Home » Archived » Memory Analyzer (MAT) » Problems checking out src
Problems checking out src [message #6946] Thu, 13 November 2008 14:05 Go to next message
Originally posted by: cgrinds.us.ibm.com
I'm following the instructions here:
http://wiki.eclipse.org/index.php?title=MemoryAnalyzer/Contr ibutor_Referenc
e#Setup
I'm using Eclipse 3.4, at step "Checkout", when I import the psf I receive
these errors:
Checkout operation for
' http://dev.eclipse.org/svnroot/technology/org.eclipse.mat/tr unk/plugins/or
g.eclipse.mat.jetty' failed.
g.eclipse.mat.chart' failed.
g.eclipse.mat.ui.help' failed.
g.eclipse.mat.hprof' failed.
g.eclipse.mat.eclipse' failed.
' http://dev.eclipse.org/svnroot/technology/org.eclipse.mat/tr unk/features/o
rg.eclipse.mat.chart-feature' failed.
rg.eclipse.mat-feature' failed.
Bad URL passed to RA layer
svn: URL
g.eclipse.mat.jetty' doesn't exist
0x0000000f: The folder 'C:\workspaces\mat-dev\org.eclipse.mat.chart\bin' is
locked by some external process. Please unlock the folder and try to check
out the project again.
0x0000000f: The folder 'C:\workspaces\mat-dev\org.eclipse.mat.ui.help\src'
is locked by some external process. Please unlock the folder and try to
check out the project again.
0x0000000f: The folder 'C:\workspaces\mat-dev\org.eclipse.mat.hprof\src' is
svn: URL
g.eclipse.mat.eclipse' doesn't exist
svn: URL
rg.eclipse.mat.chart-feature' doesn't exist
svn: URL
rg.eclipse.mat-feature' doesn't exist
Any suggestions?
Chris Grindstaff
cgrinds@us.ibm.com
Re: Problems checking out src [message #6973 is a reply to message #6946] Thu, 13 November 2008 15:34 Go to previous messageGo to next message
Hi Chris,
I realize that the project set is not update-to-date anymore. :-( I'll fix
that. Tomorrow. In the mean time, check out the projects from
then checkout the plugins below trunk/plugins.
Sorry,
Andreas.
Re: Problems checking out src [message #6996 is a reply to message #6946] Thu, 13 November 2008 15:45 Go to previous messageGo to next message
If I take another look, then the "old" psf file can only be part of the
story. We deleted some plug-ins (for example org.eclipse.mat.jetty). That
explains some of the error messages.
But the other URL's look okay. Maybe you need to configure proxy server?
Maybe the svn team provider (which one are you using?) doesn't get it?
Andreas.
Re: Problems checking out src [message #7020 is a reply to message #6973] Thu, 13 November 2008 17:19 Go to previous message
andreas.buchen@sap.com (Andreas Buchen) wrote in
news:1a4f88a3981be24598d0b195c4bb2308$1@www.eclipse.org:
> Hi Chris,
> fix that. Tomorrow. In the mean time, check out the projects from
Hello Andreas,
After I deleted my old projects and pulled the projects from svn again, all
is working.
I have several inspectors I wrote for an earlier version of MA that I
wanted to make current. Once I have them working, I'll post for comment.
Chris
Chris Grindstaff
cgrinds@us.ibm.com
Previous Topic:OQL: find objects with no inbounds from package
Next Topic:Save Value to File
Current Time: Fri Nov 07 06:23:04 EST 2025
Powered by FUDForum. Page generated in 0.03117 seconds
