Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » [Teneo] Cannot add an item to a HibernatePersistableEList
[Teneo] Cannot add an item to a HibernatePersistableEList [message #77007] |
Thu, 29 March 2007 08:48 |
Markus Bischof Messages: 72 Registered: July 2009 |
Member |
------=_NextPart_000_0023_01C771EF.D2F03AF0
Content-Type: text/plain;
charset="iso-8859-1"
Content-Transfer-Encoding: quoted-printable
Hi!
I've managed to load and save HibernateResource-Objects, but now I want =
to add some items to that resource using an AddCommand =
(org.eclipse.emf.edit.command.AddCommand), which calls (in my case) the =
method "addAll(collection)" of the HibernatePersistableEList-object =
(ownerList) (line 400). The "collection" contains only one object. This =
method runs until the call "notifications =3D inverseAdd(value, =
notifications)" (line 439) which throws an exception.
After some debugging I found the error in the BasicEObjectImpl.class of =
the one object contained in the "collection". It calls =
"newResource.attached(this)" in line 912 (newResource is a =
HibernateResource) which then calls the =
"eObject.eContainmentFeature()"-method. This method runs until line 459, =
460 an then tries to execute the following code:
FeatureMap featureMap =3D (FeatureMap)eContainer.eGet(eFeature);
for (int i =3D 0, size =3D featureMap.size(); i < size; ++i) {...}
But in my case, the method eContainer.eGet(eFeature) returns null or a =
string-object, but in no case a FeatureMap. (More information: eFeature =
is an EAttributeImpl-class and has as name "name", which means that the =
name of the eContainer should be resolved, at least I think so!)
Do I have to change my implementation so that it returns some FeatureMap =
(I actually don't know what that map should contain!) or is there =
something wrong with the HibernatePersistableEList-object?
I hope this is not too technical!
Markus Bischof
Content-Type: text/html;
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML><HEAD>
<META http-equiv=3DContent-Type content=3D"text/html; =
charset=3Diso-8859-1">
<META content=3D"MSHTML 6.00.6000.16414" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY bgColor=3D#ffffff background=3D"">
<DIV><FONT face=3DArial size=3D2>Hi!<BR><BR>I've managed to load and =
save=20
HibernateResource-Objects, but now I want to add some items to that =
resource=20
using an AddCommand (org.eclipse.emf.edit.command.AddCommand), which =
calls (in=20
my case) the method "addAll(collection)" of the =
HibernatePersistableEList-object=20
method=20
runs until the call "</FONT><FONT face=3DArial size=3D2>notifications =
=3D=20
inverseAdd(value, notifications)" (line 439) which throws an=20
exception.</FONT><BR><BR><FONT face=3DArial size=3D2>After some =
debugging I found=20
the error in the BasicEObjectImpl.class of the one object contained in =
the=20
"collection". It calls "newResource.attached(this)" in line 912 =
(newResource is=20
a HibernateResource) which then calls the=20
460 an=20
then tries to execute the following code:<BR><BR>FeatureMap featureMap =
=3D=20
(FeatureMap)eContainer.eGet(eFeature);<BR>for (int i =3D 0, size =3D=20
featureMap.size(); i < size; ++i) {...}</FONT></DIV>
<DIV><FONT face=3DArial size=3D2></FONT> </DIV>
<DIV><FONT face=3DArial size=3D2>But in my case, the method=20
eContainer.eGet(eFeature) returns null or a string-object, but in no =
case a=20
FeatureMap. (More information: eFeature is an EAttributeImpl-class and =
has as=20
name "name", which means that the name of the eContainer should be =
resolved, at=20
least I think so!)</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Do I have to change my implementation =
so that it=20
returns some FeatureMap (I actually don't know what that map should =
contain!) or=20
is there something wrong with the =
HibernatePersistableEList-object?</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>I hope this is not too =
technical!</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Markus =
Bischof</FONT></DIV></BODY></HTML>
------=_NextPart_000_0023_01C771EF.D2F03AF0--
Re: [Teneo] Cannot add an item to a HibernatePersistableEList [message #77019 is a reply to message #77007] |
Thu, 29 March 2007 08:59 |
Hi Markus,
Is the object on which eContainmentFeature is called a new object or an object loaded from the db?
gr. Martin
Markus Bischof wrote:
> Hi!
