Re: XSDRedefinableComponent [message #76839 is a reply to message #76823] |
Fri, 09 January 2009 14:16 |
Ed Merks Messages: 33216 Registered: July 2009 |
Joachim,
Comments below.
Joachim Back wrote:
> Having a look into XSD.ecore in
> org.eclipse.xsd_2.4.1.v200808251517.jar, I see that the abstract
> EClass "XSDRedefinableComponent" has the abstract ESuperType
> "XSDRedefineContent".
> All non abstract EClasses which have ESuperType
> "XSDRedefinableComponent", e.g. "XSDAttributeGroupDefinition",
> "XSDModelGroupDefinition", "XSDTypeDefinition" also have ESuperType
> "XSDRedefineContent". The EClass "XSDRedefinableComponent" is never
> inherited without also inherting "XSDRedefineContent".
> So, the EClass "XSDRedefineContent" is inherited directly AND indirectly.
> Is there any special reason for such a - I tend to say bad - modeling?
> Will the direct inheritance be removed in later versions?
I suppose that making the diagrams pettier at the expense of redundant
inheritance in the model isn't an ideal trade-off. I'll have to add
redefineable component to the concrete containment diagram to make that
complete. When I convert to using Ecore Tools instead of Rose, I could
definitely do that. Please open a bugzilla enhancement request to track
the issue. Redoing the diagrams with Ecore Tools will be a lot of work
and isn't a priority mind you...
> Regards,
> Joachim Back
Ed Merks
Re: XSDRedefinableComponent [message #603600 is a reply to message #76823] |
Joachim,
Comments below.
> Regards,
> Joachim Back
Ed Merks
FUDForum. Page generated in 0.03550 seconds
