Re: Build Error [message #723436 is a reply to message #723401] |
Thu, 08 September 2011 14:45 |
Konstantin Komissarchik Messages: 1077 Registered: July 2009 |
It looks like the build that we were using has been removed. We need to start referencing a newer build. I will not be able to attend to this until a bit later today, but you can make a quick local workaround by taking juno-42 out of the build. Edit build.properties file at branch root. Remove juno-42 from the list of configurations and set configuration.recommended to juno-38.
For 0.4, the development and default target should be Eclipse 4.2 at this point, but commandline build cross-compiles with all Eclipse versions starting with Helios 3.6 to ensure backwards compatibility.
- Konstantin
[Updated on: Thu, 08 September 2011 14:45] Report message to a moderator
Re: Build Error [message #723702 is a reply to message #723648] |
Fri, 09 September 2011 08:23 |
Kamesh Sampath Messages: 213 Registered: July 2009 |
i right now have the Sapphire environment set up completely on Linux 64-bit and ready to get back to work on the bugs.
On the Juno-42 i see a minor glitch no Mylyn part of it as its not storing the repository properties, how many ever time I give user name and password + repo info its not saving and its getting back to defaults.
If you are using Mylyn, you too getting the same issue ? Though i can add/update/comment on the bugs via browser but I found Mylyn very convenient.
Let me know if you have an work around for this ?
After I took the update from the HEAD and recompiled my code i get two compilation errors on the modeling and modeling.xml, with one being some DocumentationParser error. Thats is preventing me from launching and testing, let me if this will not have any impact on testing then I shall ignore these errors and continue my testing.
[Updated on: Fri, 09 September 2011 09:36] Report message to a moderator
Re: Build Error [message #724242 is a reply to message #724071] |
Sun, 11 September 2011 17:21 |
On 09/10/2011 09:57 PM, Konstantin Komissarchik wrote:
> That will certainly do the trick, but I encourage you to try to use
> juno-42 as much as you can as 4.2 will be the default platform for the
> Eclipse Juno release in 2012, so it is important to flush out bugs in
> the platform and any bugs in platform/Sapphire interraction.
> - Konstantin
I took an update of the HEAD and started to build a clean copy (wiped all existing or previous downloads) with
juno-42 on my Linux (Open SUSE 11.4 64-bit, JDK7) am now getting the
following error
" [java] Cannot complete the install because of a conflicting
dependency.
[java] Software being installed: Sapphire SDK 0.4.0.201109112237
(org.eclipse.sapphire.sdk.feature.group 0.4.0.201109112237)
[java] Software currently installed: Sapphire SDK
0.4.0.201109102246 (org.eclipse.sapphire.sdk.feature.group
0.4.0.201109102246)
[java] Only one of the following can be installed at once:
[java] Sapphire Documentation 0.4.0.201109102246
(org.eclipse.sapphire.doc 0.4.0.201109102246)
[java] Sapphire Documentation 0.4.0.201109112237
(org.eclipse.sapphire.doc 0.4.0.201109112237)
[java] Cannot satisfy dependency:
[java] From: Sapphire SDK 0.4.0.201109102246
(org.eclipse.sapphire.sdk.feature.group 0.4.0.201109102246)
[java] To: org.eclipse.sapphire.doc [0.4.0.201109102246]
[java] From: Sapphire SDK 0.4.0.201109112237
[java] To: org.eclipse.sapphire.doc [0.4.0.201109112237]
[java] Application failed, log file location:
/home/kamesh/sapphire/sources/latest/org.eclipse.sapphire/build/bootstrap/configuration/1315761401367.log
[java]
BUILD FAILED
/home/kamesh/sapphire/sources/latest/org.eclipse.sapphire/build.xml:643:
The following error occurred while executing this line:
/home/kamesh/sapphire/sources/latest/org.eclipse.sapphire/build.xml:1226: The
/home/kamesh/sapphire/sources/latest/org.eclipse.sapphire/build.xml:1249: The
/home/kamesh/sapphire/sources/latest/org.eclipse.sapphire/build.xml:1256: Java
returned: 13
I preceieve that its not a platform or jdk issue.
Can you please let me know how to resolve the same ?
~Kamesh
[Updated on: Sun, 11 September 2011 17:23] Report message to a moderator
Re: Build Error [message #724673 is a reply to message #724654] |
Mon, 12 September 2011 19:02 |
On 09/12/2011 11:56 PM, Konstantin Komissarchik wrote:
> I have not heard of shortcuts locking resources that they reference. It
> could be something else entirely that changed in your environment and
> you haven't identified as related. In either case, when the build fails
> during file I/O, there is nothing that we can do to make the build more
> "robust". Avoiding issues like this is between you and your operating
> system.
> - Konstantin
thanks for putting this across, but then i just put my point forth just
to make sure that we could identify similar issues in the build and iron
it out so that these build issues wont arise.
~Kamesh
[Updated on: Mon, 12 September 2011 19:29] Report message to a moderator
FUDForum. Page generated in 0.06953 seconds