> method runs until the call "notifications = inverseAdd(value,
> FeatureMap featureMap = (FeatureMap)eContainer.eGet(eFeature);
> for (int i = 0, size = featureMap.size(); i < size; ++i) {...}
> Markus Bischof
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [Teneo] Cannot add an item to a HibernatePersistableEList [message #77133 is a reply to message #77112] |
Thu, 29 March 2007 10:51 |
Member |
Yes I can.
The editor I'm using can load resource from a file (using XMIResources).
When I add a new item to such a resource, I get to the same point, but the
eContainerFeatureID is different. When I add an item (as said: ActionImpl)
to a model from a XMIResource, the eContainerFeatureID is -5, but when I
load a model from the database an do the same thing, die eContainerFeatureID
is -2. I think that could be the problem.
Here you see the code from the BasicEObjectImpl.class where the exception is
thrown. The line (*) gibes a different result for the eFeature when I'm
using a container from the database, and then line (**) throws an excption.
protected static EReference eContainmentFeature(EObject eObject, EObject
eContainer, int eContainerFeatureID)
if (eContainer == null)
return null;
else
if (eContainerFeatureID <= EOPPOSITE_FEATURE_BASE)
(*) EStructuralFeature eFeature =
eContainer.eClass().getEStructuralFeature(EOPPOSITE_FEATURE_ BASE -
eContainerFeatureID);
if (eFeature instanceof EReference)
return (EReference)eFeature;
else
(**) FeatureMap featureMap =
Re: [Teneo] Cannot add an item to a HibernatePersistableEList [message #77149 is a reply to message #77133] |
Thu, 29 March 2007 11:04 |
To be sure, is the object (a child) which has econtainerfeatureid -2 a new object (not yet
persisted) or is it an object which has been loaded from the db also (together with its parent)?
gr. Martin
> Yes I can.
> return null;
> else
> else
The Netherlands
Re: [Teneo] Cannot add an item to a HibernatePersistableEList [message #77210 is a reply to message #77164] |
Thu, 29 March 2007 11:47 |
Member |
Yes...I did this and discovered that it comes from the
DelegatinECoreEList.class from the method inverseAdd, where the method
getFeatureID() (*) is called. In the case of a model loaded from file
system, the getFeatureID() method is called upon an EObjectContainmentEList
which returns 4, and when I load the model from the database, the
getFeatureID() method is called upon a PersistableEList, which returns
estructuralFeature.getFeatureID() (which is 1).
public NotificationChain inverseAdd(Object object, NotificationChain
notifications)
InternalEObject internalEObject = (InternalEObject) object;
if (hasNavigableInverse())
if (!hasInstanceClass())
return
internalEObject.eInverseAdd
(owner,
internalEObject.eClass().getFeatureID(getInverseEReference() ),
null,
notifications);
else
return
(owner,
getInverseFeatureID(),
getInverseFeatureClass(),
notifications);
else
return
(owner,
InternalEObject.EOPPOSITE_FEATURE_BASE - getFeatureID(),
null,
notifications);
Re: [Teneo] Cannot add an item to a HibernatePersistableEList [message #77226 is a reply to message #77210] |
Thu, 29 March 2007 11:53 |
Can you see what the estructuralfeature of the PersistableEList is (is it the eattribute)?
and when you call getEStructuralFeature on the EObjectContainmentEList?
gr. Martin
> notifications)
> return
> (owner,
> null,
> notifications);
> else
> return
> (owner,
> notifications);
> else
> return
> (owner,
> null,
> notifications);
The Netherlands
Re: [Teneo] Cannot add an item to a HibernatePersistableEList [message #77258 is a reply to message #77242] |
Thu, 29 March 2007 12:15 |
--------------010209050308090506050701
Markus,
I haven't followed this whole chain closely, but it's important to keep
in mind that a feature's ID with respect to the actual EClass of the
EObject instance with that feature is the index within that EClass' list
of eAllStructuralFeatures so with multiple inheritance, that means the
ID of the feature with respect to a particular EClass may not be the
same as the ID with respect to the EClass that defines the feature.
Here's how the ID is computed with respect to any particular EClass:
public int getFeatureID(EStructuralFeature feature)
EStructuralFeature [] eAllStructuralFeaturesData =
getEAllStructuralFeaturesData();
int index = feature.getFeatureID();
if (index != -1)
for (int last = eAllStructuralFeaturesData.length; index <
last; ++index)
if (eAllStructuralFeaturesData[index] == feature)
return index;
return -1;
In the case of single inheritance, the first if within the for loop will
find it. There was a recent bug fix related to this,
https://bugs.eclipse.org/bugs/show_bug.cgi?id=175386, so hopefully
that's not a factor in this issue.
