Home » Newcomers » Newcomers » Eclipse for Java, project missing required library
Eclipse for Java, project missing required library [message #715605] Sun, 14 August 2011 15:32 Go to next message
I have started a project on Eclipse for Java, Version: 3.5.2.
On the problems tab I am getting an error that my project is missing a library, a .jar file.
When I check the lib folder in the project tree pane on the left I can see the it is not there, I know where the .jar file is on my hard disk.
Is it a question of just manually adding the .jar file to the project? What menu would I use to do this? I have gone through the available menu items when right-clicking but can't find anything which looks like it would help.
Re: Eclipse for Java, project missing required library [message #715736 is a reply to message #715605] Mon, 15 August 2011 06:55 Go to previous messageGo to next message
On 14.08.2011 21:32, aspeich wrote:
Select the Java project in the 'Package Explorer' and then context menu
> Build Path > Add External Archives....
Dani
> Thanks
Re: Eclipse for Java, project missing required library [message #715854 is a reply to message #715736] Mon, 15 August 2011 15:11 Go to previous messageGo to next message
Thanks Dani.
I tried what you suggested and I got a message saying the jar file is already on the build path and will not be added.
I looked through the folders and can see it under the 'referenced libraries' folder, however I still have an error that there is a missing required library.
I tried deleting the jar file from referenced libraries in order to add it again in the correct location but the delete option is not active.
Any ideas?
Re: Eclipse for Java, project missing required library [message #715993 is a reply to message #715854] Tue, 16 August 2011 03:22 Go to previous messageGo to next message
On 15.08.2011 21:11, aspeich wrote:
> Thanks Dani.
> Any ideas?
When you expand the library, do you see classes? Maybe you added source
instead of class files.
Dani
Re: Eclipse for Java, project missing required library [message #716570 is a reply to message #715854] Wed, 17 August 2011 13:39 Go to previous messageGo to next message
On 8/15/11 3:11 PM, aspeich wrote:
> Thanks Dani.
> required library.
> Any ideas?
It might be that Eclipse was told about the JAR, but the JAR doesn't
exist any more in the location it was told. Open the project Properties,
then select Java Build Path, and Libraries tab. Do you see any errors
listed at the top of the dialog? Is the mystery JAR listed? If so, try
removing it and then re-adding it.
Eric
Re: Eclipse for Java, project missing required library [message #717444 is a reply to message #716570] Sat, 20 August 2011 14:17 Go to previous message
Thanks Eric, that did the trick!
Previous Topic:creating a java webapp
Next Topic:Startup Errors: "XML document structures"
Current Time: Sat Sep 06 20:03:22 EDT 2025
Powered by FUDForum. Page generated in 0.09280 seconds
