Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [EMFStore] Problems when sharing project to Server
[EMFStore] Problems when sharing project to Server [message #721704] Fri, 02 September 2011 12:01 Go to next message
Hi, I'm starting with EMFStore and I followed the first 2 videotutorials: "How to install the EMFStore Framework" and "How to prepare your model for the EMFStore".
I have installed EMFStore SDK 0.8.9.M3 and the server starts ok. I also created the library model and prepared the client configuration correctly. The Client app starts ok and I can create the project and create instances of library and book. My problem is when I try to connect share the project to the EMF Server. When I try to login to it I get a "Server could not be reached." message and the EMFStore Server console shows me:
!ENTRY org.unicase.metamodel 1 1 2011-09-02 12:46:44.197
!MESSAGE Initialitation COMPLETE.
!MESSAGE Server is RUNNING...
02/09/2011 12:48:01 PM org.apache.xmlrpc.server.XmlRpcErrorLogger log
GRAVE: Received fatal alert: certificate_unknown
javax.net.ssl.SSLHandshakeException: Received fatal alert: certificate_unknown
	at com.sun.net.ssl.internal.ssl.Alerts.getSSLException(Unknown Source)
	at com.sun.net.ssl.internal.ssl.SSLSocketImpl.recvAlert(Unknown Source)
	at com.sun.net.ssl.internal.ssl.SSLSocketImpl.readRecord(Unknown Source)
	at com.sun.net.ssl.internal.ssl.SSLSocketImpl.performInitialHandshake(Unknown Source)
	at com.sun.net.ssl.internal.ssl.SSLSocketImpl.readDataRecord(Unknown Source)
	at com.sun.net.ssl.internal.ssl.AppInputStream.read(Unknown Source)
	at java.io.BufferedInputStream.fill(Unknown Source)
	at java.io.BufferedInputStream.read(Unknown Source)
	at org.apache.xmlrpc.webserver.Connection.readLine(Connection.java:241)
	at org.apache.xmlrpc.webserver.Connection.getRequestConfig(Connection.java:150)
	at org.apache.xmlrpc.webserver.Connection.run(Connection.java:204)
	at org.apache.xmlrpc.util.ThreadPool$Poolable$1.run(ThreadPool.java:68)
Can this error be related with the es.properties config file? What should I change?
Mauricio
Re: [EMFStore] Problems when sharing project to Server [message #721780 is a reply to message #721704] Fri, 02 September 2011 16:18 Go to previous messageGo to next message
Originally posted by: Jonas Helming
Hi Mauricio,
You say you have followed the step "prepare the model for the emfstore".
I assume you are following the tutorial for a older version of EMFStore.
Inheriting from a base class is not necessary in the newer versions of
EMFStore.
Did you follow this getting started:
http://eclipse.org/emf-store/gettingstarted.php
Please tell me if the new Tutorial solves your problem.
Cheers
Jonas
Am 02.09.2011 18:01, schrieb maureyeslopez:
> console shows me:
> certificate_unknown
> at
> Source)
> Source)
> at
> should I change?
> Thanks
> Mauricio
Re: [EMFStore] Problems when sharing project to Server [message #722353 is a reply to message #721780] Mon, 05 September 2011 09:34 Go to previous messageGo to next message
Jonas, my problem was in the prerrequisites. I was trying to use EMF Store with Eclipse Indigo for Plugin Development with several plugins added (EMF, Teneo, etc)
I installed Helios for Modelling and I don't have the problem any more.
Re: [EMFStore] Problems when sharing project to Server [message #723061 is a reply to message #722353] Wed, 07 September 2011 09:57 Go to previous messageGo to next message
would it be possible for you to share the detailed configuration with
us, which caused problems? We are running EMFStore on Indigo and we
would be interested in fixing any issues if there are some.
Jonas
Am 05.09.2011 15:34, schrieb maureyeslopez:
> Thanks
Re: [EMFStore] Problems when sharing project to Server [message #723429 is a reply to message #723061] Thu, 08 September 2011 10:35 Go to previous message
I sent you an email with the subject of this post with my Eclipse configuration. If you need other data just tell me.
I followed the exactly the tutorial so I think I was missing some plugin.
Mauricio
Previous Topic:[EEF] Multiple different elements binding in a properties view
Next Topic:Change the order of parameters that are displayed on property window
Current Time: Wed Sep 10 19:36:18 EDT 2025
Powered by FUDForum. Page generated in 0.03707 seconds