> Hm...it's a org.eclipse.emf.ecore.impl.EReferenceImpl-object. Now here's
> what I found out:
> The EObjectContainmentEList returns only a local field for the featureID.
> The value of that field is 4, but when I use a watch-expression to get the
> EStructuralFeature, I also get an object of type
> org.eclipse.emf.ecore.impl.EReferenceImpl, which has 1 for the featureID
> value!
> The PersistableEList doesn't return a local field but it makes the call
> eStructuralFeature.getFeatureID() which then returns 1 (I think if the
> EObjectContainmentEList would make that call, too, it would return 1!
> Markus
Content-Type: text/html; charset=ISO-8859-1
<html>
<head>
</head>
Markus,<br>
<br>
list of eAllStructuralFeatures so with multiple inheritance, that means
the ID of the feature with respect to a particular EClass may not be
the same as the ID with respect to the EClass that defines the
feature. Here's how the ID is computed with respect to any particular
EClass:<br>
<blockquote><small> public int getFeatureID(EStructuralFeature feature)<br>
{<br>
getEAllStructuralFeaturesData();<br>
int index = feature.getFeatureID();<br>
if (index != -1)<br>
{<br>
last; ++index)<br>
{<br>
if (eAllStructuralFeaturesData[index] == feature)<br>
{<br>
return index;<br>
}<br>
}<br>
}<br>
return -1;<br>
}</small><br>
</blockquote>
will find it. There was a recent bug fix related to this, <a
href="https://bugs.eclipse.org/bugs/show_bug.cgi?id=175386">https://bugs.eclipse.org/bugs/show_bug.cgi?id=175386</a>,
so hopefully that's not a factor in this issue.<br>
<br>
<br>
<blockquote cite="mideuga1r$gnt$1@build.eclipse.org" type="cite">
<pre wrap="">Hm...it's a org.eclipse.emf.ecore.impl.EReferenceImpl-object. Now here's
what I found out:
value!
Markus
</pre>
</blockquote>
<br>
</body>
</html>
--------------010209050308090506050701--
Re: [Teneo] Cannot add an item to a HibernatePersistableEList [message #77274 is a reply to message #77242] |
Thu, 29 March 2007 12:25 |
Okay, can you check in the Impl class of the parent object which featureid is passed when the
EObjectContainmentList is created?
Can post that construction code? (the new EObjectContain.....)
gr. Martin
> what I found out:
> value!
> Markus
The Netherlands
Re: [Teneo] Cannot add an item to a HibernatePersistableEList [message #77306 is a reply to message #77258] |
Thu, 29 March 2007 12:51 |
Hi Ed,
Yes this case has multiple inheritance. The code you list below, in which class is this located?
The hibernate persistable elist extends the delegatingecoreelist which also has a method
getFeatureID. In my version it is like this:
public int getFeatureID()
return getEStructuralFeature().getFeatureID();
Should this getFeatureID also make use of the eclass of the owner of the elist? My emf version is
from 20070212.
gr. Martin
Ed Merks wrote:
> Markus,
> if (index != -1)
> last; ++index)
> return index;
> return -1;
>> what I found out:
>> value!
>> Markus
The Netherlands
Re: [Teneo] Cannot add an item to a HibernatePersistableEList [message #77322 is a reply to message #77274] |
Thu, 29 March 2007 13:18 |
Member |
Hi!
I'm not quite sure wht you mean.
I set a breakpoint in the EObjectEList.class file in the constructor:
public EObjectEList(Class dataClass, InternalEObject owner, int featureID)
super(dataClass, owner);
this.featureID = featureID;
Is that the right place?
I found out, that when I load a model from the database, the owner-object is
always an object of type ActivityImpl, and when I load a model from the file
system, there are 2 or 3 calls of that contructor with a PackageImpl as
owner. I don't know if that means something but I justwanted to mention it.
I almost forgot to say thank you for your engagement! I appreciate that! I
hope we can find a solution for my problem!
Regards, Markus!
"Martin Taal" <mtaal@elver.org> schrieb im Newsbeitrag
news:eugb8l$pkv$1@build.eclipse.org...
> is passed when the EObjectContainmentList is created?
