Re: Setting mark in the code [message #77078 is a reply to message #77070] |
Thu, 24 July 2008 19:04   |
Originally posted by: Oleksii.Prudkyi.gmail.com
http://etc.to/eclipse_bookmarks_plugin
after installing setup shortcuts to Ctrl+F2, F2
Oleksii Prudkyi
24.07.2008 21:41, you wrote:
> I'm working in PDT. How can I set a simple marker so I can quickly come
> back to a code location in the same file using a key sequence like
> CTRL-F2? This is not the same as a bookmark...
> Pierre
Re: Setting mark in the code [message #77080 is a reply to message #77078] |
Thu, 24 July 2008 19:23  |
Originally posted by: codeslave.ca.ibm.com
You may also like:
* select some text
* ctrl-K to skip to next occurrence (uses same settings as ctrl-F, eg.,
wrappring, case sensitive)
Great for jumping around to find method declarations / calls and variables.
> Regards,
> Oleksii Prudkyi
>> Hi,
>> come back to a code location in the same file using a key sequence
>> like CTRL-F2? This is not the same as a bookmark...
>> Pierre
Nick Boldt :: Release Engineer, IBM Toronto Lab
Eclipse Modeling :: http://www.eclipse.org/modeling
http://wiki.eclipse.org/index.php/User:Nickb
FUDForum. Page generated in 0.02286 seconds
