Re: Running headless in virtual machine [message #724459 is a reply to message #724331] |
Mon, 12 September 2011 12:10 |
Sorry, no idea what's going on there. As I said above that is close to our own setup. I don't know if there is a configuration option in ESXi which would prevent disconnected VMs from GUI interaction.
There are a few things to consider:
- The Hudson/Jenkins connector can't be run as a service. Starting it via ssh might work depending on your setup. The best solutions is to autologin a test account and start the Hudson/Jenkins connector during login.
- Start the AUTagent(s) from inside the Hudson/Jenkins job (and don't forget to stop them when the job is done).
- You may get better performance starting the test executor on your Hudson/Jenkins master.
I'm not sure that any of the above points are the cause for your particular problem. Just check them and let's see if anything gets better if you change the setup.
Achim
FUDForum. Page generated in 0.05004 seconds