> gr. Martin
Re: [Teneo] Cannot add an item to a HibernatePersistableEList [message #77338 is a reply to message #77306] |
Thu, 29 March 2007 13:43 |
--------------030402090805090203000506
Martin,
This is a bug that hides until you hit a multiple inheritance case!
Please open a bugzilla. It should look like this:
return owner.eClass().getFeatureID(getEStructuralFeature());
I think I can still fix this for M6 today...
Martin Taal wrote:
> Hi Ed,
> also has a method getFeatureID. In my version it is like this:
> @Override
> the elist? My emf version is from 20070212.
> gr. Martin
> Ed Merks wrote:
>> Markus,
>> keep in mind that a feature's ID with respect to the actual EClass of
>> the EObject instance with that feature is the index within that
>> EClass' list of eAllStructuralFeatures so with multiple inheritance,
>> that means the ID of the feature with respect to a particular EClass
>> may not be the same as the ID with respect to the EClass that defines
>> the feature. Here's how the ID is computed with respect to any
>> particular EClass:
>> if (index != -1)
>> last; ++index)
>> return index;
>> return -1;
>>> here's what I found out:
>>> featureID. The value of that field is 4, but when I use a
>>> watch-expression to get the EStructuralFeature, I also get an object
>>> of type org.eclipse.emf.ecore.impl.EReferenceImpl, which has 1 for
>>> the featureID value!
>>> call eStructuralFeature.getFeatureID() which then returns 1 (I think
>>> if the EObjectContainmentEList would make that call, too, it would
>>> return 1!
>>> Markus
<html>
<head>
</head>
Martin,<br>
<br>
Please open a bugzilla. It should look like this:<br>
<blockquote> public int getFeatureID()<br>
{<br>
return owner.eClass().getFeatureID(getEStructuralFeature());<br>
}<br>
</blockquote>
I think I can still fix this for M6 today...<br>
<br>
<br>
Martin Taal wrote:
<blockquote cite="mideugcos$2li$1@build.eclipse.org" type="cite">Hi Ed,
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
gr. Martin
<br>
<br>
Ed Merks wrote:
<br>
<blockquote type="cite">Markus,
<br>
<br>
EClass:
<br>
<br>
<br>
<br>
<br>
<br>
<br>
if (index != -1)
<br>
<br>
<br>
last; ++index)
<br>
<br>
<br>
<br>
return index;
<br>
<br>
<br>
<br>
return -1;
<br>
<br>
<br>
<a class="moz-txt-link-freetext" href="https://bugs.eclipse.org/bugs/show_bug.cgi?id=175386">https://bugs.eclipse.org/bugs/show_bug.cgi?id=175386</a>, so hopefully
<br>
<br>
<br>
<br>
<blockquote type="cite">Hm...it's a
org.eclipse.emf.ecore.impl.EReferenceImpl-object. Now here's what I
found out:
<br>
<br>
watch-expression to get the EStructuralFeature, I also get an object of
type org.eclipse.emf.ecore.impl.EReferenceImpl, which has 1 for the
featureID value!
<br>
<br>
<br>
<br>
Markus <br>
<br>
</blockquote>
<br>
</blockquote>
<br>
<br>
</blockquote>
<br>
</body>
</html>
--------------030402090805090203000506--
Re: [Teneo] Cannot add an item to a HibernatePersistableEList [message #77353 is a reply to message #77322] |
Thu, 29 March 2007 13:45 |
Hi Markus,
I mean in the generated Impl class (ActivityImpl) there is a get method to get the list to which you
are adding the childobject. This get method should have a new EObjectContainmentEList statement. One
of the arguments to the constructor is a featureid. What value does this feature id have and how
does the generated code look like (in the get method)?
I also hope to find the issue here!
gr. Martin
> Hi!
> Regards, Markus!
