Home » Eclipse Projects » WindowBuilder » Unable to switch to Design View
Unable to switch to Design View [message #718174] Tue, 23 August 2011 09:47 Go to next message
I'm using a freshly installed Eclipse 3.7 (64bit), with the latest WindowBuilder for SWT that I've just downloaded on Win7 64bit.
I created a new SWT Application Window, which seems to run fine and show the code view, but whenever I click on the "Design" tab, I get the following error:
Internal Error
WindowBuilder encountered unexpected internal error.
This could be caused by a WindowBuilder bug or by a misconfiguration issue, conflict, partial update, etc.
java.lang.IllegalArgumentException: Path must include project and resource name: /org.eclipse.swt
Stack trace:
Stack trace:
	at org.eclipse.core.runtime.Assert.isLegal(Assert.java:63)
	at org.eclipse.core.internal.resources.Workspace.newResource(Workspace.java:2163)
	at org.eclipse.core.internal.resources.Container.getFolder(Container.java:222)
	at org.eclipse.wb.internal.core.utils.reflect.ProjectClassLoader.addAbsoluteLocation(ProjectClassLoader.java:280)
	at org.eclipse.wb.internal.core.utils.reflect.ProjectClassLoader.addRuntimeClassPathEntries(ProjectClassLoader.java:124)
	at org.eclipse.wb.internal.core.utils.reflect.ProjectClassLoader.addFragment_runtimeClassPathEntries(ProjectClassLoader.java:168)
	at org.eclipse.wb.internal.core.utils.reflect.ProjectClassLoader.addFragments(ProjectClassLoader.java:157)
	at org.eclipse.wb.internal.core.utils.reflect.ProjectClassLoader.addRuntimeClassPathEntries(ProjectClassLoader.java:127)
	at org.eclipse.wb.internal.core.utils.reflect.ProjectClassLoader.getClasspathUrls(ProjectClassLoader.java:73)
	at org.eclipse.wb.internal.core.utils.reflect.ProjectClassLoader.create(ProjectClassLoader.java:64)
	at org.eclipse.wb.internal.core.parser.AbstractParseFactory.createClassLoader_project(AbstractParseFactory.java:792)
	at org.eclipse.wb.internal.core.parser.AbstractParseFactory.getClassLoader(AbstractParseFactory.java:747)
	at org.eclipse.wb.internal.core.parser.AbstractParseFactory.initializeClassLoader(AbstractParseFactory.java:732)
	at org.eclipse.wb.internal.rcp.parser.ParseFactory.getRootContext(ParseFactory.java:132)
	at org.eclipse.wb.internal.core.parser.JavaInfoParser.prepareParseContext(JavaInfoParser.java:1185)
	at org.eclipse.wb.internal.core.parser.JavaInfoParser.parse(JavaInfoParser.java:244)
	at org.eclipse.wb.internal.core.parser.JavaInfoParser.access$9(JavaInfoParser.java:240)
	at org.eclipse.wb.internal.core.parser.JavaInfoParser$1.runObject(JavaInfoParser.java:153)
	at org.eclipse.wb.internal.core.parser.JavaInfoParser$1.runObject(JavaInfoParser.java:1)
	at org.eclipse.wb.internal.core.utils.execution.ExecutionUtils.runDesignTime(ExecutionUtils.java:153)
	at org.eclipse.wb.internal.core.parser.JavaInfoParser.parse(JavaInfoParser.java:151)
	at org.eclipse.wb.internal.core.editor.DesignPage.internal_refreshGEF(DesignPage.java:513)
	at org.eclipse.wb.internal.core.editor.DesignPage.access$9(DesignPage.java:501)
	at org.eclipse.wb.internal.core.editor.DesignPage$8$1.run(DesignPage.java:434)
	at org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.java:180)
	at org.eclipse.ui.internal.UISynchronizer.syncExec(UISynchronizer.java:150)
	at org.eclipse.swt.widgets.Display.syncExec(Display.java:4683)
	at org.eclipse.wb.internal.core.editor.DesignPage$8.run(DesignPage.java:431)
	at org.eclipse.jface.operation.ModalContext.runInCurrentThread(ModalContext.java:464)
	at org.eclipse.jface.operation.ModalContext.run(ModalContext.java:372)
	at org.eclipse.jface.dialogs.ProgressMonitorDialog.run(ProgressMonitorDialog.java:507)
	at org.eclipse.wb.internal.core.editor.DesignPage.internal_refreshGEF_withProgress(DesignPage.java:450)
	at org.eclipse.wb.internal.core.editor.DesignPage.internal_refreshGEF(DesignPage.java:400)
	at org.eclipse.wb.internal.core.editor.UndoManager.refreshDesignerEditor(UndoManager.java:381)
	at org.eclipse.wb.internal.core.editor.UndoManager.activate(UndoManager.java:90)
	at org.eclipse.wb.internal.core.editor.DesignPage.handleActiveState_True(DesignPage.java:248)
	at org.eclipse.wb.internal.core.editor.DesignPage.handleActiveState(DesignPage.java:226)
	at org.eclipse.wb.internal.core.editor.multi.DefaultMultiMode.showPage(DefaultMultiMode.java:125)
	at org.eclipse.wb.internal.core.editor.multi.DefaultMultiMode$1.widgetSelected(DefaultMultiMode.java:63)
	at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:240)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1077)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1062)
