Re: Exporting bundle project uses incorrect MANIFEST.MF [message #721726 is a reply to message #721601] |
Fri, 02 September 2011 16:59 |
This sounds like a bug in the exporter. Are you using Bundlor, if so you might need to update some settings names, I can help you if this is the case. This will hopefully be automated in the future for people coming across from the existing tools. Please remember the new tools, as donated to Eclipse, have only done a single milestone release, lots of ruff edges.
Chris
Chris Frost, Twitter @cgfrost
Springsource, a divison of VMware.
Re: Exporting bundle project uses incorrect MANIFEST.MF [message #722670 is a reply to message #722572] |
Tue, 06 September 2011 13:11 |
I've had a play with that and I consider it a serious bug in the Bundlor tooling support. I have raised bug https://bugs.eclipse.org/bugs/show_bug.cgi?id=356807 for it.
To get around your original problem I've looked at some old information about the tooling, you should be able to tell your plan project which workspace pojects it depends on then the whole process of making them available to the plan when the plan is deployed, using the tools, automatic.
Chris.
FUDForum. Page generated in 0.03456 seconds