>> gr. Martin
The Netherlands
Re: [Teneo] Cannot add an item to a HibernatePersistableEList [message #77371 is a reply to message #77353] |
Thu, 29 March 2007 13:58 |
Member |
public EList getNodes() {
if (nodes == null) {
nodes = new EObjectContainmentEList(ActivityNode.class, this,
ProcessesPackage.ACTIVITY__NODES);
return nodes;
public Object eGet(int featureID, boolean resolve, boolean coreType) {
switch (featureID) {
case ProcessesPackage.ACTIVITY__NODES:
return getNodes();
case ProcessesPackage.ACTIVITY__EDGES:
return getEdges();
case ProcessesPackage.ACTIVITY__REFERENCES:
return getReferences();
case ProcessesPackage.ACTIVITY__REFERENCE_EDGES:
return getReferenceEdges();
case ProcessesPackage.ACTIVITY__EVENT_HANDLER:
return getEventHandler();
case ProcessesPackage.ACTIVITY__TOTALEXECUTIONTIME:
return new Integer(getTotalexecutiontime());
return super.eGet(featureID, resolve, coreType);
Ok...hopefully this is right! When I'm in debug mode and I just added over
the palette a new item to the activity (I draw them with the mouse), then I
come in the eGet-method. The switch-statement does nothing and the method
continues calling the super.eGet-method. Maybe the intention is, that
normally it should return getNodes(), but it never reaches that method,
because the featureID is wrong...
Did you see the post from Ed Merks? He said that this could be a
bug...perhaps that's already the solution for the problem!?!?
Markus
news:eugfuk$rfc$1@build.eclipse.org...
> Hi Markus,
> get the list to which you are adding the childobject. This get method
> should have a new EObjectContainmentEList statement. One of the arguments
> and how does the generated code look like (in the get method)?
> gr. Martin
>> Hi!
>> featureID)
>> is always an object of type ActivityImpl, and when I load a model from
>> the file system, there are 2 or 3 calls of that contructor with a
>> PackageImpl as owner. I don't know if that means something but I
>> I hope we can find a solution for my problem!
>> Regards, Markus!
>>> featureid is passed when the EObjectContainmentList is created?
>>> gr. Martin
> The Netherlands
Re: [Teneo] Cannot add an item to a HibernatePersistableEList [message #77401 is a reply to message #77338] |
Thu, 29 March 2007 14:05 |
Ed,
Yes indeed, I was overriding the getFeatureID method also which I should not do, or do it as you
listed below.
Here is the bugzilla:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=179994
gr. Martin
Ed Merks wrote:
> Martin,
> Martin Taal wrote:
>> Hi Ed,
>> @Override
>> gr. Martin
>> Ed Merks wrote:
>>> Markus,
>>> particular EClass:
>>> if (index != -1)
>>> last; ++index)
>>> return index;
>>> return -1;
>>>> return 1!
>>>> Markus
The Netherlands
Re: [Teneo] Cannot add an item to a HibernatePersistableEList [message #77502 is a reply to message #77432] |
Thu, 29 March 2007 15:35 |
Martin,
I also fixed two other analogous problems in EcoreEList and
FeatureMapUtil and did that for both 2.2.3 and 2.3.0; the fix will be in
today's M6 build (and in next weeks 2.2.3 maintenance build).
Martin Taal wrote:
> Okay, my feel is that this is the multi-inheritance feature bug Ed
> referred to. I will solve this in Teneo also so that it works for
> older releases.
> I will do a new build probably tomorrow which contains the fix for this.
> gr. Martin
>> The value for the featureID is 1...
Re: [Teneo] Cannot add an item to a HibernatePersistableEList [message #77525 is a reply to message #77502] |
Thu, 29 March 2007 17:28 |
Member |
Hi!
I just downloaded the new emf 2.2.3M6 build (from today) and uncompressed it
in my eclipse-folder. I don't know if I did it right, but there is still the
same problem! I actually don't see a difference in the code...
The getFeatureID()-method of the class EOjbectEList.class still returns only
a local field called featureID, but when I look in debug mode in the same
class in the getEStructuralFeature()-object, the featureID of that object is
1 (which is a EReferenceImpl).
When I'm using a model from the database, the getFeatureID()-method is
called from a DelegatingEcoreEList-object (which possibly is the
HibernatePersistableEList). to a PersistableEList-object.
On the other hand, when I'm loading a model from the filesystem using a
XMIResource, the getFeatureID()-method is called from an EcoreEList-object
(which possibly is a EObjectContaintmentEList) to an EObjectEList-object.
For the same empty model and adding a simple node, using the
HibernateResource I get 1 as featureID (leading to -2 ), and using the
XMIResource I get 4 as featureID (leading to -5). -5 works fine.
The editor did not even recognize that it is dirty (meaning that a new
object is added), but when I'm using the debugger to set manually the
featureID to 4 just after is has been computed, it realizes that an element
was added (there is a * in Name of the resource...), but the element isn't
displayed...
