Home » Language IDEs » C / C++ IDE (CDT) » [SOLVED] Indigo Debug Hovers and Output on Linux
[SOLVED] Indigo Debug Hovers and Output on Linux [message #717998] Mon, 22 August 2011 20:28 Go to next message
Hi Guys,
I have had this problem for a long time and including previous versions, but I will ask in case someone can make a suggestion that can fix or mitigate the issue.
All of my debugger output in the Variables view and in hovers is riddled with "\n" characters on linux. I am also unable to get advanced debug hover at all.
I am using gdb 7.2 and have tried earlier versions.
Any suggestions, ideas, tricks?
Matt
The python pretty print stuff works fine to the extent that I have written several of my own in addition to the provided stl stuff.
[Updated on: Wed, 24 August 2011 01:21] by Moderator
Re: Indigo Debug Hovers and Output on Linux [message #718064 is a reply to message #717998] Tue, 23 August 2011 02:52 Go to previous messageGo to next message
Matt wrote on Tue, 23 August 2011 02:28
This never occurred to me. Do you use any special settings in your .gdbinit?
Which debugger framework do you use in Eclipse debug launch configuration? Does it say at the bottom of the launch config "Using GDB (DSF) Create Process Launcher"?
Re: [SOLVED] Indigo Debug Hovers and Output on Linux [message #718357 is a reply to message #718064] Wed, 24 August 2011 01:09 Go to previous message
Hi Axel,
Thanks to your suggestion I rechecked my gdbinit more carefully and found a set print pretty on command being sourced from one of the .gdb files. Commenting this out stops the chars. Yay.
I also found that the launch config was not using the DSF launcher. The definitions I have used for several years now... Nifty.
--> Thanks so much for this. Sanity rules. Smile
Previous Topic:Make Target Hide Empty Subfolders
Next Topic:Changing value of variable in debugger
Current Time: Tue Oct 28 20:01:41 EDT 2025
Powered by FUDForum. Page generated in 0.23174 seconds