	at org.eclipse.swt.widgets.Widget.notifyListeners(Widget.java:774)
	at org.eclipse.swt.custom.CTabFolder.setSelection(CTabFolder.java:2745)
	at org.eclipse.swt.custom.CTabFolder.onMouse(CTabFolder.java:1432)
	at org.eclipse.swt.custom.CTabFolder$1.handleEvent(CTabFolder.java:257)
	at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4165)
	at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3754)
	at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2696)
	at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2660)
	at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2494)
	at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:674)
	at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:667)
	at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:123)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
	at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
	at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
Full context stack trace:
Re: Unable to switch to Design View [message #718390 is a reply to message #718174] Wed, 24 August 2011 04:01 Go to previous messageGo to next message
I fixed it by including the swt.jar to the project manually, instead of setting up SWT as was recommended here: www.eclipse.org/swt/eclipse.php.
That page recommended importing the ZIP file as a project and then using it as a dependency, and that's what caused the exception above.
Maybe there is still a way to make this work even by using the SWT project as a dependency... can anyone help?
Re: Unable to switch to Design View [message #718578 is a reply to message #718390] Wed, 24 August 2011 13:37 Go to previous messageGo to next message
It seems that you try to use project where source and output location are project itself, instead of "src" and "bin".
Actually I can not even force Eclipse to create such project.
I think that link which you provide is very old.
Now recommended way to create SWT/JFace project is creating plugin and importing SWT, JFace and other plugins, so allow PDE manage classpath for you.
Re: Unable to switch to Design View [message #718595 is a reply to message #718578] Wed, 24 August 2011 15:32 Go to previous messageGo to next message
Konstantin Scheglov wrote on Wed, 24 August 2011 13:37
I've never heard about that before! (I'm new to both Eclipse and Java)
I did hear about adding User Libraries in Preferences > Java > Build Path > User Libraries, and then adding them to any project I want... is that something similar?
Re: Unable to switch to Design View [message #718870 is a reply to message #718595] Thu, 25 August 2011 10:29 Go to previous messageGo to next message
User libraries is something in the middle between:
1. adding jars directly into project;
2. managing classpath using PDE.
Such libraries allow use make modifications only in one place, instead of changing classpath for each project.
But when you update your Eclipse you still will need to change library to include new SWT, JFace, etc.
In contrast with PDE you specify name of library and PDE will find and use it in your plugins folder.
Re: Unable to switch to Design View [message #719357 is a reply to message #718870] Fri, 26 August 2011 15:36 Go to previous messageGo to next message
Strangely enough, they give the same instructions on how to use JFace: http://wiki.eclipse.org/JFace#Create_the_Eclipse_SWT.2FJFace_Project
Are you sure that this is not a WindowBuilder problem? Because the project itself compiles fine, it's only WindowBuilder the complains.
Re: Unable to switch to Design View [message #719529 is a reply to message #719357] Sat, 27 August 2011 12:16 Go to previous messageGo to next message
Well, I can not setup these projects to reproduce.
So, if you can provide projects, which can be imported into workspace to reproduce problem, I can take closer look.
Re: Unable to switch to Design View [message #721014 is a reply to message #719529] Wed, 31 August 2011 13:09 Go to previous messageGo to next message
I've fixed problem in WindowBuilder trunk.
Problem is that you use old style Java project, when *.java and *.class files are directly in project folder, instead of separate "src" and "bin" folders.
Re: Unable to switch to Design View [message #721057 is a reply to message #721014] Wed, 31 August 2011 15:46 Go to previous message
Thanks for fixing it!
Previous Topic:Latest version?
Next Topic:Exposing Shell's Styles by default
Current Time: Sun Nov 09 11:22:23 EST 2025
Powered by FUDForum. Page generated in 0.04882 seconds