Here is the code which causes the problems. It is the same in both,
DelegatingECoreEList.class and ECoreEList.class, but as mentioned above, the
getFeatureID()-method differs in the implementations (PersistableEList and
EObjectEList).
else
return
(owner,
null,
notifications);
Re: [Teneo] Cannot add an item to a HibernatePersistableEList [message #77541 is a reply to message #77525] |
Thu, 29 March 2007 17:34 |
Hi Markus,
Yes that's the part that I need to fix, the PersistableEList overrides the getFeatureId method. It
should not for the new release. If everything goes well then tomorrow there should be a new release
of Teneo which solves this.
gr. Martin
> Hi!
> displayed...
> EObjectEList).
> else
> return
> (owner,
> null,
> notifications);
The Netherlands
Re: [Teneo] Cannot add an item to a HibernatePersistableEList [message #77569 is a reply to message #77554] |
Thu, 29 March 2007 18:19 |
Hi, Markus,
What you downloaded today was a Maintenance Build from the 2.2.3 release,
not M6 of the 2.3 release. It's maintenance continued on the 2.2 release
from last year ...
Christian
> Ah, ok...I thought the new emf version would already fix "something"! :)
> My fault!
> Then I'm looking forward for the new release and I'm surely post here if
> it works! (And probably if it doesn't, too! ;) )
> Kind regards,
> Markus
Re: [Teneo] Cannot add an item to a HibernatePersistableEList [message #77585 is a reply to message #77569] |
Thu, 29 March 2007 18:25 |
--------------040906060601020701010305
Christian,
Yeah. I was confused. We didn't publish our M6 yet today and this
week's 2.2.3 maintenance build was published before I fixed the problem
there too...
Christian W. Damus wrote:
> Hi, Markus,
> from last year ...
> Cheers,
> Christian
>> My fault!
>> Kind regards,
>> Markus
<html>
<head>
<title></title>
</head>
Christian,<br>
<br>
there too...<br>
<br>
<br>
<blockquote cite="mideugvvf$1dn$2@build.eclipse.org" type="cite">
<pre wrap="">Hi, Markus,
from last year ...
Christian
</pre>
<pre wrap="">Ah, ok...I thought the new emf version would already fix "something"! :)
My fault!
Kind regards,
Markus
</pre>
</blockquote>
<pre wrap=""><!---->
</pre>
</blockquote>
<br>
</body>
</html>
--------------040906060601020701010305--
Re: [Teneo] Cannot add an item to a HibernatePersistableEList [message #603928 is a reply to message #77007] |
Hi Markus,
gr. Martin
> Hi!
> Markus Bischof
The Netherlands
Re: [Teneo] Cannot add an item to a HibernatePersistableEList [message #603945 is a reply to message #77112] |
Member |
Yes I can.
return null;
else
else
Re: [Teneo] Cannot add an item to a HibernatePersistableEList [message #603947 is a reply to message #77133] |
gr. Martin
> Yes I can.
> return null;
> else
> else
The Netherlands
Re: [Teneo] Cannot add an item to a HibernatePersistableEList [message #603961 is a reply to message #77164] |
Member |
notifications)
return
(owner,
null,
notifications);
else
return
(owner,
notifications);
else
return
(owner,
null,
notifications);
Re: [Teneo] Cannot add an item to a HibernatePersistableEList [message #603964 is a reply to message #77210] |
gr. Martin
> notifications)
> return
> (owner,
> null,
> notifications);
> else
> return
> (owner,
> notifications);
> else
> return
> (owner,
> null,
> notifications);
The Netherlands
Re: [Teneo] Cannot add an item to a HibernatePersistableEList [message #603972 is a reply to message #77242] |
Ed Merks Messages: 33141 Registered: July 2009 |
Markus,
if (index != -1)
last; ++index)
return index;
return -1;
> what I found out:
> value!
> Markus
<html>
<head>
</head>
Markus,<br>
<br>
EClass:<br>
{<br>
{<br>
last; ++index)<br>
{<br>
{<br>
return index;<br>
}<br>
}<br>
}<br>
return -1;<br>
}</small><br>
</blockquote>
<br>
<br>
what I found out:
value!
Markus
</pre>
</blockquote>
<br>
</body>
</html>
Ed Merks
Re: [Teneo] Cannot add an item to a HibernatePersistableEList [message #603975 is a reply to message #77242] |
gr. Martin
> what I found out:
> value!
