Re: BIRT log files [message #716528 is a reply to message #716268] |
Wed, 17 August 2011 15:46 |
Jeff
Do you see a file called platform.xml in this directory:
configuration\org.eclipse.update?
edit it and change
transient="false"
to
transient="true"
You should be able to clear the history and it should not write anymore
to this directory. There may be a better way to handle this and you
might want to log a bug to check.
If you are using the 3.7 runtime it does not use a platform directory.
Jason
On 8/16/2011 4:30 PM, Jeff Connelly wrote:
> The Report Engine creates XML log files in its
> configuration\org.eclipse.update\history folder. They are small, but are
> added each time the engine runs. Is there a parameter to stop/delete
> these logs or am I not shutting down the Report Engine correctly?
> Thank you , Jeff
Re: BIRT log files [message #716529 is a reply to message #716268] |
Jeff
edit it and change
transient="false"
to
transient="true"
Jason
> Thank you , Jeff
FUDForum. Page generated in 0.07621 seconds
