Home » Newcomers » Newcomers » enable to stick breakpoints
enable to stick breakpoints [message #719441] |
Sat, 27 August 2011 06:52 |
shweta jain Messages: 1 Registered: August 2011 |
sir ,
when i am trying to put breakpoint in eclips(indigo), it is sowing following msg--
break point attribute problem,installation problem
and in the GDB TRACE console o/p following msg is showing--
026,299 1-environment-cd /home/manish/s2/ns2/ns-allinone-2.34/ns-2.34
026,300 1^done
026,301 (gdb)
026,303 2-gdb-set breakpoint pending on
026,304 2^done
026,304 (gdb)
026,306 3source .gdbinit
026,308 &"source .gdbinit\n"
026,310 3^done
026,310 (gdb)
026,312 4-gdb-set auto-solib-add on
026,312 4^done
026,312 (gdb)
026,316 5-file-exec-and-symbols /home/manish/s2/ns2/ns-allinone-2.34/ns-2.34/ns
027,036 ~"Using host libthread_db library \"/lib/tls/libthread_db.so.1\".\n"
027,040 5^done
027,040 (gdb)
027,085 6-inferior-tty-set /dev/pts/3
027,086 6^error,msg="Undefined MI command: inferior-tty-set"
027,086 (gdb)
027,102 7-exec-run
027,102 7^running
027,103 (gdb)
what is meaning of these msg.
how can i put the breakpoints in eclips
plzzzzzz help.
regards
shweta jain
Re: enable to stick breakpoints [message #719933 is a reply to message #719441] |
Mon, 29 August 2011 13:43 |
On 27-Aug-11 00:52, shweta jain wrote:
> sir ,
> following msg--
> 026,300 1^done
> 026,301 (gdb) 026,303 2-gdb-set breakpoint pending on
> 026,304 2^done
> 026,304 (gdb) 026,306 3source .gdbinit
> 026,310 3^done
> 026,310 (gdb) 026,312 4-gdb-set auto-solib-add on
> 026,312 4^done
> 026,312 (gdb) 026,316 5-file-exec-and-symbols
> 027,040 5^done
> 027,040 (gdb) 027,085 6-inferior-tty-set /dev/pts/3
> 027,086 (gdb) 027,102 7-exec-run
> 027,102 7^running
> 027,103 (gdb)
> plzzzzzz help.
> regards
> shweta jain
You may get more and better help in the Eclipse CDT forum.
Current Time: Fri Apr 26 02:56:25 GMT 2024
Powered by FUDForum. Page generated in 0.08101 seconds
