CDT reports error with va_list but compiles anyway [message #718351] |
Wed, 24 August 2011 04:18 |
Originally posted by: Jarrick Chagma
I am using Eclipse 3.7 and working with a C project. The code makes use of
va_list by including stdarg.h. The project builds and runs successfully but
Eclipse marks the lines with va_list with compiler errors and says "Type
va_list could not be resolved" when I hover over it.
I am using MinGW as the tool chain and the contents of its stdarg.h are
shown below. I cannot see where the va_list macro is defined in it so I am
wondering how the build works at all.
What is going on here and how can I fix this problem?
Jarrick
* MinGW stdarg.h:
/* Copyright (C) 1989, 1997, 1998, 1999, 2000 Free Software Foundation, Inc.
This file is part of GCC.
GCC is free software; you can redistribute it and/or modify
it under the terms of the GNU General Public License as published by
the Free Software Foundation; either version 2, or (at your option)
any later version.
GCC is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
GNU General Public License for more details.
You should have received a copy of the GNU General Public License
along with GCC; see the file COPYING. If not, write to
the Free Software Foundation, 59 Temple Place - Suite 330,
Boston, MA 02111-1307, USA. */
/* As a special exception, if you include this header file into source
files compiled by GCC, this header file does not by itself cause
the resulting executable to be covered by the GNU General Public
License. This exception does not however invalidate any other
reasons why the executable file might be covered by the GNU General
Public License. */
* ISO C Standard: 7.15 Variable arguments <stdarg.h>
#ifndef _STDARG_H
#ifndef _ANSI_STDARG_H_
#ifndef RC_INVOKED
#ifndef __need___va_list
#define _STDARG_H
#define _ANSI_STDARG_H_
#endif /* not __need___va_list */
#undef __need___va_list
/* Define __gnuc_va_list. */
#ifndef __GNUC_VA_LIST
#define __GNUC_VA_LIST
typedef __builtin_va_list __gnuc_va_list;
#endif
/* Define the standard macros for the user,
if this invocation was from the user program. */
#ifdef _STDARG_H
#define va_start(v,l) __builtin_va_start(v,l)
#define va_end(v) __builtin_va_end(v)
#define va_arg(v,l) __builtin_va_arg(v,l)
#if !defined(__STRICT_ANSI__) || __STDC_VERSION__ + 0 >= 199900L
#define va_copy(d,s) __builtin_va_copy(d,s)
#endif
#define __va_copy(d,s) __builtin_va_copy(d,s)
/* Define va_list, if desired, from __gnuc_va_list. */
/* We deliberately do not define va_list when called from
stdio.h, because ANSI C says that stdio.h is not supposed to define
va_list. stdio.h needs to have access to that data type,
but must not use that name. It should use the name __gnuc_va_list,
which is safe because it is reserved for the implementation. */
#ifdef _HIDDEN_VA_LIST /* On OSF1, this means varargs.h is "half-loaded".
#undef _VA_LIST
#endif
#ifdef _BSD_VA_LIST
#undef _BSD_VA_LIST
#endif
#if defined(__svr4__) || (defined(_SCO_DS) && !defined(__VA_LIST))
/* SVR4.2 uses _VA_LIST for an internal alias for va_list,
so we must avoid testing it and setting it here.
SVR4 uses _VA_LIST as a flag in stdarg.h, but we should
have no conflict with that. */
#ifndef _VA_LIST_
#define _VA_LIST_
#ifdef __i860__
#ifndef _VA_LIST
#define _VA_LIST va_list
#endif
#endif /* __i860__ */
typedef __gnuc_va_list va_list;
#ifdef _SCO_DS
#define __VA_LIST
#endif
#endif /* _VA_LIST_ */
#else /* not __svr4__ || _SCO_DS */
/* The macro _VA_LIST_ is the same thing used by this file in Ultrix.
But on BSD NET2 we must not test or define or undef it.
(Note that the comments in NET 2's ansi.h
are incorrect for _VA_LIST_--see stdio.h!) */
#if !defined (_VA_LIST_) || defined (__BSD_NET2__) || defined
(____386BSD____) || defined (__bsdi__) || defined (__sequent__) || defined
(__FreeBSD__) || defined(WINNT)
/* The macro _VA_LIST_DEFINED is used in Windows NT 3.5 */
#ifndef _VA_LIST_DEFINED
/* The macro _VA_LIST is used in SCO Unix 3.2. */
#ifndef _VA_LIST
/* The macro _VA_LIST_T_H is used in the Bull dpx2 */
#ifndef _VA_LIST_T_H
/* The macro __va_list__ is used by BeOS. */
#ifndef __va_list__
#endif /* not __va_list__ */
#endif /* not _VA_LIST_T_H */
#endif /* not _VA_LIST */
#endif /* not _VA_LIST_DEFINED */
#if !(defined (__BSD_NET2__) || defined (____386BSD____) || defined
(__bsdi__) || defined (__sequent__) || defined (__FreeBSD__))
#define _VA_LIST_
#endif
#ifndef _VA_LIST
#define _VA_LIST
#endif
#define _VA_LIST_DEFINED
#endif
#define _VA_LIST_T_H
#endif
#ifndef __va_list__
#define __va_list__
#endif
#endif /* not _VA_LIST_, except on certain systems */
#endif /* not __svr4__ */
#endif /* _STDARG_H */
#endif /* not RC_INVOKED */
#endif /* not _ANSI_STDARG_H_ */
#endif /* not _STDARG_H */
Re: CDT reports error with va_list but compiles anyway [message #718421 is a reply to message #718372] |
Wed, 24 August 2011 08:46 |
"Axel Mueller" wrote in message news:j325tt$fv1$1@news.eclipse.org...
>The error message is from the internal code analysis (CODAN) in Eclipse. I
>have similar code with va_list on Linux (stdarg.h seems to be identical)
>but do not get this error message. It > seems your index is not complete.
>Did you try to rebuild your index (open context menu of your project in
>Project Explorer and select Index->Rebuild)?
Thanks Axel, that fixed the problem.
Jarrick
FUDForum. Page generated in 0.03938 seconds
