Home » Eclipse Projects » Buckminster dev » [buckminster-dev] Error Resolving Buckminster
[buckminster-dev] Error Resolving Buckminster [message #6859] Mon, 25 February 2008 14:42
Hi there,
Just setting up a clean dev workbench and opened the buckminster cquery.
I've got the latest updates (core v 1.0.0.r08952) but when I tried to
resolve the dev-cquery:
http://www.eclipse.org/buckminster/samples/queries/buckminst er-dev.cquery
I got a stack overflow error.
Log snippet:
!ENTRY org.eclipse.buckminster.core 2 293 2008-02-25 14:35:23.602
!MESSAGE java.lang.StackOverflowError
!STACK 0
org.eclipse.ui.internal.progress.ProgressManager$1.scheduled (ProgressManager.java:458)
org.eclipse.core.internal.jobs.JobListeners$5.notify(JobList eners.java:49)
org.eclipse.core.internal.jobs.JobListeners.doNotify(JobList eners.java:96)
org.eclipse.core.internal.jobs.JobListeners.scheduled(JobLis teners.java:162)
org.eclipse.core.internal.jobs.JobManager.schedule(JobManage r.java:958)
org.eclipse.core.internal.jobs.InternalJob.schedule(Internal Job.java:368)
at org.eclipse.core.runtime.jobs.Job.schedule(Job.java:461)
org.eclipse.ui.internal.progress.ProgressViewUpdater.schedul eUpdate(ProgressViewUpdater.java:226)
org.eclipse.ui.internal.progress.ProgressViewUpdater.refresh JobInfo(ProgressViewUpdater.java:338)
org.eclipse.ui.internal.progress.ProgressManager.refreshJobI nfo(ProgressManager.java:662)
org.eclipse.ui.internal.progress.ProgressManager$JobMonitor. internalWorked(ProgressManager.java:237)
org.eclipse.core.runtime.ProgressMonitorWrapper.internalWork ed(ProgressMonitorWrapper.java:94)
org.eclipse.core.runtime.SubProgressMonitor.internalWorked(S ubProgressMonitor.java:155)
Has something changed that I'm missing?
Todd
AMI Semiconductor - "Silicon Solutions for the Real World"
NOTICE:
This electronic message contains information that may be confidential or privileged. The information is intended for the use of the individual or entity named above. If you are not the intended recipient, please be aware that any disclosure, copying, distribution or use of the contents of this information is prohibited. If you received this electronic message in error, please notify the sender and delete the copy you received.
Previous Topic:[buckminster-dev] problems with resolve - uncaught exception
Next Topic:Re: [buckminster-dev] Error Resolving Buckminster
Current Time: Thu Nov 06 04:41:13 EST 2025
Powered by FUDForum. Page generated in 0.04324 seconds
