Home » Archived » BIRT » Get report parameter with Report Engine lib
Re: Get report parameter with Report Engine lib [message #722693 is a reply to message #722310] |
Tue, 06 September 2011 14:23 |
You need to use a createGetParameterDefinitionTask. Take a look at the
attached example class.
Jason
package REAPI;
import java.util.Collection;
import java.util.Collections;
import java.util.HashMap;
import java.util.Iterator;
import java.util.logging.Level;
import org.eclipse.birt.core.framework.Platform;
import org.eclipse.birt.report.engine.api.EngineConfig;
import org.eclipse.birt.report.engine.api.EngineException;
import org.eclipse.birt.report.engine.api.IGetParameterDefinitionTask;
import org.eclipse.birt.report.engine.api.IParameterDefnBase;
import org.eclipse.birt.report.engine.api.IParameterGroupDefn;
import org.eclipse.birt.report.engine.api.IParameterSelectionChoice;
import org.eclipse.birt.report.engine.api.IReportEngine;
import org.eclipse.birt.report.engine.api.IReportEngineFactory;
import org.eclipse.birt.report.engine.api.IReportRunnable;
import org.eclipse.birt.report.engine.api.IScalarParameterDefn;
import org.eclipse.birt.report.engine.api.ReportEngine;
import org.eclipse.birt.report.model.api.CascadingParameterGroupHandle;
import org.eclipse.birt.report.model.api.ReportDesignHandle;
import org.eclipse.birt.report.model.api.ScalarParameterHandle;
public class ReportParameterList {
static void executeReport() throws EngineException
HashMap parmDetails = new HashMap();
IReportEngine engine=null;
EngineConfig config = null;
try{
config = new EngineConfig( );
config.setBIRTHome("C:\\birt\\birt-runtime-2_6_1\\birt-runtime-2_6_1\\ReportEngine");
config.setLogConfig(null, Level.OFF);
Platform.startup( config );
IReportEngineFactory factory = (IReportEngineFactory) Platform
.createFactoryObject(
IReportEngineFactory.EXTENSION_REPORT_ENGINE_FACTORY );
engine = factory.createReportEngine( config );
}catch( Exception ex){
ex.printStackTrace();
//Open a report design
IReportRunnable design =
engine.openReportDesign("reports/parameters.rptdesign");
IGetParameterDefinitionTask task =
engine.createGetParameterDefinitionTask( design );
Collection params = task.getParameterDefns( true );
//task.getDefaultValue(arg0);
//task.getSelectionListForCascadingGroup();
Iterator iter = params.iterator( );
while ( iter.hasNext( ) )
IParameterDefnBase param = (IParameterDefnBase) iter.next( );
if ( param instanceof IParameterGroupDefn )
IParameterGroupDefn group = (IParameterGroupDefn) param;
System.out.println( "Parameter Group: " + group.getName( ) );
// Do something with the parameter group.
// Iterate over group contents.
Iterator i2 = group.getContents( ).iterator( );
while ( i2.hasNext( ) )
IScalarParameterDefn scalar = (IScalarParameterDefn)
i2.next( );
//System.out.println("\t" + scalar.getName());
parmDetails.put( scalar.getName(), loadParameterDetails(
task, scalar, design, group));
else
IScalarParameterDefn scalar = (IScalarParameterDefn) param;
//System.out.println(param.getName());
parmDetails.put( scalar.getName(),loadParameterDetails( task,
scalar, design, null));
task.close();
engine.destroy();
private static HashMap loadParameterDetails(IGetParameterDefinitionTask
task, IScalarParameterDefn scalar, IReportRunnable report,
IParameterGroupDefn group){
HashMap parameter = new HashMap();
if( group == null){
parameter.put("Parameter Group", "Default");
}else{
parameter.put("Parameter Group", group.getName());
parameter.put("Name", scalar.getName());
parameter.put("Help Text", scalar.getHelpText());
parameter.put("Display Name", scalar.getDisplayName());
//this is a format code such as > for UPPERCASE
parameter.put("Display Format", scalar.getDisplayFormat());
if( scalar.isHidden() ){
parameter.put("Hidden", "Yes");
}else{
parameter.put("Hidden", "No");
if( scalar.allowBlank() ){
parameter.put("Allow Blank", "Yes");
}else{
parameter.put("Allow Blank", "No");
if( scalar.allowNull() ){
parameter.put("Allow Null", "Yes");
}else{
parameter.put("Allow Null", "No");
if( scalar.isValueConcealed() ){
parameter.put("Conceal Entry", "Yes"); //ie passwords etc
}else{
parameter.put("Conceal Entry", "No");
