Home » Eclipse Projects » Technology Project and PMC » Modifying soruce code Vs. Using the extension point
Modifying soruce code Vs. Using the extension point [message #75734] Wed, 26 November 2008 21:13 Go to next message
My Goal:
Develop a plugin for Eclipse, this plugin has a dependeny on "plugin
X"
My Problem:
Some of features is not provided in the extension points of "plugin
X"
I'm curious:
I can achieve some of my targets via modifying the source code of
"plugin X" and re-publish "plugin X"
I know it's not a good practice
But what're the disadvantages of modifying source code directly?
Xing Yun
Re: Modifying soruce code Vs. Using the extension point [message #75750 is a reply to message #75734] Wed, 26 November 2008 22:30 Go to previous messageGo to next message
For one, if you modify the code, then you have to distribute it with
your code. You run the risk that your changes might not be compatible
with other plug-in providers. Further, as changes are made to the
original code, you will have to maintain yours.
If you think something needs to be changed, you could consider filing a
bug report to ask for it to be changed/added (you can contribute code
for the change).
Be sure to abide by the EPL if you do decide to change code.
Wayne
xing yun wrote:
> Hi
> My Goal:
> X"
> My Problem:
> X"
> I'm curious:
> Thanks
> Xing Yun
Re: Modifying soruce code Vs. Using the extension point [message #75767 is a reply to message #75750] Thu, 27 November 2008 00:01 Go to previous message
Thaks a lot for the quick reply
Xing Yun
"Wayne Beaton" <wayne@eclipse.org> wrote in message
news:ggl4aj$v8s$1@build.eclipse.org...
> For one, if you modify the code, then you have to distribute it with your
> code. You run the risk that your changes might not be compatible with
> other plug-in providers. Further, as changes are made to the original
> bug report to ask for it to be changed/added (you can contribute code for
> the change).
> Wayne
> xing yun wrote:
>> Hi
>> My Goal:
>> "plugin X"
>> My Problem:
>> "plugin X"
>> I'm curious:
>> Thanks
>> Xing Yun
Re: Modifying soruce code Vs. Using the extension point [message #601881 is a reply to message #75734] Wed, 26 November 2008 22:30 Go to previous message
for the change).
Wayne
xing yun wrote:
> Hi
> My Goal:
> X"
> My Problem:
> X"
> I'm curious:
> Thanks
> Xing Yun
Re: Modifying soruce code Vs. Using the extension point [message #601886 is a reply to message #75750] Thu, 27 November 2008 00:01 Go to previous message
Xing Yun
> the change).
> Wayne
> xing yun wrote:
>> Hi
>> My Goal:
>> "plugin X"
>> My Problem:
>> "plugin X"
>> I'm curious:
>> Thanks
>> Xing Yun
Previous Topic:Modifying soruce code Vs. Using the extension point
Next Topic:Error in eclipse Ant Build using ibator
Current Time: Sun Apr 20 21:22:13 EDT 2025
Powered by FUDForum. Page generated in 0.03791 seconds