> Markus
The Netherlands
Re: [Teneo] Cannot add an item to a HibernatePersistableEList [message #603980 is a reply to message #77258] |
Hi Ed,
from 20070212.
gr. Martin
Ed Merks wrote:
> Markus,
> if (index != -1)
> last; ++index)
> return index;
> return -1;
>> what I found out:
>> value!
>> Markus
The Netherlands
Re: [Teneo] Cannot add an item to a HibernatePersistableEList [message #603984 is a reply to message #77274] |
Member |
Hi!
Regards, Markus!
> gr. Martin
Re: [Teneo] Cannot add an item to a HibernatePersistableEList [message #603989 is a reply to message #77306] |
Martin,
Martin Taal wrote:
> Hi Ed,
> @Override
> gr. Martin
> Ed Merks wrote:
>> Markus,
>> particular EClass:
>> if (index != -1)
>> last; ++index)
>> return index;
>> return -1;
>>> return 1!
>>> Markus
<html>
<head>
</head>
Martin,<br>
<br>
{<br>
}<br>
</blockquote>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
gr. Martin
<br>
<br>
Ed Merks wrote:
<br>
<br>
<br>
EClass:
<br>
<br>
<br>
<br>
<br>
<br>
<br>
if (index != -1)
<br>
<br>
<br>
last; ++index)
<br>
<br>
<br>
<br>
return index;
<br>
<br>
<br>
<br>
return -1;
<br>
<br>
<br>
<br>
<br>
<br>
<br>
found out:
<br>
<br>
featureID value!
<br>
<br>
<br>
<br>
Markus <br>
<br>
</blockquote>
<br>
</blockquote>
<br>
<br>
</blockquote>
<br>
</body>
</html>
Ed Merks
Re: [Teneo] Cannot add an item to a HibernatePersistableEList [message #603993 is a reply to message #77322] |
Hi Markus,
gr. Martin
> Hi!
> Regards, Markus!
>> gr. Martin
The Netherlands
Re: [Teneo] Cannot add an item to a HibernatePersistableEList [message #603997 is a reply to message #77353] |
Member |
return nodes;
return getNodes();
return getEdges();
Markus
> Hi Markus,
> gr. Martin
>> Hi!
>> featureID)
>> Regards, Markus!
>>> gr. Martin
> The Netherlands
Re: [Teneo] Cannot add an item to a HibernatePersistableEList [message #604004 is a reply to message #77338] |
Ed,
listed below.
gr. Martin
Ed Merks wrote:
> Martin,
> Martin Taal wrote:
>> Hi Ed,
>> @Override
>> gr. Martin
>> Ed Merks wrote:
>>> Markus,
>>> particular EClass:
>>> if (index != -1)
>>> last; ++index)
>>> return index;
>>> return -1;
>>>> return 1!
>>>> Markus
The Netherlands
Re: [Teneo] Cannot add an item to a HibernatePersistableEList [message #604030 is a reply to message #77432] |
Martin,
> older releases.
> gr. Martin
Ed Merks
Re: [Teneo] Cannot add an item to a HibernatePersistableEList [message #604035 is a reply to message #77502] |
Member |
Hi!
displayed...
EObjectEList).
else
return
(owner,
null,
notifications);
Re: [Teneo] Cannot add an item to a HibernatePersistableEList [message #604039 is a reply to message #77525] |
Hi Markus,
gr. Martin
> Hi!
> displayed...
> EObjectEList).
> else
> return
> (owner,
> null,
> notifications);
The Netherlands
Re: [Teneo] Cannot add an item to a HibernatePersistableEList [message #604048 is a reply to message #77554] |
Hi, Markus,
from last year ...
Christian
> My fault!
> Kind regards,
> Markus
Re: [Teneo] Cannot add an item to a HibernatePersistableEList [message #604052 is a reply to message #77569] |
Christian,
there too...
> Hi, Markus,
> from last year ...
> Cheers,
> Christian
>> My fault!
>> Kind regards,
>> Markus
<html>
<head>
<title></title>
</head>
Christian,<br>
<br>
there too...<br>
<br>
<br>
from last year ...
Christian
</pre>
My fault!
Kind regards,
Markus
</pre>
</blockquote>
</pre>
</blockquote>
<br>
</body>
</html>
Ed Merks
Current Time: Fri Apr 26 06:23:04 GMT 2024
Powered by FUDForum. Page generated in 0.06228 seconds
