Home » Modeling » TMF (Xtext) » Problems with imports after migrating to xtext 2.0
Problems with imports after migrating to xtext 2.0 [message #719398] |
Fri, 26 August 2011 22:24 |
Hi anybody,
In my szenario I have different grammars, which refer to different file-suffixes:
.wf: workflow-files
.mask: mask-files
I have some crossreferences between these files,
e.g:
in a file vsa.marvin.mod.schulung.workflow.CustomerManagement.wf:
workflow-language-v2.0 package vsa.marvin.mod.schulung.^workflow;
import vsa.marvin.mod.schulung.^workflow.OverviewMask;
javaMask OverviewMask
I can't resolve these crossreferences anymore.
I debugged and came to the following problem:
In ImportScope.getLocalElementsByName(QualifiedName name) there is a call:
importFrom.getExportedObjects(type, resolvedName,isIgnoreCase()
This tries to get all exported objects of the parentpackage, I guess, again calling ImportScope.getLocalElementsByName(QFN). This time there is only one normalizer in the list (vsa.marvin.mod.schulung.workflow.CustomerManagement.*). It tries to resolve the OverviewMask-Import by append the relativeName (in this case vsa.marvin.mod.schulung.workflow.OverviewMask), leading to an resolved name "vsa.marvin.mod.schulung.workflow.CustomerManagement.vsa.marvin.mod.schulung.workflow.OverviewMask", which is wrong and doesn't find any elements.
How do I get a importoptimizer that resolves vsa.marvin.mod.schulung.workflow.OverviewMask in a correct way?
Would be nice, if you could help me.
Best regards
Markus
See the stack:
Thread [Worker-36] (Suspended)
owns: vsa.marvin.mod.common.resource.DelegatingXtextResource (id=141)
org.eclipse.xtext.scoping.impl.ImportNormalizer.resolve(org.eclipse.xtext.naming.QualifiedName) line: 59
org.eclipse.xtext.scoping.impl.ImportScope.getLocalElementsByName(org.eclipse.xtext.naming.QualifiedName) line: 150
org.eclipse.xtext.scoping.impl.ImportScope(org.eclipse.xtext.scoping.impl.AbstractScope).getElements(org.eclipse.xtext.naming.QualifiedName) line: 127
org.eclipse.xtext.scoping.impl.ScopeBasedSelectable.getExportedObjects(org.eclipse.emf.ecore.EClass, org.eclipse.xtext.naming.QualifiedName, boolean) line: 37
org.eclipse.xtext.scoping.impl.ImportScope.getLocalElementsByName(org.eclipse.xtext.naming.QualifiedName) line: 152
org.eclipse.xtext.scoping.impl.ImportScope.getSingleLocalElementByName(org.eclipse.xtext.naming.QualifiedName) line: 140
org.eclipse.xtext.scoping.impl.ImportScope(org.eclipse.xtext.scoping.impl.AbstractScope).getSingleElement(org.eclipse.xtext.naming.QualifiedName) line: 101
org.eclipse.xtext.scoping.impl.ImportScope(org.eclipse.xtext.scoping.impl.AbstractScope).getSingleElement(org.eclipse.xtext.naming.QualifiedName) line: 104
vsa.marvin.mod.common.services.MarvinLinkingService.getLinkedObjects(org.eclipse.emf.ecore.EObject, org.eclipse.emf.ecore.EReference, org.eclipse.xtext.nodemodel.INode) line: 101
vsa.marvin.mod.common.resource.DelegatingXtextResource(org.eclipse.xtext.linking.lazy.LazyLinkingResource).getEObject(java.lang.String) line: 169
vsa.marvin.mod.common.resource.DelegatingXtextResource.getEObject(java.lang.String) line: 85
vsa.marvin.mod.common.resource.DelegatingXtextResource(org.eclipse.xtext.linking.lazy.LazyLinkingResource).resolveLazyCrossReference(org.eclipse.emf.ecore.InternalEObject, org.eclipse.emf.ecore.EStructuralFeature) line: 138
vsa.marvin.mod.common.resource.DelegatingXtextResource(org.eclipse.xtext.linking.lazy.LazyLinkingResource).resolveLazyCrossReferences(org.eclipse.xtext.util.CancelIndicator) line: 102
org.eclipse.xtext.EcoreUtil2.resolveLazyCrossReferences(org.eclipse.emf.ecore.resource.Resource, org.eclipse.xtext.util.CancelIndicator) line: 417
org.eclipse.xtext.validation.ResourceValidatorImpl.resolveProxies(org.eclipse.emf.ecore.resource.Resource, org.eclipse.xtext.util.CancelIndicator) line: 127
org.eclipse.xtext.validation.ResourceValidatorImpl.validate(org.eclipse.emf.ecore.resource.Resource, org.eclipse.xtext.validation.CheckMode, org.eclipse.xtext.util.CancelIndicator) line: 62
org.eclipse.xtext.ui.editor.validation.ValidationJob$1.exec(org.eclipse.xtext.resource.XtextResource) line: 79
org.eclipse.xtext.ui.editor.validation.ValidationJob$1.exec(java.lang.Object) line: 1
org.eclipse.xtext.ui.editor.model.XtextDocument$XtextDocumentLocker(org.eclipse.xtext.util.concurrent.AbstractReadWriteAcces<P>).readOnly(org.eclipse.xtext.util.concurrent.IUnitOfWork<T,P>) line: 32
org.eclipse.xtext.ui.editor.model.XtextDocument.readOnly(org.eclipse.xtext.util.concurrent.IUnitOfWork<T,org.eclipse.xtext.resource.XtextResource>) line: 86
org.eclipse.xtext.ui.editor.validation.ValidationJob.createIssues(org.eclipse.core.runtime.IProgressMonitor) line: 75
org.eclipse.xtext.ui.editor.validation.ValidationJob.run(org.eclipse.core.runtime.IProgressMonitor) line: 64
org.eclipse.core.internal.jobs.Worker.run() line: 54
Re: Problems with imports after migrating to xtext 2.0 [message #719459 is a reply to message #719398] |
Sat, 27 August 2011 09:48 |
Sebastian Zarnekow Messages: 3118 Registered: July 2009 |
Hi Markus,
there are by default a number of import scopes nested into each other.
If one cannot find something meaningful in its parent package, it will
simply delegate with the plain name to it (see
AbstractScope#getElements(QN)).
The unresolved references are probably not caused by the behavior that
you observed in the debugger.
Sebastian
On 27.08.11 00:24, Markus Oley wrote:
> Hi anybody,
> file-suffixes:
> wf: workflow-files
> mask: mask-files
> I have some crossreferences between these files, e.g:
> I can't resolve these crossreferences anymore. I debugged and came to
> call: importFrom.getExportedObjects(type, resolvedName,isIgnoreCase()
> name
> Best regards Markus
> See the stack: Thread [Worker-36] (Suspended)
> line: 59
> line: 150
> line: 127
> line: 152
> line: 140
> line: 101
> line: 104
> line: 104
> line: 101
> line: 169
> line: 85
> line: 102
> line: 79
> line: 1
> line: 32
> line: 86
> line: 75
> line: 64
Current Time: Fri Apr 26 13:38:32 GMT 2024
Powered by FUDForum. Page generated in 0.03270 seconds