switch (scalar.getControlType()) {
case IScalarParameterDefn.TEXT_BOX: parameter.put("Type", "Text
Box"); break;
case IScalarParameterDefn.LIST_BOX: parameter.put("Type", "List
Box"); break;
case IScalarParameterDefn.RADIO_BUTTON: parameter.put("Type", "List
Box"); break;
case IScalarParameterDefn.CHECK_BOX: parameter.put("Type", "List
Box"); break;
default: parameter.put("Type", "Text Box");break;
switch (scalar.getDataType()) {
case IScalarParameterDefn.TYPE_STRING: parameter.put("Data Type",
"String"); break;
case IScalarParameterDefn.TYPE_FLOAT: parameter.put("Data Type",
"Float"); break;
case IScalarParameterDefn.TYPE_DECIMAL: parameter.put("Data Type",
"Decimal"); break;
case IScalarParameterDefn.TYPE_DATE_TIME: parameter.put("Data Type",
"Date Time"); break;
case IScalarParameterDefn.TYPE_BOOLEAN: parameter.put("Data Type",
"Boolean"); break;
default: parameter.put("Data Type", "Any"); break;
ScalarParameterHandle parameterHandle = ( ScalarParameterHandle )
scalar.getHandle();
parameter.put("Default Value", scalar.getDefaultValue());
parameter.put("Prompt Text", scalar.getPromptText());
parameter.put("Data Set Expression",
parameterHandle.getValueExpr());
if(scalar.getControlType() != IScalarParameterDefn.TEXT_BOX)
//System.out.println("dynamic parameter");
if ( parameterHandle.getContainer( ) instanceof
CascadingParameterGroupHandle ){
Collection sList = Collections.EMPTY_LIST;
String groupName = parameterHandle.getContainer( ).getName( );
//used for Cascading parms see IGetParameterDefinitionTask.java
code for comments
task.evaluateQuery( groupName );
//Need to load this for calls to get next level.
//This just gets the first level
Object [] keyValueTmp = new Object[1];
sList = task.getSelectionListForCascadingGroup( groupName,
keyValueTmp );
for ( Iterator sl = sList.iterator( ); sl.hasNext( ); )
IParameterSelectionChoice sI = (IParameterSelectionChoice) sl.next( );
Object value = sI.getValue( );
Object label = sI.getLabel( );
System.out.println( label + "--" + value);
}else{
Collection selectionList = task.getSelectionList(
scalar.getName() );
if ( selectionList != null )
HashMap dynamicList = new HashMap();
for ( Iterator sliter = selectionList.iterator( );
sliter.hasNext( ); )
IParameterSelectionChoice selectionItem =
(IParameterSelectionChoice) sliter.next( );
Object value = selectionItem.getValue( );
String label = selectionItem.getLabel( );
//System.out.println( label + "--" + value);
//Display label unless null then display value. Value is
the what should get passed to the report.
dynamicList.put(value,label);
parameter.put("Selection List", dynamicList);
Iterator iter = parameter.keySet().iterator();
System.out.println("======================Parameter =" +
scalar.getName());
while (iter.hasNext()) {
String name = (String) iter.next();
if( name.equals("Selection List")){
HashMap selList = (HashMap)parameter.get(name);
Iterator selIter = selList.keySet().iterator();
while (selIter.hasNext()) {
Object lbl = selIter.next();
System.out.println( "Selection List Entry ===== Key = " + lbl + "
Value = " + selList.get(lbl));
}else{
System.out.println( name + " = " + parameter.get(name));
return parameter;
* @param args
try
executeReport( );
catch ( Exception e )
e.printStackTrace();
On 9/5/2011 6:51 AM, Alessio Pollero wrote:
> I have an application written in Java (standalone swing application)
> from this application through Report Engine (BIRT RunTime) i want to get
> the list of all report parameters .
> Is it possible ? I want to retrieve all properties of a parameter :
> promptText
> valueType
> dataType
> distinct
> defaultValue
> I've tried using IRunAndRender, but seems that is not possible to
> retrieve a list of parameters class, there is only the option to
> retrieve parameterValue list :
> design = engine.openReportDesign(path);
> IRunAndRenderTask task = engine.createRunAndRenderTask(design);
> HashMap<String,Object> rep = task.getParameterValues();
> Is possible to retrieve a list of the parameters of a report with the
> report engine API ? How ?
> Thanks.
Current Time: Sat Apr 27 03:39:36 GMT 2024
Powered by FUDForum. Page generated in 0.02752 seconds
