Re: Different results by generating PDF-Documents [message #719393 is a reply to message #719338] |
Fri, 26 August 2011 21:52 |
I tried this with the attached scripted data set report and could not
reproduce the issue. Do you have a way I could reproduce it?
Jason
On 8/26/2011 2:30 PM, juergenschaefer2000 wrote:
> Here is the Master-page Code
> I put the code in the onRender Method.
> Exciting is when I delete everything from my report and add the sample
> Datasource that everything works fine. But with my skripting datasource
> I got the failure that the footer is never hide. It works in Eclipse
> when I use "View Report as PDF" but my Problem is I can't try it out
> with my report because the Application opens a ssh connection and load
> the Data from a server and this does not funktion when I use the Eclipse
> integrated viewer. I belive that the integrated viewer use some other
> PDFRenderingOptions but I dont know what.
> <simple-master-page name="Simple MasterPage" id="2">
> <property name="type">a4</property>
> <page-footer>
> <grid id="592">
> <method name="onRender"><![CDATA[if(pageNumber > 1){
> this.getStyle().display ="none"
> }]]></method>
> <column id="593" />
> <column id="594" />
> <column id="595" />
> <row id="596">
> <cell id="597">
> <label id="606">
> <text-property name="text">Gerät</text-property>
> </label>
> </cell>
> <cell id="598">
> <label id="607">
> <text-property name="text">Uhrzeit</text-property>
> </label>
> </cell>
> <cell id="599">
> <label id="608">
> <text-property name="text">Arbeiten</text-property>
> </label>
> </cell>
> </row>
> <row id="600">
> <cell id="601">
> <label id="609">
> <property name="borderBottomColor">#000000</property>
> <property name="borderBottomStyle">solid</property>
> <property name="borderBottomWidth">thin</property>
> </label>
> <label id="610">
> </label>
> <label id="611">
> </label>
> <label id="612">
> </label>
> <label id="613">
> </label>
> <label id="614">
> </label>
> <label id="615">
> </label>
> <label id="616">
> </label>
> </cell>
> <cell id="602">
> <label id="617">
> </label>
> <label id="618">
> </label>
> <label id="619">
> </label>
> <label id="620">
> </label>
> <label id="621">
> </label>
> <label id="622">
> </label>
> <label id="623">
> </label>
> <label id="624">
> </label>
> </cell>
> <cell id="603">
> <label id="625">
> </label>
> <label id="626">
> </label>
> <label id="627">
> </label>
> <label id="628">
> </label>
> <label id="629">
> </label>
> <label id="630">
> </label>
> <label id="631">
> </label>
> <label id="632">
> </label>
> </cell>
> </row>
> </grid>
> </page-footer>
> </simple-master-page>
Attachment: sds.zip
(Size: 1.25KB, Downloaded 172 times)
FUDForum. Page generated in 0.05031 seconds
