up
> web service. This web service accepts no parameters. Here is the code:
> public class test {
> public String doTest() {
> return "hello";
> Now I make a change so that the web service will accept a string. I add
> the String parameter to my function declaration. At this point I run the
> Web Service wizard again to generate new WSDL file, etc. but nothing
> changes. The files generated by the wizard are not updated.
> Is this how it's supposed to work? What should I do to re generate my
> web service resources?
> Thank you,
> Michael
Are you insisting on using a WSDL? Would you like to try writing a
RESTful service? I know a lot more about JAX-RS. If, however, you insist
on JAX-WS, I do have a sample project I can zip up and send you.
FUDForum. Page generated in 0.02974 seconds
